Page 1 of 2
dzVents: MaxMin Temp and Humidity
Posted: Friday 18 January 2019 16:06
by AYAMY
Some time ago I have posted in the Blocky Board looking for a solution to my problem... Find and send a notification of the lowest and highest temperatures and %humidity in the last 24 hours.
@warren tells me to look towards dzVents to find a how to figure out ... and he suggested me the following solution
-- getMaxTempHum
local httpResponses = "getMaxTempHum"
    on      =   {
                    timer           =   { "at 19:35"    },                       -- Your preferred time
                    httpResponses   =   { httpResponses }
    logging =   {
                    level           =   domoticz.LOG_ERROR,
                    marker          =   httpResponse
    execute = function(dz, item)
        -- ****************************** Your settings below this line ***************************************************
        temphumDevice = dz.devices(766)          -- Replace with ID of Device you want to be notified on
        -- ****************************** No changes required below this line *********************************************
        local extremes = {}
        local function logWrite(str,level)
            dz.log(tostring(str),level or dz.LOG_DEBUG)
        local function triggerJSON()
            local  URLString   = dz.settings['Domoticz url'] .. "/json.htm?type=graph&sensor=temp&range=day&idx=" .. temphumDevice.id
            dz.openURL({    url = URLString,
                            method = "GET",
                            callback = httpResponses })
        local function convertTime(timeString)               -- based on incoming format yyyy-mm-dd hh:mm
            local year, month, day, hour, minute
            _,_, year, month, day, hour, minute = string.find(timeString, "(%d+)-(%d+)-(%d+) (%d+):(%d+)")
            fmtString = os.date("%A, %d %B %Y (%H:%M)",os.time({year=year, month=month, day=day, hour=hour, minute=minute })):gsub(" 0"," ")
            logWrite(fmtString)
            return fmtString                                 -- outgoing format: ddd d mmmm yyyy (hh:mm)
        local function showResult(str)
            textDevice.updateText(str)
            logWrite(str,dz.LOG_FORCE)
        local function getTimeWindow(hours)
            local to   = os.time(os.date("*t"))
            local from = os.date("%A, %d %B %Y (%H:%M)",to - hours * 3600)
            local to   = os.date("%A, %d %B %Y (%H:%M)",to)
            return to, from
        local function notify(from,now)
            local notificationString =  "\nhigh Temperature: " .. extremes.high.temperature .. " Celsius at " .. convertTime(extremes.high.tTime) .. "\n"
            notificationString = notificationString .. "low temperature: " .. extremes.low.temperature .. " Celsius at " .. convertTime(extremes.low.tTime) .. "\n"
            notificationString = notificationString .. "high humidity: " .. extremes.high.humidity .. "% at " .. convertTime(extremes.high.hTime) .. "\n"
            notificationString = notificationString .. "low humidity:  " .. extremes.low.humidity .. "% at " .. convertTime(extremes.low.hTime)
            logWrite("\nExtremes between " .. from .. " and " .. now .. "\n" .. notificationString,dz.LOG_FORCE)
             dz.notify("Extremes between " .. from .. " and " .. now, notificationString, dz.PRIORITY_NORMAL, nil,nil, dz.NSS_PUSHOVER )
        local function getExtremes(rt)
            extremes.low                = {}
            extremes.high               = {}
            extremes.low.temperature    = 10000
            extremes.low.humidity       = 100
            extremes.high.humidity      = 0
            extremes.high.temperature   = -256
            for key in ipairs(rt) do
                if tonumber(rt[key].hu) > extremes.high.humidity then
                    logWrite("New max humidity found on " .. convertTime(rt[key].d) .. " ==>> " .. rt[key].hu )
                    extremes.high.humidity = tonumber(rt[key].hu)
                    extremes.high.hTime = rt[key].d
                if tonumber(rt[key].hu) < extremes.low.humidity then
                    logWrite("New min humidity found on " .. convertTime(rt[key].d) .. " ==>> " .. rt[key].hu )
                    extremes.low.humidity = tonumber(rt[key].hu)
                    extremes.low.hTime = rt[key].d
                if tonumber(rt[key].te) > extremes.high.temperature then
                    logWrite("New max temperature found on " .. convertTime(rt[key].d) .. " ==>> " .. rt[key].te )
                    extremes.high.temperature = tonumber(rt[key].te)
                    extremes.high.tTime = rt[key].d
                if tonumber(rt[key].te) < extremes.low.temperature then
                    logWrite("New min temperature found on " .. convertTime(rt[key].d) .. " ==>> " .. rt[key].te )
                    extremes.low.temperature = tonumber(rt[key].te)
                    extremes.low.tTime = rt[key].d
            return extremes
        -- Main
        if not item.isHTTPResponse then
            triggerJSON()
        elseif item.ok then                                      -- statusCode == 2xx
            extremes = getExtremes(item.json.result)
            notify(getTimeWindow(24))
            logWrite("Could not get (good) data from domoticz. Error (" .. (item.statusCode or 999) .. ")"  ,dz.LOG_ERROR)
            logWrite(item.data)
Code that I have changed as suggested with my idx sensor and time ...
-- getMaxTempHum
    on      =   {
                    timer           =   { "at 11:20"    },                       -- Your preferred time
    logging =   {
        temphumDevice = dz.devices(315)          -- Replace with ID of Device you want to be notified on
        local extremes = {}
                            method = "GET",
            logWrite(fmtString)
            return to, from
            extremes.low                = {}
            extremes.high               = {}
            return extremes
        -- Main
            triggerJSON()
            logWrite(item.data)
I have saved and Enabled the script but at 11:20 I haven't seen any info about temp or humidity... the log only shows
EventSystem: reset all events...
EventSystem: Write file: /home/ubuntu/domoticz/scripts/dzVents/generated_scripts/GETMAXTEMP.lua
Could you help me?
Re: dzVents: MaxMin Temp and Humidity
Posted: Friday 18 January 2019 21:47
by waaren
AYAMY wrote: Friday 18 January 2019 16:06 Code that I have changed as suggested with my idx sensor and time ...
Could you help me?
When I execute the script I receive a notification on pushover and see the following in the domoticz log:
2019-01-18 21:31:01.580  Status: dzVents: !Info:
Extremes between Friday, 18 January 2019 (21:31) and Thursday, 17 January 2019 (21:31)
high Temperature: 4.3 Celsius at Friday, 18 January 2019 (15:00)
low temperature: -3.5 Celsius at Friday, 18 January 2019 (07:00)
high humidity: 100% at Friday, 18 January 2019 (07:00)
low humidity:  74% at Friday, 18 January 2019 (16:00)
2019-01-18 21:31:01.602  Status: Notification: Extremes between Friday, 18 January 2019 (21:31) and Thursday, 17 January 2019 (21:31)
2019-01-18 21:31:01.793  (Youless) YouLess Meter (Youless)
2019-01-18 21:31:03.206  Notification sent (pushover) => Success
When not yet familiar with dzVents please start with reading https://www.domoticz.com/wiki/DzVents:_ ... _Domoticz before implementing.
Special attention please for "In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents disabled' is not checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
For you convenience I set the log level to DEBUG and made the notification subsystem configurable.
-- getMaxTempHum
    on      =   {
                    timer           =   { "at 21:43"    },                       -- Your preferred time
    logging =   {
                    level           =   domoticz.LOG_DEBUG,
                    marker          =   httpResponses
        -- notificationSubsystem   = dz.NSS_PUSHOVER          -- Replace with your subsystem of choice or nil to get a notication on all
        notificationSubsystem   = nil          -- This will cause the script to send a notification to all subsystems
        local extremes = {}
                            method = "GET",
            logWrite(fmtString)
            return to, from
             dz.notify("Extremes between " .. from .. " and " .. now, notificationString, dz.PRIORITY_NORMAL, nil,nil, notificationSubsystem )
            extremes.low                = {}
            extremes.high               = {}
            return extremes
        -- Main
            triggerJSON()
            logWrite(item.data)
Posted: Saturday 19 January 2019 16:39
by AYAMY
thanks for your help..i have used your new code....
and now the script executes but i have a different error....
2019-01-19 16:33:00.437 dzVents: Info: getMaxTempHum: ------ Start internal script: GETMAXTEMP:, trigger: at 16:33
2019-01-19 16:33:00.453 dzVents: Debug: getMaxTempHum: Device-adapter found for Oregon TempHygro Starck Ext: Temperature+humidity device adapter
2019-01-19 16:33:00.458 dzVents: Debug: getMaxTempHum: Processing device-adapter for Oregon TempHygro Starck Ext: Temperature+humidity device adapter
2019-01-19 16:33:00.459 Error: dzVents: Error: getMaxTempHum: An error occured when calling event handler GETMAXTEMP
2019-01-19 16:33:00.459 Error: dzVents: Error: getMaxTempHum: ...omoticz/scripts/dzVents/generated_scripts/GETMAXTEMP.lua:101: attempt to index local 'item' (a nil value)
Posted: Sunday 20 January 2019 0:16
by waaren
AYAMY wrote: Saturday 19 January 2019 16:39 thanks for your help..i have used your new code....
Can you please check again if the copy/ past3 went OK and that you only changed the time and the device number ?
In the version I posted line 101 is triggerJSON()
The error message shows that there is something else now on line 101
If you changed other lines please send me your changed version via PM so I can have a look what caused this error
Posted: Sunday 20 January 2019 11:35
by AYAMY
the code with my changes
-- getMaxTempHum
    on      =   {
                    timer           =   { "at 11:29"    },                       -- Your preferred time
    logging =   {
        local extremes = {}
                            method = "GET",
            logWrite(fmtString)
            return to, from
            extremes.low                = {}
            extremes.high               = {}
            return extremes
        -- Main
            triggerJSON()
            logWrite(item.data)
the log result
2019-01-20 11:29:00.157 dzVents: Info: getMaxTempHum: ------ Start internal script: DzIII:, trigger: at 11:29
2019-01-20 11:29:00.174 dzVents: Debug: getMaxTempHum: Device-adapter found for Oregon TempHygro Starck Ext: Temperature+humidity device adapter
2019-01-20 11:29:00.179 dzVents: Debug: getMaxTempHum: Processing device-adapter for Oregon TempHygro Starck Ext: Temperature+humidity device adapter
2019-01-20 11:29:00.179 Error: dzVents: Error: getMaxTempHum: An error occured when calling event handler DzIII
2019-01-20 11:29:00.179 Error: dzVents: Error: getMaxTempHum: ...ntu/domoticz/scripts/dzVents/generated_scripts/DzIII.lua:100: attempt to index local 'item' (a nil value)
2019-01-20 11:29:00.179 dzVents: Info: getMaxTempHum: ------ Finished DzIII
at line 100 in the event editor inside domoticz i can olny see this...
line100
line100
Posted: Sunday 20 January 2019 18:34
by waaren
AYAMY wrote: Sunday 20 January 2019 11:35 the code with my changes
Strange. I use the exact same code and it works. What is your domoticz / dzVents version ?
And can you change line 100 to
if item.isTimer or item.isDevice then
To see if that does change the behavior ? Thanks
Posted: Monday 21 January 2019 8:55
by AYAMY
I have changed the code to
-- getMaxTempHum
    on      =   {
                    timer           =   { "at 08:53"    },                       -- Your preferred time
    logging =   {
        temphumDevice           = dz.devices(313)          -- Replace with ID of Device you want to be notified on
        local extremes = {}
                            method = "GET",
            logWrite(fmtString)
            return to, from
            extremes.low                = {}
            extremes.high               = {}
            return extremes
        -- Main
        --if not item.isHTTPResponse then
            triggerJSON()
            logWrite(item.data)
and this is the result
2019-01-21 08:53:00.357 dzVents: Info: getMaxTempHum: ------ Start internal script: DzIII:, trigger: at 08:53
2019-01-21 08:53:00.384 dzVents: Debug: getMaxTempHum: Device-adapter found for Imagintronix: Temperature+humidity device adapter
2019-01-21 08:53:00.389 dzVents: Debug: getMaxTempHum: Processing device-adapter for Imagintronix: Temperature+humidity device adapter
2019-01-21 08:53:00.389 Error: dzVents: Error: getMaxTempHum: An error occured when calling event handler DzIII
2019-01-21 08:53:00.389 Error: dzVents: Error: getMaxTempHum: ...ntu/domoticz/scripts/dzVents/generated_scripts/DzIII.lua:101: attempt to index local 'item' (a nil value)
2019-01-21 08:53:00.389 dzVents: Info: getMaxTempHum: ------ Finished DzIII
Thanks for your help @waaren
Posted: Monday 21 January 2019 8:57
by waaren
AYAMY wrote: Monday 21 January 2019 8:55 I have changed the code to
And what versions do you use ?
Posted: Monday 21 January 2019 10:42
by AYAMY
About Domoticz
Version: 3.8153
Build Hash: 494fff7
Compile Date: 2017-07-30 12:19:41
Posted: Monday 21 January 2019 11:01
by waaren
That explains. The script uses functions of dzVents that are not yet available in your version. If you want to use it you need to go to later stable (4.9700) or recent Beta (4.103xx)
And please update your profile to reflect your version. That will save time and frustration.
Posted: Monday 21 January 2019 11:13
by AYAMY
now i have updated ;)
About Domoticz
Version: 4.9700
Build Hash: a3a45906
Compile Date: 2018-06-23 16:24:51
Posted: Monday 21 January 2019 11:33
by AYAMY
thank you thank you thank you thank you @waaren !!!
Now the script run but the ranges of the calculation are incorrect... The Entreme date is today (21 January ) and yesterday (20 January ) but the high\ low temperatures and high\low humidity are of the 16 January 2019 and 14 January 2019
I have to set up the code but thank you it works... now it's only about tuning the code.. ;)))
this is what i have received running the script ;)
Extremes between Monday, 21 January 2019 (11:42) and Sunday, 20 January 2019 (11:42):
high Temperature: 15 Celsius at Wednesday, 16 January 2019 (12:00)
low temperature: 3 Celsius at Wednesday, 16 January 2019 (01:00)
high humidity: 99% at Monday, 14 January 2019 (11:00)
low humidity:  96% at Monday, 14 January 2019 (23:00)
Posted: Monday 21 January 2019 17:40
by waaren
AYAMY wrote: Monday 21 January 2019 11:33 The ranges of the calculation are incorrect... The Entreme date is today (21 January ) and yesterday (20 January ) but the high\ low temperatures and high\low humidity are of the 16 January 2019 and 14 January 2019
Adjusted the script to make the range a configurable amount of hours.
-- getMaxTempHum
    on      =   {
                    timer           =   { "at 17:38"    },                       -- Your preferred time
    logging =   {
        timeSpan                = 24                       -- If set longer then the amount of short log sensors data in domoticz it will look at all data available
        local extremes = {}
                            method = "GET",
        local function convertTime(timeString,check)
            if check then
                local seconds = os.time({year=year, month=month, day=day, hour=hour, minute=minute, seconds=0 })
                return seconds
                local fmtString = os.date("%A, %d %B %Y (%H:%M)",os.time({year=year, month=month, day=day, hour=hour, minute=minute })):gsub(" 0"," ")
            return from, to
            extremes.low                = {}
            extremes.high               = {}
            local sinceTime             = os.time(os.date('*t')) - timeSpan * 3600
                    if convertTime(rt[key].d,true) >  sinceTime then
            return extremes
        -- Main
            triggerJSON()
            notify(getTimeWindow(timeSpan))
            logWrite(item.data)
Posted: Monday 21 January 2019 21:37
by AYAMY
thank you...the script is perfect !!!!! really thank you for your help !!!
Posted: Monday 18 November 2019 16:41
by AYAMY
I have upgraded to Domoticz
Version: 4.10717
Build Hash: b38b49e5
Compile Date: 2019-05-09 13:04:08
dzVents Version: 2.4.19
Python Version: 3.7.3 (default, Apr 3 2019, 05:39:12) [GCC 8.2.0]
and Now the script doesn't run.... it has these errors
2019-11-18 16:37:00.527 Error: dzVents: local netWork not open for dzVents openURL call !
2019-11-18 16:37:00.527 Error: dzVents: check dzVents wiki (look for 'Using dzVents with Domoticz')
Posted: Monday 18 November 2019 19:12
by waaren
AYAMY wrote: Monday 18 November 2019 16:41 I have upgraded to Domoticz
In case you don't have access to the dzVents wiki
Using dzVents.png (54.03 KiB) Viewed 3012 times
Posted: Tuesday 19 November 2019 15:15
by AYAMY
my bad.... sorry....
I have a Fritzbox... and using 192.168.0.* doesn't work ... Fritz releases 192.168.178.* so i have added 192.168.178.* and now it works...
Posted: Saturday 15 August 2020 14:57
by zavjah
this is awesome as it is exactly what I need, but much simpler:
Can someone please help me how can I simplify the script to only get the Information of a highest temp within the last 24h?
Thx a lot,
zavjah
Posted: Saturday 15 August 2020 18:10
by waaren
zavjah wrote: Saturday 15 August 2020 14:57 Hi,
Thx a lot,
zavjah
Remove lines 63-65
            notificationString = notificationString .. "low humidity:  " .. extremes.low.humidity .. "% at " .. convertTime(extremes.low.hTime)/code]
Posted: Saturday 15 August 2020 21:26
by zavjah
Hi waaren,
I was able to "reduce" the script successfully to this:
local MaxTemperature = 'getMaxTemp'
return {on = {timer           =   {'every Minute'},                       -- Your preferred time
              httpResponses   =   { MaxTemperature }
        local tempDevice = dz.devices('Außen')
        local extremes = {}
        if item.isDevice or item.isTimer then
            dz.openURL({    url = 'http://192.168.178.23:8080/json.htm?type=graph&sensor=temp&range=day&idx=' .. tempDevice.idx  .. '&range=day',
                            method = "GET",
                            callback = MaxTemperature })
            return
            extremes.high               = {}
            return extremes
        -- Main
        if item.ok and item.isJSON then
            dz.log('Höchsttemeratur gestern: ' .. extremes.high.temperature .. '°C')
Now, I'd like to combine this with a second script I have for rain level:
local RainLevelTest = 'getRainLevel'
return {on= {
            httpResponses = {RainLevelTest,},
    logging = {level = domoticz.LOG_INFO,}, --LOG_DEBUG, LOG_ERROR, LOG_INFO
        local rainDevice = dz.devices('Regen') -- name enclosed in quotes or number without quotes
        local regenMaenge = 8       -- Wieviel mm Regen braucht es, damti ich NICHT gieße?
        local regenZeitraum = 2     -- Tage vom Zeitpunkt des Skript lauf aus, also heute!
            dz.openURL(
                {url = 'http://192.168.178.23:8080/json.htm?type=graph&sensor=rain&idx=' .. rainDevice.idx .. '&range=day', --&range=day oder &range=week oder &range=month
                 callback = RainLevelTest,
            return
        local function getmm(rt)
            local startDate = (dz.time.addMinutes(-1 * regenZeitraum * 24 * 60)).rawDate
            local mm = 0
            for index, record in ipairs(rt) do
                mm = mm + record.mm
            return mm
-- Main
            dz.log('Regenmenge in den letzten 24h: ' .. getmm(item.json.result) .. 'mm')
            dz.log('Keine valide Antwort von domoticz ',dz.LOG_ERROR)
            dz.log(item,dz.LOG_ERROR)
I lack the knowledge how to do that, I assume I do semthing wrong at "dz.OpebURL"
Can you help, please?
thx,
Zavjah
