Qubino Flush RGBW dimmer config wrong?
Posted: Thursday 13 December 2018 19:35
Hi all!
First, I am a newbie in this field so please excuse me if I'm posting this in the wrong end of the Internet.
I'm running Domoticz on a RPi using an Aoetec Z-stick gen 5 as controller for Zwave nodes. I have a Qubino Flush RBGW dimmer plus (ZMNHWD1) for controlling a RGBW LED strip.
I understand that Domoticz uses Open-Zwave to communicate with the Z-stick and this is probably a Open-zwave problem, but I find no forum for open-zwave except for developers, and that's way over my head, so please foregive me if I'm in the wrong place, but I could use some help here.
If I understand it right there is an XML-file that controls the config menu that shows up for the dimmer in Domoticz. It's just that the parameters in the XML file for the ZMNHWD1 doesn'nt match the configuration parameters stated in the extended user manual from Qubino.
In the Qubino manual parameter 1-4 configures the corresponding channel (RGBW) with a value 1 to 10. This value configures input switch type and "mode type" for one channel .
In the XML file parameter 1 is a general configuration of "input switch type" with only two different values. Parameter 2 is "mode type" with three different values, and so on.
From what I can see the config XML doesn't match the specification for the dimmer, but I'm new to this. Can someone please have a look and see what's going on? The XML seems to be 2 years old, so maybe it's for an earlier version of the ZMNHWD1 dimmer and have never been updated?
XML-file on Github:
https://github.com/OpenZWave/open-zwave ... MNHWD1.xml
Qubino extended manual. (see section 14)
https://products.z-wavealliance.org/Pro ... ng_2.2.pdf
(EDIT: changes link to latest version of manual)
XML-file on Github:
