Roowifi
Posted: Monday 14 January 2019 0:28
A long time ago I've bought a Roowifi board in order to be able to add my Roomba to Domoticz. I did several attempts to get this working but it seems i'm to stupid for it
When I paste the URL below in chrome I get some response.
http://192.168.178.185/roomba.json
So I thought then it would be easy to use lua with a JSON parser to put some info in Domoticz.
In order to make a start i made the script below.
But all I get is
Can someone point me in the right direction because I'm stuck...
"response": {
"r0": {
"name": "Bumps Wheeldrops",
"value": "0"
"r1": {
"name": "Wall",
"value": "0"
"r2": {
"name": "Cliff Left",
"value": "0"
"r3": {
"name": "Cliff Front Left",
"value": "0"
"r4": {
"name": "Cliff Front Right",
"value": "0"
"r5": {
"name": "Cliff Right",
"value": "0"
"r6": {
"name": "Virtual Wall",
"value": "0"
"r7": {
"name": "Motor Overcurrents",
"value": "0"
"r8": {
"name": "Dirt Detector - Left",
"value": "0"
"r9": {
"name": "Dirt Detector - Right",
"value": "0"
"r10": {
"name": "Remote Opcode",
"value": "0"
"r11": {
"name": "Buttons",
"value": "0"
"r12": {
"name": "Distance",
"value": "0"
"r13": {
"name": "Angle",
"value": "0"
"r14": {
"name": "Charging State",
"value": "0"
"r15": {
"name": "Voltage",
"value": "15888"
"r16": {
"name": "Current",
"value": "-151"
"r17": {
"name": "Temperature",
"value": "22"
"r18": {
"name": "Charge",
"value": "2490"
"r19": {
"name": "Capacity",
"value": "2697"
}In order to make a start i made the script below.
local t1 = os.date("%H") -- get hour time digit
local t2 = os.date("%M") -- get minute time digit
local ROOMBAIP = "192.168.178.185" -- Roomba IP Address
if t1 == "00" and t2 == "20" then -- time to poll
JSON = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- For Linux
--Extract data from roomba.
RoombaJsonURL = 'curl "http://'..ROOMBAIP..'/roomba.json"'
jsondata = assert(io.popen(RoombaJsonURL))
RoombaDevice = jsondata:read('*all')
jsondata:close()
RoombaData = JSON:decode(RoombaDevice)
--RoombaTemperature = jsonData.response.r17
print(" ----- Roomba temperature = " .. RoombaData .. "");
--commandArray={['UpdateDevice']='1609|0|' .. RoombaJson} -- update sensor value
return commandArrayCode: Select all
Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_roomba.lua: /home/pi/domoticz/scripts/lua/script_device_roomba.lua:25: attempt to concatenate global 'RoombaData' (a nil value)
