Fibaro FGR222 is not working
Posted: Monday 31 December 2018 8:41
by Jordindc
I'm just introducing in home automation area and I've just doing my first tests. I'm using a raspberry pi 3 B+ with a razberry2 card to z-wave compability. When I had to choose between Z-way server or domoticz&openzwave platform, I thought this last one was a more active community and had a more complete functionallity implemented. So I've started installing domoticz using tutorials I found in this site.
Now I have my razberry running in my domoticz platform. It is well intalled with its blue setup button and I've included my fist device: a fibaro FGR222 Roller Shutter 2 (non z-wave plus). Just in the moment I intiated "Include Node" process, it appeared in my node list, but it was identified as "FGRM222 Roller Shutter Controller 2" (not FGR222 that is de right model I included). The point is that it is not working properly:
  • Buttons doesn't work although setting 1 is set to "No protection"
  • When I change any setting in configuration panel, it seems nothing happens, and default options always appear after refresh
  • When I change device type to Blind (it is originally as Light/Switch) I can action the blind up and down, but it just runs for less than 1 second. And I can't calibrate it because I can't activate setting 29
  • And, finally, now I can't edit device properties in switches panel
Any idea about what is happening?
Thanks in advance
