conbee and deconz in domoticz
Posted: Tuesday 18 December 2018 0:57
by tjabas
Hi!
i have som problems with setting up a conbee and deconz in domoticz.
i have managed to install deconz and i have connected some ikea lamps to decontz via a conbee stick, in deconz everything works good,
in domoticz i have added deconz as a phillips hue, and managed to pair it with deconz(the pair button)
but nothing comes up under devices.
the log doesnt show anything either, only this: 2018-12-18 00:55:46.021 Status: Philips Hue: Worker started.
what could be wrong?
Re: conbee and deconz in domoticz
Posted: Tuesday 18 December 2018 22:57
by Thorgal789
Wich one plugin/hardware are you using ?
The only plugin I know that works with deconz don't have this kind of log. They are like this one
2018-12-18 22:46:56.578 (deCONZ) ### Update device (deCONZ - Multi Sensor) : {'nValue': 0, 'sValue': '999', 'BatteryLevel': 95}
If all works fine in deCONZ, you have nothing to do with this plugin (nothing to add or pair), just start the plugin, it synchronise itself yours devices from deCONZ to Domoticz, and create all missing devices in device panel.
At startup you will see somthing like this
2018-12-18 22:55:43.834 (deCONZ) ### Request lights
2018-12-18 22:55:43.984 (deCONZ) ### Request sensors
2018-12-18 22:55:44.297 Status: (deCONZ) ### deCONZ ready
2018-12-18 22:55:44.297 Status: (deCONZ) ### Found X Operators, Y Sensors, Z Groups with W Ignored
Posted: Thursday 20 December 2018 1:31
by tjabas
Thanks for your answer,
I was using the latest stable version of domoticz, i had to install the latest beta for it to work, the lights from deconz didnt show in the stable version.
im using a conbee and deconz in a raspberry pi 3.
But is there a way to get the rgb light to change color?
im using an ikea rgb light, in deconz i can change the color but in domoticz its impossible to change it.
Posted: Thursday 20 December 2018 1:32
by tjabas
im using the phillips hue settings in domoticz
Posted: Thursday 20 December 2018 16:57
by Thorgal789
Posted: Thursday 20 December 2018 18:50
by tjabas
So it would be possible to change color with this plugin?`
Posted: Thursday 20 December 2018 18:58
by tjabas
i have installed the plugin after the installation guide, but the guide says to install it in domoticz/plugin folder, i only have domoticz/plugins folder, but i guess that it is the same, anyhow, after installation i cant see the deconz plugin in the hardware list, what is it called? should i look for deconz?
Posted: Thursday 20 December 2018 19:10
by tjabas
well now i managed to get that plugin installed, but i cant get any connection to deconz, would the setting be the same as for phillips hue plugin?
Posted: Thursday 20 December 2018 19:32
by tjabas
now it think that i got it working ,but i dont see anything in devices. i get this in the log:
2018-12-20 19:31:31.842 Status: (deconz) Stop directive received.
2018-12-20 19:31:31.842 Status: (deconz) Exiting work loop.
2018-12-20 19:31:31.930 Status: (deconz) onDisconnect called for Name: 'deCONZ_WebSocket', Transport: 'TCP/IP', Protocol: 'None', Address: '192.168.1.119', Port: '8088', Baud: -1, Connected: False
2018-12-20 19:31:31.930 Error: CConnection_disconnect, disconnection request from 'deconz' ignored. Transport does not exist.
Posted: Friday 21 December 2018 15:36
by Thorgal789
Solution on the first post you have make.
Posted: Friday 21 December 2018 15:43
by tjabas
Thanks for your answers.
i finally got it working, the solution was to install both the deconz and phillips hue in hardware, then pair phillips hue with deconz, then copy the generated key and paste it into the deconz hardware manager.
Posted: Friday 21 December 2018 15:46
by Thorgal789
IDK what You have done, but it's not correct.
Your API key in deconz was bad. You just need to generate a good one.
Philips hue is a plugin and deconz an other, nothing to see.
