Zigate and xiaomi door sensor cant pair
Posted: Sunday 30 December 2018 18:43
HI guys,
Im newbe in domoticz and zigate today i tried to pair some door sensors but without succes.
my server is i7, xubuntu ,zigate plugin 4.0.0
so i press button on device /xiaomi aquara door sensor/ and in log show this:
zigate is usb not wifi
2018-12-30 18:40:36.438 Sunrise: 07:30:00 SunSet: 15:53:00
2018-12-30 18:40:36.438 Day length: 08:23:00 Sun at south: 11:05:00
2018-12-30 18:40:36.438 Civil twilight start: 06:54:00 Civil twilight end: 16:30:00
2018-12-30 18:40:36.438 Nautical twilight start: 06:14:00 Nautical twilight end: 17:09:00
2018-12-30 18:40:36.438 Astronomical twilight start: 05:36:00 Astronomical twilight end: 17:47:00
2018-12-30 18:40:36.666 Active notification Subsystems: (0/13)
2018-12-30 18:40:36.694 Starting shared server on: :::6144
2018-12-30 18:40:36.694 Accepting shared server connections via MyDomotiz (see settings menu).
2018-12-30 18:40:36.278 Status: Domoticz V4.10301 (c)2012-2018 GizMoCuz
2018-12-30 18:40:36.278 Status: Build Hash: b1521946, Date: 2018-12-20 19:46:47
2018-12-30 18:40:36.296 Status: Startup Path: /home/sonics007/domoticz/
2018-12-30 18:40:36.438 Status: EventSystem: reset all events...
2018-12-30 18:40:36.664 Status: PluginSystem: Started, Python version '3.6.7'.
2018-12-30 18:40:36.685 Status: WebServer(HTTP) started on address: :: with port 8080
2018-12-30 18:40:36.694 Status: Proxymanager started.
2018-12-30 18:40:36.694 Status: TCPServer: shared server started...
2018-12-30 18:40:36.694 Status: RxQueue: queue worker started...
2018-12-30 18:40:36.694 Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: bind: Address already in use
2018-12-30 18:40:36.694 Error: WebServer(SSL) check privileges for opening ports below 1024
2018-12-30 18:40:37.897 Status: PROXY: Authenticate result: success.
2018-12-30 18:40:38.695 Status: (zigate) Started.
2018-12-30 18:40:38.695 Status: EventSystem: reset all events...
2018-12-30 18:40:38.695 Status: EventSystem: reset all device statuses...
2018-12-30 18:40:38.723 Status: Python EventSystem: Initalizing event module.
2018-12-30 18:40:38.724 Status: EventSystem: Started
2018-12-30 18:40:38.724 Status: EventSystem: Queue thread started...
2018-12-30 18:40:38.969 Status: PluginSystem: Entering work loop.
2018-12-30 18:40:39.183 (zigate) ListOfDevices :
2018-12-30 18:40:39.183 (zigate) Establish Zigate connection
2018-12-30 18:40:39.185 (zigate) Connected successfully
2018-12-30 18:40:39.179 Status: (zigate) Entering work loop.
2018-12-30 18:40:39.179 Status: (zigate) Initialized version 4.0.0, author 'zaraki673 pipiche38'
2018-12-30 18:40:39.180 Status: (zigate) onStart called - Zigate plugin V 4.0.0
2018-12-30 18:40:39.180 Status: (zigate) load PluginConf
2018-12-30 18:40:39.181 Status: (zigate) ZigateMode: ZigBee sendDelay: 0 reTransmit: 1 zTimeOut: 2
2018-12-30 18:40:39.181 Status: (zigate) logFORMAT: 0 logLQI: 0 allowRemoveZigateDevice: 0
2018-12-30 18:40:39.181 Status: (zigate) allowStoreDiscoveryFrames: 0 forceCreationDevice: 0 networkScan: 0 channel: ['0']
2018-12-30 18:40:39.183 Status: (zigate) load ListOfDevice
2018-12-30 18:40:39.183 Status: (zigate) Entries loaded from /home/sonics007/domoticz/plugins/Domoticz-Zigate/DeviceList-4.txt : 0
2018-12-30 18:40:39.183 Status: (zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB0
2018-12-30 18:40:39.185 Status: (zigate) onConnect called
2018-12-30 18:40:39.185 Status: (zigate) ZigateConf - Setting UTC Time to : 1546191639
2018-12-30 18:40:39.185 Status: (zigate) Start network
2018-12-30 18:40:39.185 Status: (zigate) Zigate enter in discover mode for ever
2018-12-30 18:40:39.195 Status: OpenZWave: using config in: /home/sonics007/domoticz/Config/
2018-12-30 18:40:39.212 Status: OpenZWave: Starting...
2018-12-30 18:40:39.212 Status: OpenZWave: Version: 1.4-3297-g98c3bde5-dirty
2018-12-30 18:40:39.379 Status: OpenZWave: Driver Ready
2018-12-30 18:40:39.397 Status: OpenZWave: All Nodes queried
2018-12-30 18:40:45.896 (zigate) receiveDataCmd - unexpected message Type: 00c8 Expecting: 8010
2018-12-30 18:40:45.896 (zigate) ZigateRead - Unknow Message Type for : 0100c8000a2800150d0002d226ed00e903
2018-12-30 18:40:48.050 (zigate) receiveDataCmd - unexpected message Type: 00cd Expecting: 8015
2018-12-30 18:40:48.050 (zigate) ZigateRead - Unknow Message Type for : 0100cd000c3fe0f400150d0002d226ed00e903
2018-12-30 18:40:48.351 (zigate) ZigateRead - Unknow Message Type for : 0100cd000c2de0f400150d0002d226ed00fb03
2018-12-30 18:40:48.351 (zigate) ZigateRead - Unknow Message Type for : 0107010003fe0000fb03
2018-12-30 18:40:48.352 (zigate) ZigateRead - Unknow Message Type for : 0101020023fd00e0f4010000000500c20016ecf5ede92ef3e5eef3eff2dfede1e7eee5f42ee1f132fb03
2018-12-30 18:40:48.352 (zigate) ZigateRead - Unknow Message Type for : 010102000ec000e0f401000000010020000103fb03
2018-12-30 18:40:48.603 (zigate) ZigateRead - Unknow Message Type for : 010102002af501e0f4010000ff0100c2001d01210d0c032816046168010521db00062401000000000a210000e41001fb03
yesterday i try it on my virtualbox all has working with no issue but today on my proper server not
what i need to do?
what i need to do?
