change Setpoint with delay?
Posted: Friday 11 January 2019 18:03
by renerene
domoticz.devices('SVT Setpoint Normal').updateSetPoint(tempNormalDefault).afterMin(vertraging)
this is not not working; afterMin works probably only with switches:
2019-01-11 18:02:35.590 Status: dzVents: Error (2.4.9): dzSVTThermostaat: ...z/scripts/dzVents/generated_scripts/dzSVTThermostaat.lua:152: attempt to call field 'afterMin' (a nil value)
suggestions?
Re: change Setpoint with delay?
Posted: Friday 11 January 2019 18:20
by waaren
renerene wrote: Friday 11 January 2019 18:03
suggestions?
According to the wiki this should work. Is this a zwave setPoint device ?
If you don't know please insert domoticz.devices('SVT Setpoint Normal').dump() somewhere in the beginning your script and send the complete dump (you find it in the domoticz logfile to me) If you prefer via PM.
Posted: Friday 11 January 2019 19:06
by renerene
it is a 'thermostat Setpoint' dummy switch
Here is the result of .dump():
2019-01-11 19:04:59.961 Status: dzVents: > month: 1
2019-01-11 19:04:59.961 Status: dzVents: > bState: false
2019-01-11 19:04:59.961 Status: dzVents: > setState()
2019-01-11 19:04:59.961 Status: dzVents: > updateCounter()
2019-01-11 19:04:59.961 Status: dzVents: > timedOut: false
2019-01-11 19:04:59.961 Status: dzVents: > idx: 941
2019-01-11 19:04:59.961 Status: dzVents: > description:
2019-01-11 19:04:59.961 Status: dzVents: > _adapters:
2019-01-11 19:04:59.961 Status: dzVents: > 1: Thermostat setpoint device adapter
2019-01-11 19:04:59.961 Status: dzVents: > setVolume()
2019-01-11 19:04:59.961 Status: dzVents: > updateBarometer()
2019-01-11 19:04:59.961 Status: dzVents: > pause()
2019-01-11 19:04:59.961 Status: dzVents: > hardwareId: 23
2019-01-11 19:04:59.961 Status: dzVents: > updateElectricity()
2019-01-11 19:04:59.962 Status: dzVents: > signalLevel: 12
2019-01-11 19:04:59.962 Status: dzVents: > _nValue: 1
2019-01-11 19:04:59.962 Status: dzVents: > switchOn()
2019-01-11 19:04:59.962 Status: dzVents: > id: 941
2019-01-11 19:04:59.962 Status: dzVents: > unit: 4
2019-01-11 19:04:59.962 Status: dzVents: > updateLux()
2019-01-11 19:04:59.962 Status: dzVents: > updateDistance()
2019-01-11 19:04:59.962 Status: dzVents: > _state: 20.5
2019-01-11 19:04:59.962 Status: dzVents: > toggleSwitch()
2019-01-11 19:04:59.962 Status: dzVents: > _data:
2019-01-11 19:04:59.962 Status: dzVents: > data:
2019-01-11 19:04:59.962 Status: dzVents: > hardwareType: Smart Virtual Thermostat
2019-01-11 19:04:59.962 Status: dzVents: > hardwareID: 23
2019-01-11 19:04:59.962 Status: dzVents: > hardwareName: SVT-thermostaat
2019-01-11 19:04:59.962 Status: dzVents: > protected: false
2019-01-11 19:04:59.963 Status: dzVents: > hardwareTypeValue: 94
2019-01-11 19:04:59.963 Status: dzVents: > setPoint: 20.5
2019-01-11 19:04:59.963 Status: dzVents: > icon: override_mini
2019-01-11 19:04:59.963 Status: dzVents: > timedOut: false
2019-01-11 19:04:59.963 Status: dzVents: > lastUpdate: 2019-01-11 19:04:00
2019-01-11 19:04:59.963 Status: dzVents: > switchTypeValue: 0
2019-01-11 19:04:59.963 Status: dzVents: > baseType: device
2019-01-11 19:04:59.963 Status: dzVents: > deviceType: Thermostat
2019-01-11 19:04:59.963 Status: dzVents: > rawData:
2019-01-11 19:04:59.963 Status: dzVents: > 1: 20.5
2019-01-11 19:04:59.963 Status: dzVents: > signalLevel: 12
2019-01-11 19:04:59.963 Status: dzVents: > batteryLevel: 255
2019-01-11 19:04:59.963 Status: dzVents: > changed: false
2019-01-11 19:04:59.963 Status: dzVents: > subType: SetPoint
2019-01-11 19:04:59.963 Status: dzVents: > deviceID: 00170004
2019-01-11 19:04:59.963 Status: dzVents: > id: 941
2019-01-11 19:04:59.963 Status: dzVents: > switchType: On/Off
2019-01-11 19:04:59.964 Status: dzVents: > description:
2019-01-11 19:04:59.964 Status: dzVents: > lastLevel: 0
2019-01-11 19:04:59.964 Status: dzVents: > name: SVT Setpoint Normal
2019-01-11 19:04:59.964 Status: dzVents: > dump()
2019-01-11 19:04:59.964 Status: dzVents: > isVariable: false
2019-01-11 19:04:59.964 Status: dzVents: > updateSetPoint()
Script
domoticz.devices('SVT Setpoint Normal').updateSetPoint(23)
domoticz.devices('SVT Setpoint Normal').updateSetPoint(21).afterMin(2)
Log
2019-01-11 19:19:50.247 Status: dzVents: Debug: dzSVTThermostaat: Constructed timed-command: 23
2019-01-11 19:19:50.247 Status: dzVents: Debug: dzSVTThermostaat: Constructed timed-command: 21
2019-01-11 19:19:50.251 Status: dzVents: Error (2.4.9): dzSVTThermostaat: An error occured when calling event handler dzSVTThermostaat
Posted: Wednesday 16 January 2019 22:46
by waaren
suggestions?
Fixed in latest domoticz beta V4.10360 (dzVents 2.4.10) !
