Can't delete device
Posted: Wednesday 09 January 2019 0:21
by DoMoney
Hi, I have several questions:
1. I have created Broadlink discovery device, now I can't delete it, the browser is freezing. Please advice, if I can't delete such information from some file?
2. After deleting some z wave devices, I still can see some sub devices at the tab of devices, is it possible to remove it permanently?
Re: Can't delete device
Posted: Thursday 10 January 2019 15:08
by RR46
Regarding #2, could you explain where do you delete these devices?
In tab devices (/all) you can select several devices and delete them...
Posted: Saturday 16 February 2019 18:20
by watanders
I have a Broadlink RM mini3 Wi-Fi IR remote controller
- there are no devices created
- apart from 'start' there is no info in the log file (even though I set log level to debug)
2019-02-16 18:14:26.500 Status: (infraroodWoonkamer) Entering work loop.
2019-02-16 18:14:26.501 Status: (infraroodWoonkamer) Initialized version 4.1.0, author 'zak45'
[/code]- when trying to delete domoticz hangs (website unresponsive, no CPU usage)
- I could create a new discovery Broadlink device, but now I have 2 broadlink devices I cannot remove
Note the device works fine from the (iPhone) app
Posted: Saturday 16 February 2019 19:51
by DutchHans
I've posted several times that the browser hangs (no port 8080 nor 443 ) when deleting devices.. either via the devicestab or via a json command...
No replies at all... I thought I was the only one with this problem
Posted: Sunday 17 February 2019 17:19
by watanders
Update: I have been able to remove both devices:
- under 'hardware' select the troublesome device
- set enabled to 'red' (=disabled)
- press 'update'
Then domoticz hang, but when i restarted it, I was able to delete the device!
this worked for the second device too
Posted: Sunday 17 February 2019 17:25
by DutchHans
With all do respect... That is not a solution..
I hope the developers read this post...
There is something wrong in the delete-commands.. it sometimes works from the devices-tab.. and sometimes via a JSON command.. but its far from reliable.
Regards, Hans
Posted: Tuesday 24 November 2020 18:38
by wkossen
well, i had the same problem today with the Pinger plugin.
hangs when deleting. i manually removed the devices it created, but still the hardware made domoticz hang on removal. I followed your 'no-solution-method' and that worked to get the Pinger out. but i agree, that is not a solution. Apparently this problem is still present in the current stable branche, or somehow has returned. It's been almost 2 years from your last post.... weird but true...
