Domoticz does not restart after being killed on Raspbian (stretch)
Posted: Wednesday 09 January 2019 16:21
Clean install of Domoticz V4.9700 on Raspbian Stretch Lite on Raspberry Pi 2.
No Domoticz database restored.
It seems that Domoticz does not restart after being killed with a kill command on Raspbian (stretch).
After starting Domoticz the status is "active (exited)" instead of "active (running)" as it should be.
After rebooting the system Domoticz can be started again.
See below.
For reference.
This does work on Raspbian (wheezy).
See below.
Is this a bug?
Successful Domoticz restart on Raspbian (stretch):
Unsuccessful Domoticz restart on Raspbian (stretch) using kill command:
Successful Domoticz restart on Raspbian (wheezy):
Successful Domoticz restart on Raspbian (wheezy) using kill command:
See below.
For reference.
See below.
Is this a bug?
pi@raspberrypi:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
pi@raspberrypi:~ $ sudo /etc/init.d/domoticz.sh status
● domoticz.service - LSB: Home Automation System
Loaded: loaded (/etc/init.d/domoticz.sh; generated; vendor preset: enabled)
Active: active (running) since Wed 2019-01-09 15:36:59 CET; 5min ago
Docs: man:systemd-sysv-generator(8)
Process: 360 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
CGroup: /system.slice/domoticz.service
└─367 /home/pi/domoticz/domoticz -daemon -www 8080 -sslwww 443
Jan 09 15:36:58 raspberrypi systemd[1]: Starting LSB: Home Automation System...
Jan 09 15:36:59 raspberrypi domoticz.sh[360]: 2019-01-09 15:36:59.300 Status: Domoticz V4.9700 (c)2012-2018 GizMoCuz
Jan 09 15:36:59 raspberrypi domoticz.sh[360]: 2019-01-09 15:36:59.308 Status: Build Hash: a3a45906, Date: 2018-06-23 16:24:51
Jan 09 15:36:59 raspberrypi domoticz.sh[360]: 2019-01-09 15:36:59.317 Status: Startup Path: /home/pi/domoticz/
Jan 09 15:36:59 raspberrypi domoticz.sh[360]: domoticz: Domoticz is starting up....
Jan 09 15:36:59 raspberrypi domoticz[366]: Domoticz is starting up....
Jan 09 15:36:59 raspberrypi domoticz[367]: Domoticz running...
Jan 09 15:36:59 raspberrypi systemd[1]: Started LSB: Home Automation System.
pi@raspberrypi:~ $ sudo /etc/init.d/domoticz.sh stop
[ ok ] Stopping domoticz.sh (via systemctl): domoticz.service.
Active: inactive (dead) since Wed 2019-01-09 15:43:10 CET; 9s ago
Process: 531 ExecStop=/etc/init.d/domoticz.sh stop (code=exited, status=0/SUCCESS)
Jan 09 15:43:08 raspberrypi systemd[1]: Stopping LSB: Home Automation System...
Jan 09 15:43:08 raspberrypi domoticz[367]: Domoticz is exiting...
Jan 09 15:43:10 raspberrypi domoticz[367]: Domoticz stopped...
Jan 09 15:43:10 raspberrypi systemd[1]: Stopped LSB: Home Automation System.
pi@raspberrypi:~ $ sudo /etc/init.d/domoticz.sh start
[ ok ] Starting domoticz.sh (via systemctl): domoticz.service.
Active: active (running) since Wed 2019-01-09 15:43:22 CET; 10s ago
Process: 587 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
└─594 /home/pi/domoticz/domoticz -daemon -www 8080 -sslwww 443
Jan 09 15:43:22 raspberrypi systemd[1]: Starting LSB: Home Automation System...
Jan 09 15:43:22 raspberrypi domoticz.sh[587]: 2019-01-09 15:43:22.826 Status: Domoticz V4.9700 (c)2012-2018 GizMoCuz
Jan 09 15:43:22 raspberrypi domoticz.sh[587]: 2019-01-09 15:43:22.827 Status: Build Hash: a3a45906, Date: 2018-06-23 16:24:51
Jan 09 15:43:22 raspberrypi domoticz.sh[587]: 2019-01-09 15:43:22.828 Status: Startup Path: /home/pi/domoticz/
Jan 09 15:43:22 raspberrypi domoticz.sh[587]: domoticz: Domoticz is starting up....
Jan 09 15:43:22 raspberrypi domoticz[594]: Domoticz running...
Jan 09 15:43:22 raspberrypi systemd[1]: Started LSB: Home Automation System.Code: Select all
pi@raspberrypi:~ $ ps -ef | grep domo
root 594 1 0 15:43 ? 00:00:00 /home/pi/domoticz/domoticz -daemon -www 8080 -sslwww 443
pi 660 466 0 15:43 pts/0 00:00:00 grep --color=auto domo
pi@raspberrypi:~ $ sudo kill 594
Active: active (exited) since Wed 2019-01-09 15:43:22 CET; 35s ago
Jan 09 15:43:50 raspberrypi domoticz[594]: Domoticz is exiting...
Jan 09 15:43:53 raspberrypi domoticz[594]: Domoticz stopped...
pi 726 466 0 15:44 pts/0 00:00:00 grep --color=auto domo
Active: active (exited) since Wed 2019-01-09 15:43:22 CET; 1min 12s ago
pi@raspberrypi:~ $Code: Select all
pi@raspberrypi ~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 7 (wheezy)"
VERSION_ID="7"
VERSION="7 (wheezy)"
ID=raspbian
ID_LIKE=debian
ANSI_COLOR="1;31"
pi@raspberrypi ~ $ sudo /etc/init.d/domoticz.sh status
[ ok ] domoticz is running.
pi@raspberrypi ~ $ sudo /etc/init.d/domoticz.sh stop
[FAIL] domoticz is not running ... failed!
pi@raspberrypi ~ $ sudo /etc/init.d/domoticz.sh start
2019-01-09 15:57:57.612 Status: Domoticz V4.9700 (c)2012-2018 GizMoCuz
2019-01-09 15:57:57.612 Status: Build Hash: a3a45906, Date: 2018-06-23 16:24:51
2019-01-09 15:57:57.613 Status: System: Raspberry Pi
2019-01-09 15:57:57.613 Status: Startup Path: /home/pi/domoticz/
[ ok ] domoticz is running.Code: Select all
pi@raspberrypi ~ $ ps -ef | grep domo
root 5301 1 1 15:57 ? 00:00:00 /home/pi/domoticz/domoticz -daemon -www 8080 -sslwww 443
pi 5375 5032 0 15:58 pts/0 00:00:00 grep --color=auto domo
pi@raspberrypi ~ $ sudo kill 5301
2019-01-09 15:58:42.773 Status: Domoticz V4.9700 (c)2012-2018 GizMoCuz
2019-01-09 15:58:42.773 Status: Build Hash: a3a45906, Date: 2018-06-23 16:24:51
2019-01-09 15:58:42.774 Status: System: Raspberry Pi
2019-01-09 15:58:42.774 Status: Startup Path: /home/pi/domoticz/
pi@raspberrypi ~ $
