Equal string lenght
DomoticaRob
Domoticz version: V4.9700
Equal string lenght
Post by DomoticaRob »
I want that the strings have the same lenght:
--This is what I want:
--[123     ]
--[1234    ]
--[     456]
--[    3456]
--This is what I get:
--[123 ]
--[1234 ]
--[ 456]
--[ 3456]
stringOud="123"
stringNieuw = stringLengte(stringOud,6,"R")
print(stringNieuw)
stringOud="1234"
print(stringNieuw)
stringOud="456"
stringNieuw = stringLengte(stringOud,6,"L")
print(stringNieuw)
stringOud="3456"
print(stringNieuw)
function stringLengte(stringOud,lengteGewenst,kantOpvullen)
    local stringNieuw=""
    local lengteBasis=string.len(stringOud)
    local lengteRest=lengteGewenst-lengteBasis
    if kantOpvullen=="R" then
        stringNieuw=(stringOud..string.rep(string.char(32),lengteRest))
    elseif kantOpvullen=="L" then
        stringNieuw=(string.rep(string.char(32),lengteRest)..stringOud)
    return stringNieuw
The problem with character 32 (space) is that in a print or io.write you don't get all the spaces you want.
I want it because I want a file output with horizontal equal distances.
What is the solution?
jvdz
Domoticz version: 4.107
Re: Equal string lenght
Post by jvdz »
Yes they are all the same length when I run your posted test script, but you probably check it with a proportional font in stead of a fixed font like courier?
Do you want to display it in a webpage or something?
Jos
DomoticaRob
Hey Jos,
I also have this problem in the Domoticz log.
Unfortunately I can't attach pictures anymore to this forum, I get this error code:
ERROR
Sorry, the board attachment quota has been reached.
Otherwise I could show you a screendump.
When I use for example character 46, that is a dot [.] then it's ok. So all the distances are equal. But not with character 32 [space].
The output of my script is a textfile. When I use it in a texteditor with non-proportional font I also don't get equal distances.
DomoticaRob wrote: Tuesday 18 December 2018 23:54 I also have this problem in the Domoticz log.
/quote]
Tested your code in a dzVents script (output to log) and I see the expected result.
2018-12-19 01:39:31.622  Status: dzVents: [123   ]
2018-12-19 01:39:31.622  Status: dzVents: [1234  ]
2018-12-19 01:39:31.622  Status: dzVents: [   456]
2018-12-19 01:39:31.622  Status: dzVents: [  3456]
jvdz
Post by jvdz »
DomoticaRob wrote: Tuesday 18 December 2018 23:54 Hey Jos,
So you are looking at the Webpage that displays the Domoticz log? Html will not display multiple spaces unless they are   (None breaking spaces)
When you look at the actual domoticz,log file with an editor that uses a none proportional font, you will see they are there. :)
Jos
DomoticaRob
You're damn right.
Problem solved.
Thanks everybody.
