Logitech hub
Posted: Monday 24 December 2018 0:37
by smartel
For those interested, Logitech has issued a firmware update that breaks the remote access API, thus Domoticz was not able to communicate with the Logitech Harmony Hubb, here is a link to fix it :
https://community.logitech.com/s/questi ... rabilities
Re: Logitech hub
Posted: Monday 24 December 2018 10:39
by StanHD
@smartel
Thank you very much, working again now.
Looks like Logitech may be realising the amount of customers they made unhappy.
Sent from my SM-T820 using Tapatalk
Re: Logitech hub
Posted: Friday 04 January 2019 13:58
by JCLB
Re: Logitech hub
Posted: Saturday 16 February 2019 21:54
by poudenes
Hello all,
Logitech have updated firmware to 4.15.250 and enable the xmpp again for all users.
But since my hub is updated Domoticz can't connect to it anymore.
Searched on internet and you need enable XMPP:
Menu > Harmony Setup > Add/Edit Devices & Activities > Remote & Hub > Enable XMPP
Then everything work again
Re: Logitech hub
Posted: Sunday 03 May 2020 8:05
by HSR3
I've been using the Harmony Hub for some time now with XMPP enabled after the firmware update to 4.15.250. All was working fine until the latest firmware update to 4.15.264 mid March. Although the XMPP option is still enabled Domoticz cannot connect to the hub. I scanned the ports of the hub but no open ports have been found. Switching the XMPP option OFF and ON doesn't help either.
Anybody with the same problems and possible solution?
Re: Logitech hub
Posted: Tuesday 05 May 2020 14:25
by krizzz
Sorry to hear about your problems, but thanks for posting your issues! I will definitely not update than!
Re: Logitech hub
Posted: Tuesday 07 July 2020 10:00
by jelleeelco
krizzz wrote: Tuesday 05 May 2020 14:25
I have the same version on my hub (4.15.264) and I have no issues connecting to it, so I doubt anything is broken in the hub software...
On a different topic, just a couple of days ago someone created a 'server' that imitates a Roku device and makes it possible to capture ALL buttons pressed from the remote. So you can actually change lights based on pauze/play, and not just in Kodi with the Kodi plugin, but in all activities. I haven't been able to test this out myself yet (it requires the Harmony hub which I have, but also a remote that you can sync over USB, as that step is needed for initial installation to find the Roku Server as a device- I don't have a remote like that yet) but it's very promising. It's in early stages and he's refining the code and installation (I hope he makes it work without the need for a remote with USB)...
His project is called Harmony Span, see links below:
https://github.com/AShifter/harmony-span/
https://www.youtube.com/watch?v=W59Ae5jUl2w
