Trigger on two conditions
Posted: Friday 28 December 2018 16:35
by DespyNL
I would like to trigger my Hue Motion sensor script only between specific time. Is this possible?
devices = {
'Hue Motion 1'
timer = {
'at 06:00-09:00'
At this point it always triggers
Re: Trigger on two conditions
Posted: Friday 28 December 2018 17:42
by waaren
DespyNL wrote: Friday 28 December 2018 16:35
Check
the dzVents wiki
syntax to achieve this is
devices = {["Hue Motion 1"] = {"at 06:00-09:00"}},
Posted: Tuesday 01 January 2019 21:44
by Aadr
I'am stuggeling with this syntaxis, specially with more than one device and more than one timeframe.
I have come up with this code:
devices =
{[ 'Motion Kantine'] = {'at 13:00-22:00 on sat','at 19:00-23:30 on mon,tue,wed,fri',
'at 19:00-02:30 on thu'},
['Status_Muziek'] = {'at 13:00-22:00 on sat','at 19:00-23:30 on mon,tue,wed,fri',
['Verlichting_Kantine_Mode'] = {'at 13:00-22:00 on sat','at 19:00-23:30 on mon,tue,wed,fri',
but this code never triggers.
can someone point me in the right way?
thanks
Posted: Tuesday 01 January 2019 22:34
by waaren
Aadr wrote: Tuesday 01 January 2019 21:44
I'am struggling with this syntaxis, specially with more than one device and more than one timeframe.
Hopefully you are on a more recent version then what your profile shows
The problem in your "on = " section is one missing }
local timeTable = {'at 13:00-22:00 on sat','at 19:00-23:30 on mon,tue,wed,fri','at 19:00-02:30 on thu'}
devices = {
['Motion Kantine'] = timeTable,
['Status_Muziek'] = timeTable,
['Verlichting_Kantine_Mode'] = timeTable
logging = { level = domoticz.LOG_DEBUG,
marker = "multiple device triggers" },
execute = function(dz, item)
local function logWrite(str,level)
dz.log(tostring(str),level or dz.LOG_DEBUG)
logWrite ("triggered by " .. item.name)
Posted: Wednesday 02 January 2019 19:24
by Aadr
Thank you, Waaren
It works well and I can start now with the next DzVents-beginners challenge.
Was there a way I could have know this syntaxis by my self, I am not educated in programming. Is there some more documentation to read, except for the wiki and the forum?
And I have updated my profile
thank you.
Re: Trigger on two conditions [SOLVED]
Posted: Wednesday 02 January 2019 20:25
by waaren
Aadr wrote: Wednesday 02 January 2019 19:24
dzVents is for the biggest part Lua. Behind the scenes there is some C++ code to efficiently communicate from and to the domoticz data but most of the Lua code that makes it easier to script in Lua and work with domoticz data is in the domoticz/dzVentz/runtime/ directory's
What I did to better understand how stuff is working is looking at the code in these directory's. What also worked for me is to search te internet for all kinds of information on Lua. If you already know a bit about other programming languages, Lua is not extremely difficult and once you get a better understanding on how Lua tables work you are more then halfway
Luckily you can find tons of information on that and a good starting point is
https://www.lua.org/pil/2.5.html
What confuses most people at first is the difference between {} and [] and that tableName.keyName is the same as tableName["keyName"]
In general terms:
everything between {} is a table
everything between [] is a key in a table. And a key can be any Lua datatype (yes also a table
) except nil
if a table has no explicit keys than the keys are integers starting from 1
Hope this will help
