Hi all
i am trying to add my nest thermostat E to domoticz.
followed the NestDeveloperApiKey and that part seems to work fine.
but, domoticz is unable to find my thermostat. is it supported?
this is the log:
2019-01-02 15:17:16.828 Status: NestOAuthAPI: Worker started...
2019-01-02 15:17:20.390 (RFXCOM) Temp (Temperatuur kamer iris)
2019-01-02 15:17:20.789 (RFXCOM) Temp + Humidity (Temperatuur studeerkamer)
2019-01-02 15:17:21.829 NestOAuthAPI: Trying to access API on https://developer-api.nest.com/structures.json?auth=.......
2019-01-02 15:17:23.839 NestOAuthAPI: Access token appears to be valid.
2019-01-02 15:17:23.839 NestOAuthAPI: Login success. Token successfully validated.
2019-01-02 15:17:28.165 Error: NestOAuthAPI: request not successful 1 (no thermostat or protect was received), restarting..!
Nest hermostat E
plantjes
- Domoticz version: 3.5877
Re: Nest hermostat E
Did you find any solution yet?
jbackes
Nope. There is no solution yet unfortunately.
Turns out that when you have the EU version, the heatlink from the thermostat E is excluded from the API. See here
https://developers.nest.com/reference/api-thermostat
They say they are restructuring the API now. Maybe after that it will be supported but no one confirmed this and still no news
