Console for lua/dzvents
DAVIZINHO
Post by DAVIZINHO »
My idea es have a "console" or something similar to put one lua command and test it.
In some case i want to test a command because i dont know if works fine or not and i must create a "test script"; with this idea you can use the console to test it and view the results.
its posible?, do you see usefull like me?
thanks!
Re: Console for lua/dzvents
DAVIZINHO wrote: Thursday 03 January 2019 14:09 My idea es have a "console" or something similar to put one lua command and test it.
its possible?, do you see useful like me?
If you refer to a standard Lua command you can try it on the Command Line Interface. Install Lua if not already done (sudo apt-get install lua5.2),
type lua from the prompt and you are in the Lua command interpreter. Here you can test all commands ( but you won't have the data (structures) available from the domoticz instance)
Could this console help you ?
DAVIZINHO
Post by DAVIZINHO »
waaren wrote: Friday 04 January 2019 21:16
Wow, great!!
thanks a lot!
