IKEA Tradfri remote (E1524) not pairing with Zigate
pfloryann
- Domoticz version: 2026.3
I tried to pair IKEA Tradfri remote (E1524) with Zigate and show me in log:
2019-01-08 20:11:37.245 Status: (Zigate) [0] NEW OBJECT: 4975 Device Annouce
2019-01-08 20:11:41.509 Status: (Zigate) [0] NEW OBJECT: 4975 Device Annouce
2019-01-08 20:11:48.357 Status: (Zigate) [0] NEW OBJECT: 4975 Device Annouce
2019-01-08 20:11:52.534 Status: (Zigate) [0] NEW OBJECT: 4975 Device Annouce
2019-01-08 20:11:52.737 Status: (Zigate) [0] NEW OBJECT: 4975 Device Annouce
and remain with this message...domoticz show button (dimmer) in devices list but when i push the button from Ikea remote not working...not changing status and not record command in domoticz log. I want to create an domoticz event with this remote to power on the bulb...
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5, Gree AC, JBL soundbar, Philips Android Tv
Re: IKEA Tradfri remote (E1524) not pairing with Zigate
Could you kindly provide the file DeviceList-xx.txt
What version of plugin are you using ?
pfloryann
How how can i save the file Devicelist-xx.txt ?pipiche wrote: Friday 11 January 2019 13:15 Could you kindly provide the file DeviceList-xx.txt
I have last version of plugin (i think) because i installed zigate this week...but i don't know how can i check the plugin version please tell me how...i'm new with these.
Thank You
Please check in the folder where you have installed the plugin modules,
...../domoticz/plugin/Domoticz-Zigate
Here you should have a file name DeviceList-xx.txt ( where xx is a number between 01 to 99 )
It would be great if you could also attached the domoticz log file, so we can see the full logs
pfloryann
I attached the devicelist .txt ...and from domoticz log all about Ikea Remote :pipiche wrote: Saturday 12 January 2019 12:55 Please check in the folder where you have installed the plugin modules,
2019-01-12 22:20:56.347 Status: (Zigate) Permit Join is On
2019-01-12 22:21:31.269 Status: (Zigate) [0] NEW OBJECT: e42a Device Annouce
2019-01-12 22:21:31.273 Status: (Zigate) NetworkID : e42a is replacing 11ca and is attached to IEEE : 90fd9ffffef4e66a
2019-01-12 22:21:35.448 Status: (Zigate) [0] NEW OBJECT: e42a Device Annouce
2019-01-12 22:21:35.653 Status: (Zigate) [0] NEW OBJECT: e42a Device Annouce
Thx
- DeviceList-5.txt
- (8.37 KiB) Downloaded 98 times
Last edited by pfloryann on Saturday 12 January 2019 21:27, edited 1 time in total.
pfloryann
I have edited the previous post were i have added new domoticz logs.
I use plugin version 4.0.6 version
From the DeviceList I can identified you have already:
- TRADFRI bulb E27 WS opal 980lm already added. Is that the case ? Or is that the one you want to add ?
As the log file, I'm also interested on other information which could help to make the right diagnostic
If the case is that this Bulb is the one you want to add , it looks like it has been added and probably has been removed from Domoticz, but not from the plugin. If that is the case. You must do the following:
(1) Make sure the device is not in Domoticz
(2) Stop Domoticz
(3) Edit the DeviceList-5.txt
(4) Remove the line :
(5) Save the file
(6) Restart Domoticz with Permit To join
Then you should be able to pair the Bulb by just switching Off and On the Bulb
(2) Stop Domoticz
34d1 : {'MacCapa': '8e', 'Model': 'TRADFRI bulb E27 WS opal 980lm', 'ColorInfos': {'X': '30138', 'ColorMode': 2, 'Y': '26909', 'ColorTemperatureMireds': '370'}, 'ZDeviceID': '0220', 'Manufacturer': '117c', 'IEEE': '90fd9ffffef2539b', 'Heartbeat': '5037', 'ProfileID': 'c05e', 'App Version': '17', 'Battery': {}, 'HW Version': '1', 'DeviceType': 'FFD', 'Stamp': {'MsgType': '8102', 'Time': '2019-01-10 23:49:16'}, 'RSSI': 138, 'Version': '3', 'ReceiveOnIdle': 'On', 'ReadAttributes': {'Ep': {'01': {'0000': {'0007': '00', '0005': '00', '0004': '00', '0002': '00', '0003': '00', '0001': '00', '0010': '86'}, '0300': {'0000': '86', '0006': '86', '0007': '00', '0005': '86', '0004': '00', '0003': '00', '0001': '86', '0008': '00'}, '0001': {'0000': '86', '0021': '86', '0007': '86', '0005': '86', '0004': '86', '0002': '86', '0003': '86', '0001': '86', '0006': '86', '0020': '86'}}}}, 'Status': 'inDB', 'SQN': {}, 'RIA': '1', 'PowerSource': 'Main', 'NbEp': '1', 'Type': 'ColorControl/Switch/LvlControl/', 'ConfigureReporting': {'Ep': {'01': {'0005': '', '0000': {}, '0006': '00', '0b05': {}, '0004': {}, '0300': '00', '0003': {}, '0019': {}, '1000': {}, '0008': '00', '0020': {}}}}, 'Stack Version': '87', 'LogicalType': 'Router', 'Ep': {'01': {'0000': {}, '0005': {}, '0004': {}, 'ClusterType': {'46': 'ColorControl'}, '0019': {}, '0008': {}, '1000': {}, '0006': '01', '0003': {}, '0300': {}, '0b05': {}, '0020': {}}}}(6) Restart Domoticz with Permit To join
In case you wanted to add a new Bulb ( a second one) then I need the Log the extract is not helpfull)
pfloryann
The TRADFRI bulb E27 WS is another device and it's working...Ikea remote...i think it;s not registered in Zigate device list...but in domoticz device list is diplayed with this id "90fd9ffffef4e66a". Anyway when i push any button from ikea remote in domoticz log...does not show anything...no error...no command..nothingpipiche wrote: Saturday 12 January 2019 21:28 In case you wanted to add a new Bulb ( a second one) then I need the Log the extract is not helpfull)
Ok, sorry didn't understand the issue at start.
The Remote is indeed correctly pair and in the DeviceList-5.txt, but there is no device created (if created it is indeed useless ) on the Domoticz side and that is expected.
So what you can do is you can pilot your bulb either with the Remote or with Domoticz, nothing else at that time.
pfloryann
The bulb is registered and working with domoticz...but i want to create an event in domoticz to control the bulb with this Ikea Remote. I create event but not working...it's working only if i push the button in domoticz...when i push from remote...is not working and not change the status in domoticz. I think the remote is not registered in zigate and that's the problem
If you want you can control the bulb with the remote.
To do that you need to bring the remote closed to the bulb and press the button for few seconds until the bulb dim a bit.
Then you can switch on/off , dim . And then Domoticz via the plugin should see the changes and do if your script is watching bulb changes it should see it
pfloryann
Doesn't work...if i pairing bulb with remote ..i can't switch the bulb from domoticz...if i pairing the bulb with zigate i can't control from remote...that's why I want to create an domoticz event ...because is the only one solution
See here : https://faire-ca-soi-meme.fr/domotique/ ... oler-tous/
(1) Paire the Bulb to Zigate
(2) Pair the Remote to Zigate
(3) Associate the Remote with the Bulb
I'm doing it at home it work very well, I can even pair the remote with 2 Bulb
We are talking about a Ikea Tradfri remote, correct ?
PS/ For the group part, this is now available on the beta branch of the plugin
pfloryann
It's working now Thank you very much!
But if i want to control another device (not ikea) with domoticz event and with this Remote...will be available soon?
This is more a Zigate topic, which is currently under discussion and under work, but don't know if we will get a positive signpfloryann wrote: Saturday 12 January 2019 22:49 But if i want to control another device (not ikea) with domoticz event and with this Remote...will be available soon?
Zigate frirmware 3.0f and Plugin pre-4.1 is able to manage the IKEA TRadfri remote throughg groups.
In such we get all Remote event on Domoticz and then you can do what every you want .
More infos on: https://github.com/sasu-drooz/Domoticz- ... Management
pfloryann
I updated my zigate to 3.0f and plugin to pre-4.1. Now i want to know if this objects groups can be created from domoticz...or i must to create manually file Conf/ZigateGroupsConfig-xx.txt. In domoticz zigate Group Mngt tab ...the list is empty and i haven't add group button.
Please have a look to the Wiki, I think everything is detailed. Now if something is not understandable, please let us know .
But in short, You must create manual the file Conf/ZigateGroupsConfig-xx.txt; and the domoticz group management tab will remain empty.
