Best zigbee stick for domoticz?
tjabas
Post by tjabas »
There seems to be some different zigbee controllers out There, but which one is the best and easiest to set up and use?
Is There anyone that has full support in domoticz yet?
oldfantome
Re: Best zigbee stick for domoticz?
Post by oldfantome »
I use "zigate"
tjabas
Post by tjabas »
Ok, does zigate have full support in domoticz?
Thorgal789
Post by Thorgal789 »
Yes, like others, if by full support you mean your ikea+philips color bulbs, I can confirm all have "full support".
oldfantome
compatible with Phillips hue , ikea, xiaomi (aqara ,switch ,temp,motion ,cube,doors Switch etc...) and others.
full list :
https://zigate.fr/le-materiel-compatible-zigate/
pipiche
Post by pipiche »
The plugin is currently under development of new features like Group management. Of course you can use group from Domoticz but then the implementation will manage each single element of the group. While a native group management will be much more efficient.
molnaratti
Post by molnaratti »
Delta78
Post by Delta78 »
On my side, I m using the deconz framework with a conbee, I used it on another application before and I realy think nothing is missing, and now with a domoticz plugin.
https://github.com/Smanar/Domoticz-deCONZ.
^^, make your choice.
