global_data and matchrule
Posted: Tuesday 01 January 2019 20:33
by poudenes
Hi All,
I want add some match rules into my global_data:
domoticz.time.matchesRule 'on 01/12-05/01'
domoticz.time.matchesRule 'on 23/10-4/11'
domoticz.time.matchesRule 'on 11/05,19/08'
I tried follow to add them:
xmas = function(domoticz)
        end,
        halloween = function(domoticz)
        end,
        bday = function(domoticz)
        end,
and in my script tried to use:
-- HALLOWEEN
    if (domoticz.devices(TEST).active) then
        if (domoticz.helpers.halloween(domoticz)) then
            domoticz.helpers.RGB(domoticz,BulbDressoirAll,100,'Blue',nil)
-- X-MAS
       elseif (domoticz.helpers.xmas(domoticz)) then
            domoticz.helpers.RGB(domoticz,BulbDressoirAll,100,'White',nil)
-- REST VAN JAAR
            domoticz.helpers.Kelvin(domoticz,BulbDressoirAll,nil,4000,nil)
        domoticz.helpers.TurnOff(domoticz,BulbDressoirAll,nil,nil)
Changed some thing as well, but what i do i cant let it work.
Reason i want use helpers in a IF statement is when i need change the dates (and it will if my partner complain about the light color etc) then i only need them to change in global_data and all the script that use the helpers will automatic use the new value...
Re: global_data and matchrule
Posted: Tuesday 01 January 2019 21:55
by waaren
poudenes wrote: Tuesday 01 January 2019 20:33 I want add some match rules into my global_data:
Hope this helps ( I use "dz" everywhere possible where I refer to "domoticz" )
global_data.lua
-- global_data.lua
        data = {
		                domoticzLocation                        = { initial = "Nederland" },
	helpers =   {
                    xmas = function(dz)
                        return dz.time.matchesRule('on 01/12-05/01')
                    end,
                    halloween = function(dz)
                        return dz.time.matchesRule('on 23/10-4/11')
                    end,
                    birthday = function(dz)
                        return dz.time.matchesRule('on 11/5,19/8')
                    end,
script
    on      =   {   timer =  {"every minute" }},
    logging =   {   level   =   domoticz.LOG_DEBUG,
                    marker  =   "helper"               },
    execute = function(dz, item)
        local function logWrite(str,level)
            dz.log(tostring(str),level or dz.LOG_DEBUG)
        logWrite("Return value from helper function X-mas     = ".. tostring(dz.helpers.xmas(dz)))
        logWrite("Return value from helper function Halloween = ".. tostring(dz.helpers.halloween(dz)))
        logWrite("Return value from helper function birthday  = ".. tostring(dz.helpers.birthday(dz)))
        -- HALLOWEEN
        if dz.helpers.halloween(dz)  then
            dz.helpers.RGB(dz,BulbDressoirAll,100,'Blue',nil)
        -- X-MAS
        elseif dz.helpers.xmas(dz) then
            dz.helpers.RGB(dz,BulbDressoirAll,100,'White',nil)
       -- REST VAN JAAR
            dz.helpers.Kelvin(dz,BulbDressoirAll,nil,4000,nil)
Posted: Wednesday 02 January 2019 8:03
by poudenes
Thanks. When I'm home after cremation ceremony of my mom today I will try this. Playing with script can clear my head a lot at the moment.
Verzonden vanaf mijn iPhone met Tapatalk Pro
Posted: Wednesday 02 January 2019 14:53
by poudenes
It work!! Thanks
