Rtl 433 RTL-SDR receiver : rtl_433 startup failed
Posted: Friday 28 December 2018 18:09
Hello everyone,
I start on Domoticz.
I installed Domoticz (v4.9700) on a Raspberry Pi Model B with the Raspbian Stretch OS (2018-11-13).
I am having problems using the "RTL 433 - RTL-SDR Receiver".
In the Domoticz log file, I have the following information:
2018-12-28 18: 00: 36.271 Status: Rtl433: Worker stopped ...
2018-12-28 18: 00: 37.324 Status: Rtl433: Worker started ...
2018-12-28 18: 00: 37.433 Status: Rtl433: rtl_433 startup failed. Make sure it's properly installed (rtl_433 -f csv -q -I 2 2> / dev / null). https://github.com/merbanan/rtl_433
If I run command line "rtl_433 -F csv -q -I 2 2" I get the following message:
rtl_433 version 18.12-50-ge843853 branch master at 201812281225
Trying conf file at "rtl_433.conf" ...
Trying conf file at "/home/pi/.rtl_433/rtl_433.conf" ...
Trying conf file at "/usr/local/etc/rtl_433/rtl_433.conf" ...
Trying conf file at "/etc/rtl_433/rtl_433.conf" ...
quiet option (-q) is default and deprecated. See -v to increase verbosity
include_only (-I) is deprecated. Use -S none | all | unknown |
If I remove the options "-q -I 2 2", it works perfectly against.
pi @ raspberrypi: ~ / rtl_433 / src $ rtl_433 -E csv
Registered 96 out of 120 device decoding protocols [1-4 8 11-12 15-21 23 25-26 29-36 38-60 62-64 67-71 73-100 102-103 108-116 119]
time, msg, codes, model, button, id, channel, battery, temperature_C, mic, rid, humidity, state, status, brand, rain_rate, rain_total, gust, average, direction, pressure_hPa, uv, power_W, energy_kWh, unit, group_call, command, sun, dim_value, WIND_SPEED, wind_gust, wind_direction, dipswitch, RButton, device, temperature_F, rc, brandmodelidtemperature_C, setpoint_C, switch, cmd, cmd_id, modelidcmd, tristate, direction_str, direction_deg, speed, rain, Msg_type, signal, hours, minutes, seconds, year, month, day, sensor_code, uv_status, uv_index, lux, wm, k, ws_id, rainfall_mm, wind_speed_ms, gust_speed_ms, current, interval, learn, sensor_id, BATTERY_LOW, sequence_num, message_type, wind_speed_mph, wind_dir_deg, WIND_DIR, rain_inch, gust_speed_mph, wind_approach, rain_mm, flags, maybetemp, binding_countdown, depth, dev_id, power0, power1, power2, node, CT1, CT2, CT3, CT4, Vrms / batt, temp1_C, temp2_C, temp3_C, temp4_C, temp5_C, temp6_C, pulse, address, button1, button2, button3, button4, data, group, sid, transmit, moisture, type, pressure_PSI, battery_mV, pressure_bar, pulse, energy, device id, code, the No, to, from, payload, event, heartbeat, brandmodelidstatus, temperature_C1, temperature_C2, test, probe, water, ptemperature_C, phumidity, newbattery, heating, heating_temp, uvi, light_lux, counter, alarm, depth_cm, repeat, pressure_kPa, maybe_battery, typeid, pressure_kpa, modelID, temperature_1_C, temperature_2_C, device_type, raw_message, switch1, switch2, Switch3, Switch4, switch5, seq, extradata, house_id, module_id, SENSOR_TYPE, sensor_count, alarms, Sensor_value, battery_voltage, failed, class, alert, secret_knock, relay
Detached kernel driver
Found Rafael Micro R820T tuner
Exact sample rate is: 250000.000414 Hz
[R82XX] PLL not locked!
Sample rate set to 250000 S / s.
Tuner gain set to Auto.
Tuned to 433.920MHz.
2018-12-28 18:02:49 ,,, THGR122N ,, 245,1, LOW, 1,300 ,,, 75 ,,, OS ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
It seems that the parameters is hard-coded in the C file (see https://github.com/domoticz/domoticz/bl ... Rtl433.cpp)
I did not find how to change these default settings when launching rtl_433 by domoticz via the interface.
Can someone help me to change these settings without having to modify Domoticz sources?
In advance a very big thank you,
Have a nice day and a very good new year,
Best regards,
Bruno
Best regards,
Bruno
