MQTT mosquitto problems
rednas
Post by rednas »
I am trying to make zigbee2mqtt working on my raspberry pi.
I installed mosquitto and zigbee2mqtt, but it looks like my mosquitto isn't working right.
Trying to test mosquitto with mosquitto_sub and mosquitto_pub throws me this error: Error: Connection refused
However, when I first type mosquitto -d, it starts to work. But in the way I want it to use it should start automatically and not by first giving that command.
Does someone know how to fix this?
SweetPants
Re: MQTT mosquitto problems
Post by SweetPants »
When installed, there should be a file called mosquitto.service in /etc/systemd/system
If that is the case, start it with sudo systemctl start mosquitto.service
This should start the service, even after a reboot
rednas
Post by rednas »
SweetPants wrote: Friday 14 December 2018 19:30 When installed, there should be a file called mosquitto.service in /etc/systemd/system
There is no such a file in that folder. So something must have gone wrong during installation?
How can I fix it?
rednas wrote: Saturday 15 December 2018 12:35 Something must have gone wrong during installation?
I installed mosquitto on my PI systems (debian Stretch) as follows
sudo wget http://repo.mosquitto.org/debian/mosquitto-repo.gpg.key
sudo apt-key add mosquitto-repo.gpg.key
sudo apt-get install mosquitto
sudo apt-get install mosquitto-clients
sudo update-rc.d mosquitto enable
sudo update-rc.d mosquitto defaults
sudo service mosquitto status
If you already did the first 4 steps then the last 3 steps should do the job. Otherwise uninstall and do all above steps.
rednas
Post by rednas »
I tried reinstalling it. However, my Domoticz stopped working when I enabled the Zigbee2MQTT hardware, so I went looking for errors etc.
I followed this once again: https://koenkk.github.io/zigbee2mqtt/ge ... 2mqtt.html
The page states:
Output should look like:
pi@raspberry:/opt/zigbee2mqtt $ systemctl status zigbee2mqtt.service
● zigbee2mqtt.service - zigbee2mqtt
   Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; disabled; vendor preset: enabled)
   Active: active (running) since Thu 2018-06-07 20:27:22 BST; 3s ago
 Main PID: 665 (npm)
   CGroup: /system.slice/zigbee2mqtt.service
           ├─665 npm
           ├─678 sh -c node index.js
           └─679 node index.js
Jun 07 20:27:22 raspberry systemd[1]: Started zigbee2mqtt.
Jun 07 20:27:23 raspberry npm[665]: > [email protected] start /opt/zigbee2mqtt
Jun 07 20:27:23 raspberry npm[665]: > node index.js
Jun 07 20:27:24 raspberry npm[665]: 2018-6-7 20:27:24 INFO Starting zigbee-shepherd
Jun 07 20:27:25 raspberry npm[665]: 2018-6-7 20:27:25 INFO zigbee-shepherd started
However, this is what I get:
pi@RP-Domoticz:~$ systemctl status zigbee2mqtt.service
   Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; enabled)
   Active: active (running) since Thu 2019-01-10 16:11:08 CET; 8min ago
 Main PID: 606 (npm)
           ├─606 npm
           ├─886 sh -c node index.js
           └─887 node index.js
I am missing these log lines and the Loaded part is different as well.
What am I doing wrong?
