Water Motor Automation
Posted: Monday 24 December 2018 17:50
by tango156157
Helloz...I'm looking at automating my Water motor. At my place, Public Water supply is provided by our Municipal Corp. at set times. We have water motors at every house to pump the water to our Rooftop Water tanks from where it is distributed within the house.
I want to:
1. I have 4 Sensors in my water tank placed at different levels in the Water tank ( At 0%, 50%, 100% and Water Pump Intake Pipe)
2. I have connected above sensors to my Raspberry Pi to GPIO pins so they trigger the following named switches in Domoticz - 'Low', 'Med', 'High' and
'Waterin' respectively.
3. I want the water Motor to start daily from 6 AM to 7 AM and 6 PM to 7 PM only when Water in tank is Less than 100 and 50% and 0% (so Motor will only start when Water % is less than 100% in the tank) and when it's the time for the Public Water Supply times (ie. from 6-7 AM and 6-7 PM)
4. Finally in the scenario when No water is being pumped during above conditions (no water in the Public Supply but still Daily water time of 6-7 AM and PM) - the motor should stop and check periodically and start / Stop motor.
I have tried Blocky for below requirements, But I feel that it's more complicated and the answer to my requirements is in dzVents only....Requesting my Fellow Domoticz Enthusiasts to help me here...
T
Re: Water Motor Automation
Posted: Monday 24 December 2018 21:08
by waaren
tango156157 wrote: Monday 24 December 2018 17:50 Helloz...I'm looking at automating my Water motor. At my place, Public Water supply is provided by our Municipal Corp. at set times. We have water motors at every house to pump the water to our Rooftop Water tanks from where it is distributed within the house.
If I understood your setup and requirements correctly the dzVents code below should work for you.
-- waterTank.lua   for dzVents >= 2.4
local morning       = "at 6:*"         -- every minute between 6:00-7:00
local evening       = "at 18:*"        -- every minute between 18:00-19:00
local highSensor    = "High"
local waterPump     = "water Motor"     -- change to name of motor device within quotes or id of motor device without quotes.
    on =        {       timer      =   { morning,evening },
                        devices    =   { highSensor  }},
    logging =   {       level   =   domoticz.LOG_DEBUG,
                        marker  =   "waterTank control" },
    execute = function(dz, item)
        tankFull  = dz.devices(highSensor).state == "On"
        pump      = dz.devices(waterPump)
        pumping   = pump.state == "On"
        if item.isTimer and dz.time.matchesRule("at *:59") and pumping then  -- Pump timeslot ends. Stop pump (when pumping)
            pump.switchOff()
        elseif item.isTimer and not tankFull and not pumping then             -- Pump timeslot
            pump.switchOn()
        elseif tankFull then -- triggered by highSensor
            pump.switchOff()
Posted: Thursday 27 December 2018 7:57
by tango156157
Many Thanks Waaren, I will try implementing the above script and let you know....
Wishing u a Happy New Year Ahead....
Posted: Tuesday 01 January 2019 14:43
by tango156157
waaren wrote: Monday 24 December 2018 21:08
            pump.switchOff()
            pump.switchOn()
            pump.switchOff()
So I tried above code which seems to work for my basic requirements of starting motor at said times, however still some tweaks required to the code based on observations:
1. The Water Motor starts but exactly after 1 Minute - the Water motor stops as next condition kicks in (If No Water is being pumped by motor at the water tank (this is picked up by a sensor connected to Raspberry Pi GPIO which gives condition of GPIO Pin in Closed state (Open signifies Water is being pumped into the water tank).
2. In the script below, I want the motor to be in "Off" condition for 2 minutes if there is no water being pumped to avoid a Dry Run state of the water motor, however this code also re-runs after exactly 1 minute and Water Motor turns on... This then becomes an endless loop till time conditions are true.
My modified code is as below:
local morning = "at 06:*" -- every minute between 6:00-7:00
local highSensor = "100" -- 100% Tank Full sensor connected via GPIO to Raspberry Pi
local waterPump = "WaterMotor" -- Water Motor Switch
local waterin = "WaterSensor" -- Water sensor placed in Water inlet pipe of the tank connected to water pump
devices = { highSensor,waterin }},
tankFull = dz.devices(highSensor).state == "Open"
wateryes = dz.devices(waterin).state == "Open" -- Open is Water is getting pumped and Closed is no water getting pumped
pump.switchOff()
pump.switchOn()
pump.switchOff()
elseif item.isTimer and not wateryes then
pump.switchOff().forMin(2)
