Not working Energy counter for Xiaomi smart socket on Zigate
pfloryann
Post by pfloryann »
Live energy it's working on Xiaomi smart socket...but do not working Energy Counter...it is remain 0 KW.
In attached image Counter is with red circle, same device with yellow and live energy with green
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5, Gree AC, JBL soundbar, Philips Android Tv
pipiche
Re: Not working Energy counter for Xiaomi smart socket on Zigate
Post by pipiche »
Could you please provide the plugin version you are using ?
I'll have a look this evening at home where I have a Salus plug and a Xiaomi smartplug and are working correctly.
pipiche
Post by pipiche »
@pfloryann , thanks a lot for reporting that issue.
I've created an issue on Github https://github.com/sasu-drooz/Domoticz- ... issues/322
And it is now fixed.
If you update the plugin to Version 4.0.7 it should be back to normal
Just let me know
pfloryann
Post by pfloryann »
Yes is working now after plugin update. Thank you!
pfloryann
Post by pfloryann »
I tested today Energy counter...but the counter is not correct in Utility page...but in device log is correct energy counter. Please check
pipiche
Post by pipiche »
version of Domoticz ? I'm on beta V4.10355 and have similar issue with an other Plug from Salus
pfloryann
Post by pfloryann »
I use 4.9700
pipiche
Post by pipiche »
Could you kindly open an issue on GitHub ?
We can track it: https://github.com/sasu-drooz/Domoticz-Zigate/issues
pfloryann
Post by pfloryann »
I created now on github
pipiche
Post by pipiche »
pipiche
Post by pipiche »
If you can test the latest version o fthe plugin against the beta branch ( git checkout beta) , I would be interested to have your feedbacks
pfloryann
Post by pfloryann »
pipiche wrote: Friday 18 January 2019 13:20 If you can test the latest version o fthe plugin against the beta branch ( git checkout beta) , I would be interested to have your feedbacks
I have tested with the beta version of plugin and with domoticz 4.1 and data counter is wrong, the counter show live energy does not calculate total consumption and in device log he storing the highest level power used.
pipiche
Post by pipiche »
Please could you check with Domoticz forum if it is not the expected behaviour as we are not doing anything fancy in the plugin except providing the instant consumption.
