GoogleApiClient
Filip
GoogleApiClient
Post by Filip »
I am trying to make a plugin to connect to my calendar. I try to import the googleapiclient in my plugin (see extract code below). I don't use any function of the googleapiclient in the code (I only do the import). All works well, no error messages are shown... However, other plugins started up afterwards do NOT start anymore... If I put the line "from googleapiclient import sample_tools" in comments, then all plugins are working fine.
Has somebody already experience with this?
#IMPORTS
import Domoticz
import subprocess
import sys
sys.path.append('/usr/local/lib/python3.5/dist-packages')
from datetime import datetime
zak45
Domoticz version: V2024.4
Re: GoogleApiClient
Post by zak45 »
Filip wrote: Tuesday 25 December 2018 22:52 I am trying to make a plugin to connect to my calendar.
Or you can try this :
https://www.domoticz.com/wiki/Plugins/iCal.html
Filip
Re: GoogleApiClient
Post by Filip »
Mmmm... not really the intention... I have a python script working with CRON, but wanted to convert to a plugin...
Seems like the plugin system stopped (and heartbeat not called anymore) after the import.
Seems something crashes, but I don't get logs... Already tried the loglevel and debuglevel, but this does not give the right information...
Filip
Re: GoogleApiClient
Post by Filip »
Finally I have solved it with a dedicated python script called from the plugin (see code below; call to external python script in bold). Not 100% happy seen the python script uses web access and is blocking for the plugin. Would prefer to use the callback mechanism of the plugin.
If somebody has still an idea how to import the GoogleApiClient in the plugin, don't hesitate.
def onHeartbeat(self):
Domoticz.Debug("onHeartbeat called")
if self.run:
self.runAgain -= 1
if self.runAgain <= 0:
# Start the command to read the Google Calendar
Domoticz.Debug("Start ")
command = "python /home/pi/domoticz/plugins/GoogleCalendar/google-calendar.py '%s' '%s'" % (self.name, self.location)
response = subprocess.check_output(command, shell=True)
response = response.decode('utf-8')
Domoticz.Debug(response)
if 'Enter verification code' in response:
http = response[response.find('http'):response.find('Enter')-2]
Domoticz.Error('The credentials have been revoked or expired, please re-run the application to re-authorize.')
Domoticz.Error('Go to \'%s\' and copy the authorisation code in the hardware setup of the GoogleCalendar.' % http)
auth_code = u'%s' % Parameters["Mode4"]
subprocess.run(command, shell=True, universal_newlines=True, input=auth_code)
elif 'ERROR' in response:
Domoticz.Error(response)
else:
events = response.splitlines()
Domoticz.Debug(str(len(events)))
if len(events) > 0:
data = events[0].split('--')
UpdateDevice(_UNIT_APPOINTMENT, nValue=1, sValue='%s: %s\n%s'%(data[0].replace("T", " "), data[1], data[2]), AlwaysUpdate=False)
UpdateDevice(_UNIT_TIMELEFT, nValue=int(data[3])*24+int(data[4]), sValue=str(int(data[3])*24+int(data[4])), AlwaysUpdate=False)
else:
UpdateDevice(_UNIT_APPOINTMENT, nValue=0, sValue='(NONE)\n', AlwaysUpdate=False)
UpdateDevice(_UNIT_TIMELEFT, nValue=0, sValue=0, AlwaysUpdate=False)
# Run again following the period in the settings
self.runAgain = _MINUTE*int(Parameters["Mode3"])
else:
Domoticz.Debug("onHeartbeat called, run again in "+str(self.runAgain)+" heartbeats.")
