ESP (Domoticz) with PIR
CoolRemote
Post by CoolRemote »
Hello, Nice to meet you all! I am new to this specific Domoticz forum.
After searching online for connecting a PIR sensor with relay and tamper switch to Domoticz by using ESP easy I found the following video; https://www.youtube.com/watch?v=6dz2qkyayLw. It seems to work, but no explanation at all and the text in the video is too blurry to work out what has been done, apart from that it is another language.
So in simple words there are just mechanical switches that have to interact with Domoticz. The tamper switch, and the NO/NC contacts of the relay in the PIR. This is one of the (4) PIR sensors I would like to use for this: https://www.google.com/url?sa=i&source= ... 4014665970
Is there someone on this forum who knows how to connect this physical to the Raspberry PI and used it with Domoticz/ESP Easy?
FullThrottleDK
Re: ESP (Domoticz) with PIR
Post by FullThrottleDK »
Hi CoolRemote.
So, do you have programmed the ESP easy with rules and all, and just need the connection from the ESP to Domoticz?
