Volume control by dimmer
Posted: Sunday 30 December 2018 16:42
by VHK17
How to change the volume of the amixer With a virtual dimmer.
I can change the volume by comment line amixer sset PCM,0 90%
What is the best way to do this ; amixer sset PCM,0 virtual dimmer%
Re: Volume control by dimmer
Posted: Sunday 30 December 2018 17:22
by Pjedr
Maybe my script can help, it looks for changed device with a specific name, and if the value contains the word 'level' it extracts it and calculates a level for the soundlevel between 0 and max of 70
function round(num, idp) local mult = 10^(idp or 0) --Round number to identent point
if num >= 0 then return math.floor(num * mult + 0.5) / mult else return math.ceil(num * mult - 0.5) / mult end
--for i,v in pairs(devicechanged) do print('Changed: device='..i..', value='..v) end
for i,v in pairs(devicechanged) do if (#device==0 or #i < #device) then device=i end end
if LogLvl >= 4 then print('Getriggerd door ___'..device..' now '..otherdevices[device]..'___') end
if device=='LF Ûntfanger Onkyo Lûdknop' then --1
if string.match(otherdevices['LF Ûntfanger Onkyo Lûdknop'], "Level") then print('We hebben een Onkyo Set Level match') --2
sOnkyoVolumeProcents=tonumber(otherdevices['LF Ûntfanger Onkyo Lûdknop']:match("(%d+)"))
sOnkyoVolumeCalc=round(70/100*sOnkyoVolumeProcents)
--print('Onkyo = '..sOnkyoVolumeProcents..' procent, calculated value = '..sOnkyoVolumeCalc)
--print('nohup '..sScriptsDir..'/OnkyoVolumeSet.sh '..sOnkyoVolumeCalc)
os.execute('nohup '..sScriptsDir..'/OnkyoVolumeSet.sh '..sOnkyoVolumeCalc..' 2>/dev/null &')
end end --2 --1
