hello ,
i'm using a new GUI which is build in HTML5 and use MQTT websockets to dialog beetween Monitor (new GUI) and Domoticz .
My MQTT server is implemented with Mosquitto and is running on the same machin than domoticz.
I use give ordre to my domoticz with IFTTT (Google or amazon doesn't mind) which start some http request (webhooks) and in some scenario with ifttt maker to trigger some foreign devices not supported by domoticz but known by IFTTT (Tahoma SOMFY IO-homecontrol protocol).
My problem is :
when i start MQTT with websockets protocol, then all my ITFFF webhooks request (HTTP order) doesn't run anymore (nothing is received on domoticz log) but IFTTT answer that the order is preformed with the response world parametered.
is there a solution to fix this conflict ?
thanks
conflict with MQTT websockets and IFTTT
