SDM120C modbus
HilverinkJ
SDM120C modbus
Post by HilverinkJ »
SDM120C ModBus RTU client to read EASTRON SDM smart mini power meter registers
https://github.com/gianfrdp/SDM120C
Can anyone tell me if it is possible to use this with a LAN/RS485 converter?
Joop.
EdddieN
Domoticz version: 4.9700
Re: SDM120C modbus
Post by EdddieN »
11101101 - www.machinon.com
MaikelK
Re: SDM120C modbus
Post by MaikelK »
You can also put it on a ESPEasy unit with the current test branch. It has a plug-in for this unit!
emme
Domoticz version: latest
Re: SDM120C modbus
Post by emme »
I'm using 2 of them
a SDM120 and a SDM120C (C means CLAMP :P the first is hardwired to the phase and count it, the second uses the Clamp) on a espMini-Mega-test branch
I just believi it's...amazing!!!!
please note.. if you want to use 2 on the same bus, you NEED to change ID: then you have to deal with modbus.. my fist time wasn't easy :P :P :P
the modbud plugin cannot suit my needs becase:
1) I've finish the availble USB ports on the PI :P
2) PI is far away from the meter position :P
"We always done this way"
