dzvents cam screenshot
Posted: Saturday 19 January 2019 16:24
by pvklink
Hi, i converted my last three blockly devices and one of them is a alarmscript.
I got the dzvents script working when it detects smoke or a burgler is active, the alarm switch is put on and several devices are triggered
In my old blockly script i had a rule "send camera_snapshot <camera> with subject <subject> after <x> seconds.
This part worked quit well! Is there a simular option in dzvents? i cant find it!
on = {devices = {'smoke*','Smoke*'}}, -- alle devices die met Smoke beginnen worden door dit script opgepakt
logging = { level = domoticz.LOG_DEBUG , -- Uncomment to override the dzVents global logging setting
marker = "Security"},
execute = function(dz, device, info)
local switch = dz.devices('Alarm_knop')
if device.state == 'On' then -- huis op alarm, iedereen is weg
switch.switchOn().checkFirst() --.silent() is als je volgende events niet wil starten
dz.log("Script: " .. info.scriptName .. " Er is een smokealarm, scenes worden geactiveerd....", dz.LOG_INFO)
elseif device.state == 'Off' then -- huis op alarm, iedereen is weg
switch.switchOff().checkFirst() --.silent() is als je volgende events niet wil starten
dz.log("Script: " .. info.scriptName .. " Smokealarm, onbekende alarmstatus....", dz.LOG_INFO)
Re: dzvents cam screenshot
Posted: Saturday 19 January 2019 18:03
by waaren
pvklink wrote: Saturday 19 January 2019 16:24
Can you show a screenshot of your blockly ?
Posted: Saturday 19 January 2019 18:45
by pvklink
I dont have an option to include a picture.
But it is quit easy, when you select add script/blockly
and then add devices/cameras within the blockly environment ..
that works perfect when you configure the email config in domoticz
Posted: Saturday 19 January 2019 20:29
by waaren
pvklink wrote:I dont have an option to include a picture.
What are the values of camera, subject and x?
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
Posted: Sunday 20 January 2019 12:16
by pvklink
IPCAM
foto vanaf de tuin
0
Posted: Monday 21 January 2019 10:56
by waaren
dzVents has no native command for this yet but you can use the function below.
local function snapshot(idx,subject,delay)
if not dz then dz = domoticz end
if not idx then idx = 1 end
if not subject then subject = "snapshot_" .. dz.time.rawDate .. "_" .. dz.time.rawTime end
if delay and delay > 0 then
local url = dz.settings['Domoticz url'] .. "/json.htm?type=command¶m=emailcamerasnapshot&camidx=".. idx .. "&subject=" .. dz.utils.urlEncode(subject)
dz.openURL(url).afterSec(delay)
dz.sendCommand("SendCamera:" .. idx, subject)
copy / paste this into your script directly after your
- execute = function(domoticz, item)
part.
You can call this function with the camera number (default 1), subject (default snapshot_date_time), delay (default 0)
testcommands for this function:
snapshot(nil,"Test default camera index (1) and no delay")
snapshot(1,"Test camera index 1 and no delay")
snapshot(1,"Test camera index 1 and delay of 5 seconds",5)
Posted: Monday 21 January 2019 20:35
by pvklink
Great!
This should be a part of standard dzvents....
It works great!
The only thing i couldn't find was the idx attribute, or a number as ID.
So i used:
Is it possible to use Naam instead of idx? IDX isn't visible, only place to look is in the database ... i think...
Another great improvement for this function is that you can take x pictures after y seconds...:
snapshot(1,"Test camera index 1 and delay of 5 seconds",y,x)
Cam attributes are:
Actief:
Naam:
Protocol:
IP Adres:
Poort:
Gebruikersnaam:
Wachtwoord:
ImageURL:
Posted: Monday 21 January 2019 20:52
by waaren
pvklink wrote: Monday 21 January 2019 20:35
Great!
I will test it...
Thirst question: my cam has no idx attribute, or a number as ID. Cam attributes are:
Actief:
Naam:
Protocol:
IP Adres:
Poort:
Gebruikersnaam:
Wachtwoord:
ImageURL:
Do i use Naam instead of idX?
I am working this but have not found an easy way to use the name. Domoticz internally only accept an idx.
If you use
- http://domoticz_ip:domoticz_port/json.htm?type=cameras
in your browser you will see your cameras including names and id's.
getting this as a native dzVents command is not as easy as l thought, so I would not wait for it
Posted: Monday 21 January 2019 20:55
by pvklink
No problem, it works great for me!
I tried it with: .repeatAfterMin(delay, 5) instead of .afterSec(delay)... this does not work...
Re: dzvents cam screenshot [Solved]
Posted: Tuesday 22 January 2019 2:40
by waaren
pvklink wrote: Monday 21 January 2019 20:55
That command will probably never gets implemented for the snapshot command.
What you could use now is:
local cameraID = 1
local repeats = 5 --- number of repeats
local interval = 11 -- seconds between repeats
for i = 0,(repeats - 1) do
snapshot(cameraID,"Test repeated snapshots (" .. i+1 .."/" .. repeats .. ") of camera with index " .. cameraID ..
". Snap was shot ".. (i * interval) .. " seconds after script finished.", ( i * interval ))
Posted: Tuesday 22 January 2019 23:02
by pvklink
Works perfect!
Thanks again @waaren!
Case closed, next project : a spirit zwaveplus radiator valve.
just installed it, and after 5 minitues it seems to work!
Posted: Wednesday 06 February 2019 17:05
by Gravityz
@Waaren.
i noticed your snapshot feature got implemented.
i also want to take multiple snapshots but i think with the new feature the script can be made a lot easier.
instead of looping just 3(or 5) snapshots after eachother with a delay.
also the local function is replaced by the build in function right!
is this correct or am i missing something.
active = true,
-- de devices die dit script triggeren
devices = {
'PIR sensor'
-- device bevat de info van het device wat de trigger veroorzaakt heeft
-- stuurt een foto als er beweging wordt gedetecteerd en het alarm aan staat.
if (domoticz.devices('PIR sensor').state == 'On' and domoticz.security == domoticz.SECURITY_ARMEDAWAY) then
domoticz.snapshot(1,"beweging snapshot 1")
os.execute("sleep 1")
domoticz.snapshot(1,"beweging snapshot 2")
domoticz.snapshot(1,"beweging snapshot 3")
Posted: Wednesday 06 February 2019 17:26
by waaren
Gravityz wrote: Wednesday 06 February 2019 17:05
I also want to take multiple snapshots but i think with the new feature the script can be made a lot easier.
If you use a recent Beta then the dzVents has indeed a native snapshot command. It can be used like
active = true,
devices = {
'PIR sensor'
if (device.state == 'On' and domoticz.security == domoticz.SECURITY_ARMEDAWAY) then
for i = 0,2 do
domoticz.snapshot(1,"beweging snapshot " .. (i + 1)).afterSec(i)
Posted: Wednesday 06 February 2019 17:30
by Gravityz
nice. tried something similar but could not get it to work. this looks very good.
i wil change my script into that of yours
Posted: Wednesday 06 February 2019 19:02
by hoeby
also take a look to this thread
www.domoticz.com/forum/viewtopic.php?f=59&t=26729
it takes a snapshot from a camera, and places it in a directory on the pi. after that it sends it by telegram.
maybe it helps you to get to the point you are looking for
Posted: Wednesday 06 February 2019 19:18
by Gravityz
thanks. good info
