Python plugin : no device added
julien92
Domoticz version: 4.9701
Post by julien92 »
This is my very first post here :)
I would like to manage my Denon CEOL N9 through Domoticz (installed on a Rpi).
For this, I followed this tutorial :
https://www.domoticz.com/wiki/Python_Plugin_Manager
I've then clicked on Setup > Hardware > I entered a name > in type, I selected "Denon/Marrantz"
Then cliked "Add" and "Update"
I then stopped / started the Domoticz service.
But the issue I encounter is that when I check into Setup > Devices, there is no new device added... :?
I've tried with any other plugin, which each time leads to the same result : nothing in the "Devices" menu.
I should have made something wrong but cannot figure out what...
Could you please help me to solve this issue?
Thanks a lot in advance! :)
Julien
MikeF
Domoticz version: V2022.2
Re: Python plugin : no device added
Post by MikeF »
Have you ticked 'Accept new devices Allow for 5 minutes' in Setup > Settings?
julien92
Post by julien92 »
The "Accept new Hardware Devices" was already active.
I've just tried this :
- click on "Alllow for 5 mintutes"
- reproduce the new hardware creation through the Python Plugin Manager
But same result :(
Dnpwwo
Post by Dnpwwo »
@julien92,
Can you turn debugging on for the plugin (should be a drop down for it on the Hardware page) and post the resulting log entries?
The Denon plugin supports controlling amplifiers via a telnet API. In recent years Denon have moved away from it so you amp may not be supported, the debug log may show that
julien92
Post by julien92 »
@Dnpwwo,
Thanks for your reply.
I think the issue is rather related to the Python plugin, as I get the exact same issue with any other plugin I try to add.
Neverthless, I've managed to add the Denon/Marrantz plugin easily by following this :
https://github.com/dnpwwo/Domoticz-Denon-Plugin
(thanks a lot for all your work! :)
Once the plugin installed and Domoticz restarted, the new hardware is present into the available hardwares.
I then fill in the IP address of my amp, set the debug logs and click Add.
This created 3 switches.
Nevertheless, it seems the connection is lost for each of them.
I've added the DEBUG logs attached.
Do you have any idea what could be the problem?
I don't think this is related to my amp, as I've managed to add it flawlessly within Opehab2 (which I don't like very much, appart from that).
Thank you very much in advance! :)
Julien
DEBUG logs DENON.txt
(13.03 KiB) Downloaded 61 times
