setRGB for Hue
Maxx
setRGB for Hue
Post by Maxx »
I am struggling to get the actual status of my Hue lights in dzvents. I made a scripts based on a script of Waaren where I can store the actual value of the lights. I want to use this to detect if the lights are changed by an external source (like the philips app).
Somehow the value as stored in the "device.color table" does not seem reliable
this is the script:
-- Develop
    on =       {
        timer = {'every minute'},
    data    =   {   Color                   = { initial = {} },
                    RGBColors               = { initial = {} },
    logging =   {   level                   = domoticz.LOG_DEBUG,
                    marker                  = "Licht develop" },
    execute = function(dz, item)
        local AllLights = {37, 38}
        local function colorTable2RGB(colorTable)
            for k,v in pairs(colorTable) do
                if k == "r" then
                    red = v
                if k == "g" then
                    green = v
                if k == "b" then
                    blue = v
            return red, green, blue
        local function checkAll()
            for i, p in pairs(AllLights) do
                    dz.data.RGBColors = dz.utils.fromJSON(dz.devices(p).color)
                    local name = dz.devices(p).name
                    local Rood, Groen, Blauw = colorTable2RGB(dz.data.RGBColors)
                    dz.log(name)
                    dz.log('IDX is: ' .. p)
                    dz.log(dz.data.RGBColors)
                    dz.log('Rood is: ' .. Rood)
                    dz.log('Groen is: ' .. Groen)
                    dz.log('Blauw is: ' .. Blauw)
        checkAll()
The output is:
 2018-12-30 21:07:00.417 Status: dzVents: Info: Licht develop: Eethoek_2
2018-12-30 21:07:00.417 Status: dzVents: Info: Licht develop: IDX is: 37
2018-12-30 21:07:00.417 Status: dzVents: Info: Licht develop: {["b"]=102, ["cw"]=0, ["g"]=202, ["ww"]=0, ["m"]=3, ["t"]=0, ["r"]=254}
2018-12-30 21:07:00.417 Status: dzVents: Info: Licht develop: Rood is: 254
2018-12-30 21:07:00.417 Status: dzVents: Info: Licht develop: Groen is: 202
2018-12-30 21:07:00.418 Status: dzVents: Info: Licht develop: Blauw is: 102
2018-12-30 21:07:00.418 Status: dzVents: Debug: Licht develop: Processing device-adapter for Eethoek_1: RGB(W) device adapter
2018-12-30 21:07:00.419 Status: dzVents: Debug: Licht develop: Processing device-adapter for Eethoek_1: Switch device adapter
2018-12-30 21:07:00.419 Status: dzVents: Info: Licht develop: Eethoek_1
2018-12-30 21:07:00.419 Status: dzVents: Info: Licht develop: IDX is: 38
2018-12-30 21:07:00.419 Status: dzVents: Info: Licht develop: {["b"]=102, ["cw"]=0, ["g"]=202, ["ww"]=0, ["m"]=3, ["t"]=0, ["r"]=254}
2018-12-30 21:07:00.419 Status: dzVents: Info: Licht develop: Rood is: 254
2018-12-30 21:07:00.419 Status: dzVents: Info: Licht develop: Groen is: 202
2018-12-30 21:07:00.419 Status: dzVents: Info: Licht develop: Blauw is: 102
2018-12-30 21:07:00.420 Status: dzVents: Info: Licht develop: ------ Finished Licht develop v0
it shows both lights with the same rgb values, the problem is that the colors are different in reality. Is something wrong with my script?
I am not sure when the values are updated in the device.
Re: setRGB for Hue
Maxx wrote: Sunday 30 December 2018 21:15 I am struggling to get the actual status of my Hue lights in dzvents. I made a scripts based on a script of Waaren where I can store the actual value of the lights. I want to use this to detect if the lights are changed by an external source (like the philips app).
Please check output of script below. It shows that the results from the API call returns up to date values for rgb and that the result of dz.devices(id).color can be outdated. dzVents is only a passtrough for the .color from domoticz data so I don't think much can be done about that.
local callBack    = "getColorFromDevice"
local allLights = {37, 38}
--local allLights = {156,157}
    on =       {
                    devices         = allLights,
                    httpResponses   = { callBack    },
        local function logWrite(str,level)
            dz.log(tostring(str),level or dz.LOG_DEBUG)
        local function getDeviceStatus()
            local dzAPI = dz.settings['Domoticz url'] .. "/json.htm?type=devices&rid="
            for i,v in ipairs(allLights) do
                url = dzAPI .. v
                dz.openURL  ({ url = url, method = "GET", callback = callBack })
        if not item.isHTTPResponse then
            getDeviceStatus()
            -- logWrite(item.data)
            local colorJSON     = dz.utils.fromJSON(item.json.result[1].Color)
            local device        = dz.devices(tonumber(item.json.result[1].idx))
            local colorDevice   = dz.utils.fromJSON(device.color)
            for k,v in pairs({Red="r",Blue="b",Green="g"}) do
                logWrite(   string.format("%-6s", k ) ..
                            " from JSON ==>> " ..
                            string.format("%03d", colorJSON[v]) ..
                            " ; from dz.devices(" .. device.name .. ").color ==>> " ..
                            string.format("%03d",colorDevice[v])
Maxx
Re: setRGB for Hue
Post by Maxx »
Hi Waaren,
Thanks for you quick response. You are right the, data is often outdated sometimes not even close to what has been send to the lights.
Currently I am using OpenURL to get the Hue status directly from the Hue json and I use curl commands to set the lights. (Send the Hue native HSB and read it)
I rather not send RGB values and then read the HSB to get the real status
Because I want to move away from the curl commands I started trying the more "dzvent native" commands like setRGB. (send RGB and read RGB).
There is another way to move away from curl and still use the HSB values: Currently openURL only supports the POST method, the Hue API needs the PUT method.
I tried modifying the domoticz.lua to accept the PUT method but this is not as easy as I hoped. Maybe this is a nice update for the next version of dzvents?
Re: setRGB for Hue
Maxx wrote: Monday 31 December 2018 13:20 I tried modifying the domoticz.lua to accept the PUT method but this is not as easy as I hoped. Maybe this is a nice update for the next version of dzvents?
Would indeed be nice but not very rewarding if we would have to call curl behind the scenes to get this. I know @Dannybloe and others looked at it but seems complicated.
I started a couple of weeks ago on something similar with Hue colors in dzVents for one of the forum-members but stopped somewhere halfway because I got no feedback anymore on an updated version.
Hopefully you or someone else can cherryPick from it and get this whole color stuff a step forward. For me the different type of calls to Hue and the use of transitiontime was new.
--[[  Hue transition.lua  (dzVents version must be > 2.4)
    prerequisites:  Hue bridge with at least one Philips Hue bulb. (not tested for other brands)
                    curl installed om the OS and accessible by domoticz user
                    dzVents version 2.4 or newer installed as described in the wiki
    at      civiltwilightend the Hue bulbs are switched on with daylight color
    until   sunset gradually the warmth of the lights will become warmer and the brightness will drop
    after   sunset the brightness will drop very smoothly to about 20%
    Change the light names at line 110 to your lightnames within quotes or IDX without
    ensure that the domoticz user can execute curl and check the location of your curl executable at line 111
        Line 112 and 113 are to be used for deActivation of the script using the state of a switch.
    script will start at civiltwilightend, gradually dropping brightness and Kelvin until sunset
    and gradually dropping brightness further from sunset to 1:45 hour after sunset
   http://192.168.192.72/debug/clip.html
    URL:
    /api/apistring/lights/5/state
start
   {"on":true,"bri":254,"ct":153 ,"sat":0}
drop
		"on": true,
		"bri": 100,
		"sat": 252,
		"xy": [
			0.58,
			0.31
		"ct": 250,
		"transitiontime":100
dim
		"on": true,
		"bri": 40,
		"sat": 252,
		"xy": [
            0.58,
			0.31
		"ct": 500,
local hueResponse       = "hueFutureCommand_"
local hardwareCallback  = "getDomoticzHardware"
local hueDeviceCallback = "getHueDeviceStatus"
local stage1            = "initial"
local stage2            = "hardwareInfo retrieved"
local stage3            = "hueInfo retrieved"
local hueTriggerIDX     = 18
local refreshTrigger    = "at 05:01"
local twilightTrigger   = "every 5 minutes between 60 minutes before sunset and sunset"
local sunsetTrigger     = "2 minutes after sunset"
    on          =   {   timer           =   {
                                                twilightTrigger,
                                                refreshTrigger,
                                                sunsetTrigger,
                        httpResponses   =   {
                                                (hueResponse .."*"),
                                                 hardwareCallback,
                                                 hueDeviceCallback,
                        devices         =   {
                                                [hueTriggerIDX] = { 'between sunset and 23:00' }
    data        =   {   refreshState        =   { initial = stage1    },
                        refreshTime         =   { initial = "never"   },
                        Activated           =   { initial = false     },
                        HueIP               =   { initial = ""        },
                        HueDevices          =   { initial = {}        },
                        HueAPI              =   { initial = ""        },
                        manualActivation    =   { initial = "notset"  },
    logging     =   {
                        marker          =   "Hue transition"
    execute = function(dz, item, info)
        _G.logMarker            = info.scriptName     -- sets the logmarker for dz.log
        local hueLights         = {}
--      ********************************************************************* Your changes below this line *************
        local luxDeviceIDX          = 100
        local luxFence              = 1200
        local dimTransitionSeconds  = 6500                     -- Max 6500
        hueLights                   = {"LM46 tafel rechts",156 }    -- Change to name(s) with surrounding Quotes or domoticz IDX without
        local curlExecutable        = "/usr/bin/curl"               -- Check if you have curl on your system
        local deActivationDevice    = 18   -- IDX, "name" or nil    -- deviceName within "" or IDX number without to deActivate script execution
        local ActivationState       = "Off"                         -- State of the deactivation device that cause the script to be active
        local keepOnAfterDim        = false
--      ********************************************************************** No changes below this line **************
        if deActivationDevice and dz.devices(deActivationDevice).state ~= ActivationState and
            item.trigger ~= refreshTrigger and not item.isHTTPResponse then                                     -- Changed
            logWrite("No action needed; Alarm is on ")
            return
        local twilight                  =  dz.devices(luxDeviceIDX).lux < luxFence
        local brightLight               = '{"on":true,"bri":254,"ct":153 ,"sat":0,"hue":9735}'  -- 254 = 100%, 153 = 6500 K (max),  9735 = Sunlight
        local dropColorAndBrightness    = '{"on": true,"bri": 100,"sat": 252,"xy": [ 0.58, 0.31 ],"ct": 250,"transitiontime":XXXX }'
        local dimTransitionTicks        = math.min(65500,dimTransitionSeconds * 10)
        local dropBrightness            = '{"on": true,"bri": 15,"sat": 252,"hue":9735,"ct": 500,"transitiontime": ' ..
                                            dimTransitionTicks .. '}'                                              -- changed
                                            -- 65500, about 1 hour and 45 minutes)   -- 40  = about 17%
        local transitionTime            = {}
        local function osExecute(cmd)
            logWrite(cmd)
            local fileHandle     = assert(io.popen(cmd, 'r'))
            local commandOutput  = assert(fileHandle:read('*a'))
            local returnTable    = {fileHandle:close()}
            logWrite("\n\nreturnCode: " .. returnTable[3] .. "\ncommandOutput: ".. commandOutput .. "\n")
            return commandOutput,returnTable[3]            -- rc[3] contains returnCode
        local function callURL(url,callBack,seconds)
            local seconds     = seconds or 0
            local callBack    = callBack or "noCallbackRequired"
            local url         = url or dz.settings['Domoticz url'] .. "/json.htm?type=command&param=addlogmessage&message=" ..
                                       dz.utils.urlEncode(info.scriptName) ..  "%20Scheduled%20this%20callback%20" .. seconds .. "%20seconds%20ago"
            dz.openURL  ({ url = url, method = "GET", callback = callBack }).afterSec(seconds)
        local function hueHTTP()
            return "http://" .. dz.data.HueIP .. "/api/" ..  dz.data.HueAPI ..  "/lights"
        local function light2HueNumber(light)
            return tonumber(light.deviceId)
        local function curl(light, body)
            return curlExecutable .. " -H 'Content-Type: application/json' -X PUT -d " ..
                    "'" .. body .. "' " ..hueHTTP() .. "/" .. light2HueNumber(light) .."/state"
        local function getHueStatus() -- this function calls the Phillips hue hub and ask for all lights
           callURL(hueHTTP(), hueDeviceCallback)
        local function insertDelay(str,rep)
            return str:gsub("XXXX",rep)
        local function dimSequence()
            for i=1,#hueLights do
                osExecute(curl(dz.devices(hueLights[i]),dropBrightness))
        local function brightLight()                                             -- new function
                osExecute(curl(dz.devices(hueLights[i]),brightLight))
        local function startSequence()
           dz.data.manualActivation = "notset"
            transitionTime.seconds = dz.time.secondsSinceMidnight - ( _G.timeofday.CivTwilightEndInMinutes * 60 )
            transitionTime.hueTicks = math.max( 6000, math.min(65534,  transitionTime.seconds * 10 )) -- Min 10 minutes. Hue uses 0.1 second Ticks
            dz.data.Activated = true
                osExecute(curl(dz.devices(hueLights[i]),insertDelay(dropColorAndBrightness,transitionTime.hueTicks)))
        local function getDomoticzHardware()  -- this function calls local domoticz process and ask for all defined Hardware
           local url  = dz.settings["Domoticz url"] .. "/json.htm?type=hardware"
           callURL(url, hardwareCallback)
           dz.data.HueDevices = {}   -- (re) init Hue devices when new hardware is retrieved
           local url = "http://" .. dz.data.HueIP .. "/api/" ..  dz.data.HueAPI ..  "/lights"
            callURL(url,hueDeviceCallback)
        local function handleHueDeviceStatus()
           local lights = item.json -- convert to table
            for i, light in pairs(lights) do
                logWrite("Light in Hue: [" .. i .. "] type: " .. light.type)
                logWrite("Light in Hue: [" .. i .. "] name: " .. light.name)
                t                               = {}
                t.number                        = i
                t.type                          = light.type
                for j=1,#hueLights do                                      -- Just store the lights involved and ignore rest
                    if tonumber(dz.devices(hueLights[j]).deviceId) == tonumber(t.number) then
                        dz.data.HueDevices[light.name]  = t
            dz.data.refreshTime =  os.date("%x %X")
        local function  handleDomoticzHardware()        -- this function extracts hueIP from json string from getDomoticzHardware call and
           rt  = item.json.result                   -- put these in persistent vars for future use
            for i = 1,#rt do
                if rt[i].Type == 38 then                -- Hardware type Hue is 38
                    dz.data.HueIP  = rt[i].Address      -- Fill with IP number
                    dz.data.HueAPI = rt[i].Username     -- Fill with API key
                    return false
        local function initializePersistentData(callType)
            if dz.data.manualActivation == "notset" then
                dz.data.manualActivation = item.isDevice and item.state == "Off" and dz.time.matchesRule("between 15 minutes before sunset and 22:00")
            if (dz.data.manualActivation and not(next(dz.data.HueDevices))) or ( callType ~= nil and callType == "time" ) then
                dz.data.Activated = false
                if dz.data.refreshState == stage1 then
                 -- Get API key and hue IP to refresh persistent data
                    dz.data.refreshState = stage2
                elseif dz.data.refreshState == stage2 then
                 -- get Lights info to refresh persistent data
                    getHueStatus()
                    dz.data.refreshState = stage3
                elseif dz.data.refreshState == stage3 then
                    dz.data.refreshState = stage1
                    if dz.data.manualActivation then
                        dz.devices(hueTriggerIDX).switchOff().afterSec(1)
            elseif item.trigger == hueDeviceCallback  then
                handleHueDeviceStatus()         -- get hue light info directly from Hue hub
            elseif dz.data.HueIP ~= "" and dz.data.HueAPI ~= ""  then
                if next(dz.data.HueDevices) == nil then
                    getHueStatus()                  -- We already have the API key and hue IP but HueDevices table is empty
            elseif (dz.data.HueIP == "" or dz.data.HueAPI == "")  and dz.data.refreshState == stage1 then
                getDomoticzHardware()           -- Get API key and hue IP
            elseif item.trigger == hardwareCallback then
                handleDomoticzHardware()        -- get API key and hue IP from JSON into persistent vars
        -- Main
        if item.trigger == refreshTrigger or not(next(dz.data.HueDevices)) then
             initializePersistentData("time")                         -- refresh persistent data
        elseif item.trigger == hueResponse .. "setInactive" then
        elseif item.trigger == hueResponse .. "dimDelayed" then
            dimSequence()
        elseif dz.time.matchesRule(sunsetTrigger) or
            if dz.data.Activated then
               logWrite("Sequence already activated")
               return
            initializePersistentData()       -- Check if initializing persistent Data is necessary
            if next(dz.data.HueDevices) then -- we have the devices in persistent data
                startSequence()
                local delay = math.abs(transitionTime.seconds)
                callURL(nil,hueResponse .. "dimDelayed",delay )          -- trigger script again after transitionTime.minutes
                callURL(nil,hueResponse .. "setInactive", delay + dimTransitionSeconds )
        elseif twilight then                                                  -- new
                brightLight()
Maxx
Re: setRGB for Hue
Post by Maxx »
Thanks, I will have a look at this but first I have to bake some oilballs today
Happy 2019
