Page 1 of 2
Get energy consumption (and more) from EV charger
Posted: Tuesday 01 January 2019 19:57
by azzilla
New member so be kind
I have a EV charger from Garo (GLBMMN-T222WO) that has a web gui which has all sorts of information about energy consumption, connector status and so on.
I contacted the manufacurer and asked if there is an api that i could pull data from but there wasn't, i also got a tone of "don't meddle with our stuff" from the support rep.
I managed to find a specific url when i looked in the browser console that pulls a status.json file.
It looks like this.
What i would like to be able to do is. If possible that is?
- Status from "connector" translated to a virtual sensor so i can get a notification to my phone when it disconnects/connects. There have been an increase in cables being stolen in my area and i want to at least try to prevent it. They are effin expensive.
- Status from "currentChargingPower" translated to a virtual sensor so i can monitor the wattage of the charger.
If anyone can point me in the right direction or better, help me set this up i would appreciate it so much. I am really bummed about the choice of EV Charger but i hope i can make it somewhat smarter with this solution.
Re: Get energy consumption (and more) from EV charger
Posted: Tuesday 01 January 2019 20:40
by waaren
azzilla wrote: Tuesday 01 January 2019 19:57
I have a EV charger from Garo (GLBMMN-T222WO).
Please share the exact url and the raw JSON return and also the notification app you use from domoticz to your mobile.
With that information a dzVents script can be created that stores the information in a virtual alert sensor and a virtual electric usage device.
Posted: Tuesday 01 January 2019 21:02
by azzilla
waaren wrote: Tuesday 01 January 2019 20:40
The link
http://192.168.1.15:2222/rest/chargebox ... 6334042114
The json info
"ocppState": null,
"freeCharging": false,
"ocppConnectionState": null,
"connector": "NOT_CONNECTED",
"mode": "ALWAYS_OFF",
"currentLimit": 32,
"factoryCurrentLimit": 32,
"switchCurrentLimit": 32,
"powerMode": "OFF",
"currentChargingCurrent": 0,
"currentChargingPower": 0,
"accSessionEnergy": 0,
"latestReading": 57000,
"currentTemperature": 11,
"pilotLevel": 0,
"sessionStartValue": 57000,
"nrOfPhases": 1
I use Prowl. Do you also need the API key or should i fill this in myself?
Thanks a bunch for your help!
Posted: Tuesday 01 January 2019 22:00
by waaren
azzilla wrote: Tuesday 01 January 2019 21:02
I will have a look and assume you configured Prowl in domoticz already. I will use that in the script, so no need to share your api key.
Posted: Wednesday 02 January 2019 3:03
by waaren
I have a EV charger from Garo (GLBMMN-T222WO) that has a web gui which has all sorts of information about energy consumption, connector status and so on. I managed to find a specific url when i looked in the browser console that pulls a status.json file.
Please start with reading the
required setup steps for dzVents.
Also
this Quickstart is very useful to get a basic understanding of dzVents Lua for domoticz.
I could not test everything because I don't own this device and I don't use prowl as notification system but what I could test works.
More explanation is in the comments inside the script. Please feel free to ask for clarification if things are not clear or when you encounter problems.
PS. Please update your profile with the version you use. Thx
have Fun !
-- Garo EV charger
Create dummy hardware ( https://www.domoticz.com/wiki/Hardware_Setup#Dummy_Hardware )
Create two virtual devices on the dummy hardware ( https://www.domoticz.com/wiki/Virtual_meter )
1. Alert Device
2. Electric (instant and counter)
modify names in lines between -- +++++++++
local callBack = "GaroCharger"
timer = { "every minute" }, -- when freq changed, energy total calc. must be modified as well (search for 60 in this script)
httpResponses = { callBack },
logging = {
level = domoticz.LOG_DEBUG,
marker = "Garo EV charger"
data = { notificationSend = { initial = false },
message = { initial = "" },
timeSend = { initial = "not yet" },
execute = function(dz,item)
-- ++++++++++++++++ Enter your setting between these lines +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
local testMode = false -- set to false when live
local alert = dz.devices("garo Alert") -- Change to the name you use for this device
local power = dz.devices("garo Power") -- Change to the name you use for this device
local notificationResetTime = "09:00" -- Set time at when you want the notication to repeat when still not Connected
local myNotificationTable = { -- table with one or more notification systems.
-- Can be one or more of them
-- Remove "--" in front of all notification systems you want to use
-- dz.NSS_GOOGLE_CLOUD_MESSAGING,
dz.NSS_PUSHOVER,
-- dz.NSS_HTTP,
-- dz.NSS_KODI,
-- dz.NSS_LOGITECH_MEDIASERVER,
-- dz.NSS_NMA,
dz.NSS_PROWL,
-- dz.NSS_PUSHALOT,
-- dz.NSS_PUSHBULLET,
-- dz.NSS_PUSHOVER,
-- dz.NSS_PUSHSAFER,
-- ++++++++++++++++ No modification should be needed below this line +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
local alertLevel = dz.ALERTLEVEL_GREEN
local connectionOK = "CONNECTED"
local testData = '{"ocppState": null,"connector": "CONNECTED","mode": "ALWAYS_OFF","currentChargingPower": 2227.1}' -- not used when live
local repeatNotification = dz.time.matchesRule("at " .. notificationResetTime) and alert.color == dz.ALERTLEVEL_RED
-- output to domoticz log
local function logWrite(str,level)
dz.log(tostring(str),level or dz.LOG_DEBUG)
logWrite ("triggered by " .. item.trigger)
-- call the url to get the JSON
local function getJSON()
local url = "http://192.168.1.15:2222/rest/chargebox/status?_=1546334042114"
if testMode then
url = dz.settings['Domoticz url'] .. "/json.htm?type=command¶m=addlogmessage&message=ChargeBox_test"
dz.openURL({ url = url,
method = "GET",
callback = callBack })
-- convert json data to Lua table
local function json2Table()
if testMode then
return dz.utils.fromJSON(testData)
return dz.utils.fromJSON(item.data)
-- Get the relevant fields
local function extractFields(t)
return t.connector,t.currentChargingPower
local function updatePersistentData(val,message)
dz.data.notificationSend = val
if val then
dz.data.timeSend = dz.time.raw
dz.data.message = message
-- send notification to all systems active and in myNotificationTable when status changed or once a day
local function notify(message, forced)
if forced or not dz.data.notificationSend then
dz.notify("Garo charger", message, dz.PRIORITY_NORMAL, dz.SOUND_INTERMISSION, "", myNotificationTable )
updatePersistentData(true,message)
-- Update devices when needed
local function fillDevices(connected, Power)
local changed = false
if alert.text ~= connected then
changed = true
if connected ~= connectionOK then
alertLevel = dz.ALERTLEVEL_RED
alert.updateAlertSensor(alertLevel, connected)
updatePersistentData(false)
energy = power.WhTotal + Power / 60 -- if you change the frequncy of the script you should also change the 60
power.updateElectricity(Power, energy)
return changed
-- Main
if item.isTimer then
getJSON()
local connector, currentChargingPower = extractFields(json2Table())
if fillDevices(connector, currentChargingPower) or repeatNotification then
notify("Charger is " .. connector, repeatNotification )
Posted: Wednesday 02 January 2019 9:20
by azzilla
waaren wrote: Wednesday 02 January 2019 3:03
Also
have Fun !
-- Garo EV charger
1. Alert Device
logging = {
dz.NSS_PUSHOVER,
-- dz.NSS_HTTP,
-- dz.NSS_KODI,
-- dz.NSS_NMA,
dz.NSS_PROWL,
-- dz.NSS_PUSHALOT,
-- dz.NSS_PUSHOVER,
if testMode then
method = "GET",
if testMode then
if val then
changed = true
return changed
-- Main
getJSON()
Working like charm!
Big thank you. Really!
Am going to read up on Lua/DzVents and take it from here.
Next sten is that i'll try to get ssh access to the box. The communication model in the box is a rPi and ssh is activated, i just need to convince the manufacturer to give me the credentials.
Then i should be able to modify the status.json and be able to send instructions to the charger.
Sweet!
Posted: Saturday 08 February 2020 13:30
by ikke
we just got these boxes into our household, and I run into this topic while googling for the device. I noticed from manual that it seems to have raspberry pi inside. Based on that info google dropped me here. I was also wondering how to get access to the device for data. I don't get to open the box, but if someone could, it would be nice to get dumps of the cards connected to raspberrypi. There seems to be usb stick based on picture. So if you get your hands on the box, it would be trivial to install stuff there to get more data out of it. Personally I'd find it interesting to drop mqtt sender in there, to get all the info out of it into mqtt periodically. Like my other raspberry pi's do at home.
So in case you have hands on access to the box, I'm glad to help you with getting e.g. the ssh access to it. All you need to do is likey drop your ssh key in there. So getting out the ssd card/usb stick, and going to user's home directory, likely root, and adding the key to the end of .ssh/authorized_keys file. If it won't work, please copy here the /etc/passwd and the /etc/ssh/sshd_config files.
Remember to cut the power off from the box totally before messing with it. Just to be fully understanding that the electricity in there
can easily kill you. Never do any of this while it's powered. Just in case for everyone reading this.
If you could power it down, extract the usb stick and the ssd card, and copy the contents of them, it would be super. No reason to share them publicly (contains your WLAN pwd, and we don't want to upset the vendor), but I sure would like to see what could be done with them. If possible, store them using some full image copy tool, like dd in Linux.
Posted: Thursday 03 December 2020 13:15
by zadiraines
I'm wondering if you managed to get the dump. I would be interested in digging into it, too. Looks like they use RPI 3 model B rev2 based on the images with no 5Ghz wireless support. I'd be interested in replacing it with a newer model, too. Both 3B+ and 4 support 802.11AC over 5Ghz.
Looking at
this PDF it seems that there is an usb stick and an sd card. So a dump for both would be useful (asuming the USB stick is a mass storage device). My second guess would be the stick being a second wifi interface.
Posted: Wednesday 16 December 2020 20:50
by zadiraines
So looks like the rest API is the best way of talking to the charging station. There is a server running on the RPi listening on port 2222 that relays [and en/decodes] messages to a serial device connected to the GPIO header. Theoretically, it would be possible to debug those messages and create an integration for serial console access - for those people who don't have the network upgrade option. The USB stick is a storage device, containing a database - so is irrelevant from the integration POV.
One thing every owner should know is that the RPi is creating an SSH connection out to some sort of management network, creating an ssh tunnel allowing certain SSH keys to connect back to it from the management network - so technically the support people from GARO would be able to access your internal home network through RPi as a bastion host. You may want to either disconnect it from the network and only connect when support is required or isolate it in a separate network of firewall outgoing traffic.
Posted: Wednesday 24 March 2021 19:21
by StarkJohan
Just trying to put down the information I've found so far for anyone interested. At this point it's pretty much a list of random pieces of information.
The latest software seems to be posted here:
https://www.webel-online.se/wifi/
To upload the zip package this url is used: http://<glb-ip>:8080/update/
You can download the update package, unzip it and poke around. There's a few bash scripts and a few jsp packages that probably can be edited as well as some java class that easily can be decompiled. I have not tried altering anything yet but maybe the files can be altered and then uploaded.
The java classes used when updating runs the bash scripts which performs the actual update: downloadandupdate.sh and updaterscript.sh
The tomcat manager is avalable here: http://tomcat:tTeFxaYBR73Y@<glb-ip>:8080/manager/
/var/lib/tomcat8/webapps/ROOT/index.html
For security reasons, using the manager webapp is restricted to users with role "manager-gui". The host-manager webapp is restricted to users with role "admin-gui". Users are defined in /etc/tomcat8/tomcat-users.xml.
The jsp uses these three urls on port 2222 (probably the ssh tunnel mentioned by zadiraines, there is a cronjob running for usr/local/bin/create_ssh_tunnel.sh) for getting current status as previously mentioned. I haven't looked to much into the json response but at least the current charge current/power can be read which currently is not shown in the GUI (1.2.2). The 13 digit timestamp at the end of the url is perhaps used for statistics but I'm not sure. It's not needed to get the json response but should probably be properly posted when writing any integrations.
For the box with the pi the first url is used. This seems to be called every second from the GUI.
http://<glb-ip>:2222/rest/chargebox/config?_=<13-digit-timestamp>
For the slave boxes (and also the master apparently): This URL is called roughly every 30 seconds.
http://<glb-ip>:2222/rest/chargebox/slaves/false?_=<13-digit-timestamp>
To get the available info from any load balancing "house" power meters us the modbus id as follows. This URL is also called roughly every 30 seconds.
http://<glb-ip>:2222/rest/chargebox/meterinfo/CENTRAL100?_=<13-digit-timestamp>
I have the intention to open up my box to dump the sd card some day but currently this is not a priority. You could probably add your ssh key to the sd card as previously suggested or alter one of the bash scripts to add a sudo user to get ssh access after pushing an update. I don't want to try the update route without dumping the sd card first though.
I haven't looked into the network activity much but I know that this is used for checking for new firmware. It is hard coded in the hosts file like this:
85.11.39.104
www.webel-online.se
Also, the url
https://chargebox.webel.se/ is used for "easy access" to your web GUI which means the glb communicates with this server. Lookup shows it actually resolves to the same ip (85.11.39.104).
Posted: Thursday 01 April 2021 19:04
by Grizz
Wow, I just have to say that I was almost at the point of giving up controlling my ev charger. Then I found this thread! Thank you ALL for sharing!
So I will share what I'm doing now to control my charger using Python.
I’m using
http://<glb-ip>:2222/rest/chargebox/status to get the JSON response with info like if charger is enabled/disabled, current charging current/power and current limit.
- Spoiler: show
# Get charger state
url = 'http://<glb-ip>:2222/rest/chargebox/status'
url_request = urllib.request.urlopen(url)
data = json.loads(url_request.read())
enabled = data['mode'] == 'ALWAYS_ON'
currentChargingCurrent = data['currentChargingCurrent']
currentChargingPower = data['currentChargingPower']
currentLimit = data['currentLimit']
chargeStatus = data['mainCharger']['chargeStatus']
nrOfPhases = data['nrOfPhases']
To enable/disable charger I’m posting JSON-string
'ALWAYS_ON'
or
'ALWAYS_OFF' to
http://<glb-ip>:2222/rest/chargebox/mode with header
{'Content-Type': 'application/json; charset=UTF-8'}
- Spoiler: show
# Set charger state
mode = 'ALWAYS_OFF'
if enabled:
mode = 'ALWAYS_ON'
requests.post('http://<glb-ip>:2222/rest/chargebox/mode', data=mode, json=None, headers={'Content-Type': 'application/json; charset=UTF-8'})
To change charge current I’m posting JSON-string
{"reducedIntervalsEnabled": true,"reducedCurrentIntervals": [{"schemaId": 1,"start": "00:00:00","stop": "24:00:00","weekday": 8,"chargeLimit": "<NEW_CHARGE_CURRENT>}]} to
http://<glb-ip>:2222/rest/chargebox/currentlimit with header
- Spoiler: show
# Set charge limit
url = 'http://<glb-ip>:2222/rest/chargebox/currentlimit'
data = '''{"reducedIntervalsEnabled": true,"reducedCurrentIntervals": [{"schemaId": 1,"start": "00:00:00","stop": "24:00:00","weekday": 8,"chargeLimit": "%s"}]}''' % str(currentLimit)
requests.post(url, data=data, json=None, headers={'Content-Type': 'application/json; charset=UTF-8'})
Hope this will help anyone else like me that is searching for a simple solution to control their charger!
Posted: Thursday 08 April 2021 22:06
by fhloston
Hi, here is my few cents...
Maybe I should wait to post this as this part of the interface is currently broken. It broke in 1.2.2 from Garo. currently it is in 1.2.3 and still broken. I have a ticket for it at Garo though, so hoping to get it fixed....
"chargeStatus":64
This piece is giving that charge status of the car, or was before 1.2.2. I added that to the script created by waaren
I added a percentage device that shows current charge level of the car, and a nice graph of the history (when the box actually reports the correct values, currently it is very fond of reporting 64, but it varies).
And made some additions to the code. Look for "chargestatus" and "chargelevel"
My script now looks like this:
-- Garo EV charger
1. Alert Device
logging = {
local chargelevel = dz.devices("Kona Charge") -- Charge level of car
dz.NSS_PUSHOVER,
-- dz.NSS_HTTP,
-- dz.NSS_KODI,
-- dz.NSS_NMA,
dz.NSS_PROWL,
-- dz.NSS_PUSHALOT,
-- dz.NSS_PUSHOVER,
local testData = '{"ocppState": null,"connector": "CONNECTED","mode": "ALWAYS_OFF","currentChargingPower": 2227.1,"chargeStatus":44}' -- not used when live
local url = "http://192.168.1.18:2222/rest/chargebox/status?_=1546334042114"
if testMode then
method = "GET",
if testMode then
return t.connector,t.currentChargingPower,t.chargeStatus
if val then
local function fillDevices(connected, Power, Chargelevel)
changed = true
chargelevel.updatePercentage(Chargelevel)
return changed
-- Main
getJSON()
local connector, currentChargingPower, chargeStatus = extractFields(json2Table())
if fillDevices(connector, currentChargingPower, chargeStatus) or repeatNotification then
Posted: Friday 20 August 2021 15:29
by StarkJohan
The REST api seems to have been moved from <ip>:2222/rest/chargebox/status to <ip>:8080/servlet/rest/chargebox/status
Posted: Tuesday 30 November 2021 9:47
by x3740xmx
Has anyone managed to find a way who authorized the charge with rfid?
I have done some digging and found the seriallog and some other data.
If you open the web gui and then open the javascript console, these are some commands that can be executed.
javascript:openLogPopup() //Shows seriallog in the web ui
javascript:openSupportPopup() //Opens a modal for remote support?
javascript:downloadLogs() //Downloads seriallog from the last day
javascript:downloadSettings() //Exports settings in a pdf
Posted: Monday 17 January 2022 8:22
by azzilla
Fun to see that someone else than me have made use of this script. Thanks again for your help waaren.
I am trying to make sense of something else regarding the Garo charger script now..
I have setup load balancing for my charger as I kept blowing the main fuse in the house when I set charging to full capacity. The charger is recieving values from a power meter in the mains fusebox. The meter keeps track on the overall load on all phases and reports the usage to the charger so that the charging current automatically steps down when load is close the what the main fuse is rated for. This has been such a great upgrade.
These values are available in json format via a subfolder in the url. In my case the url looks like this:
http://xxx.xx.x.xxx:8080/servlet/rest/c ... o/EXTERNAL and the values shown looks like this:
Note that the url could differ for you as I've read some about this in the HomeAssistant forums.
The values that are of interest are "phaseXCurrent" and the values shown in the image corresponds to:
"phase1Current: 48" = 4,8A
"phase2Current: 31" = 3,1A
"phase3Current: 5" = 0,5A
Now to my "ask"
I would love it if I could get some help with either tweaking this script or creating a seperate script so that I could get a Power Meter device in Domoticz for power consumption tracking for my total consumption.
I can't imagine that this would be impossible as the values shown for amperage could easily be converted from A to W with (in this specific case) amps multiplied by 23 for wattage. For some reason they have decided to use "deciamps" (?)
Posted: Wednesday 03 August 2022 23:08
by tantgron
I don't know if this thread is dead already, but I got my Garo ev-charger without the "databoard" that I installed later as a spare part, a regular Pi3 with some plastic material covering.
I copied the memory card before I even installed it for the first time, and also running it of a not-garo memory card.
If it would be if any help, I got it as a dump to e-mail/Dropbox.
Sorry for bad English.
Posted: Wednesday 03 August 2022 23:24
by tantgron
It is a GLBDC-T222FC.
Posted: Thursday 17 November 2022 0:46
by janbjorn
tantgron wrote: Wednesday 03 August 2022 23:08
I'd be really interested in that Pi3 dump if you still have it laying around. Accidentally ordered my charger without the "Wifi-card" and have a bunch of Pi3's laying around...
Posted: Thursday 16 February 2023 11:52
by henjo
I have just bought a Garo GLB charger without the WIFI module. I am curious if anyone got it working with a regular RPI and a angled header connector?
Posted: Thursday 02 March 2023 9:22
by henjo
I would be very happy if you sent me a copy of the SD-card dump.
