please help, simple light with motion detector
salopette
Post by salopette »
Hello, can someone please create simple script for light with motion detector.
I can not get it myself.
I have stairs with 6 lamps (on / off) and a motion detector (sends ON / OFF after 2min)
the button can be ignored
active = true,
devices = {
'Zigbee Stick - BWM1',
'Zigbee Stick - Taster'
local Taster = domoticz.devices('Zigbee Stick - Taster')
local BWM = domoticz.devices('Zigbee Stick - BWM1')
local lamp1 = domoticz.devices('Zigbee Stick-treppe1')
local lamp2 = domoticz.devices('Zigbee Stick-treppe2')
local lamp3 = domoticz.devices('Zigbee Stick-treppe3')
local lamp4 = domoticz.devices('Zigbee Stick-treppe4')
local lamp5 = domoticz.devices('Zigbee Stick-Flur OG1')
local lamp6 = domoticz.devices('Zigbee Stick-Flur OG2')
if (device.name == 'Zigbee Stick - BWM1' and device.state == 'On'
or device.name == 'Zigbee Stick - Taster' and device.state == 'Click') then
  if (lamp1.state == 'Off' or lamp2.state == 'Off' or lamp3.state == 'Off' or lamp4.state == 'Off' or lamp5.state == 'Off' or lamp6.state == 'Off') then
        lamp1.switchOn()
        lamp2.switchOn()
        lamp3.switchOn()
        lamp4.switchOn()
        lamp5.switchOn()
        lamp6.switchOn()
        lamp1.switchOff()
        lamp2.switchOff()
        lamp3.switchOff()
        lamp4.switchOff()
        lamp5.switchOff()
        lamp6.switchOff()
havnegata
Domoticz version: V4.10162
Re: please help, simple light with motion detector
Post by havnegata »
I was reading through the forum and came by this nice script by user @waaren. It's even got a check for lux-value:
http://www.domoticz.com/forum/viewtopic ... en#p200271
salopette
Post by salopette »
Thanks, I will show it.
I'm new to DZVents, I've always used Blockly so far, but it's not supposed to be as good and flexible as DZvents.
Is there an easy way to learn dzvents?
havnegata
Post by havnegata »
The Wiki https://www.domoticz.com/wiki/DzVents:_ ... _scripting is always a good startingpoint for reference, but I haven't got any skills in programming, so my approach is to search the forum for similar problems and then I try to adopt to my needs.
salopette wrote: Wednesday 26 December 2018 10:29 Thanks, I will show it.
What about the video in this post
salopette
Post by salopette »
I got it now! Do not use timer or daytime
active = true,
devices = {
local Taster = 'Zigbee Stick - Taster'
local BWM = 'Zigbee Stick - BWM1'
if (device.name == BWM and device.state == 'On'
    or device.name == Taster and device.state == 'Click') then
        lamp1.dimTo(5)
        lamp2.dimTo(5)
        lamp3.dimTo(5)
        lamp4.dimTo(20)
        lamp5.dimTo(30)
        lamp6.dimTo(30)
        lamp1.switchOff()
        lamp2.switchOff()
        lamp3.switchOff()
        lamp4.switchOff()
        lamp5.switchOff()
        lamp6.switchOff()
