Lua Wake up light script
Posted: Tuesday 11 December 2018 22:49
With domoticz and a Philips Hue light i compiled this script to have a wakeuplight.
On this forum i saw a couple of other examples, but as fare as i know of, not with the following functions combined.
- the light turns on at 7h very dimm and the amount of light slowly increases
- the light only turns on monday till friday, saterday and sunday are excepted
- in the array holidays you can give a list of dates (like holidays, christmas etc) when the light should not wake you
If you have suggestions/improvements feel free.
time = os.date("*t")
weekday = (os.date("%w"))
datum = (os.date("%d/%m/%Y"))
weekday=tonumber(weekday)
datum = (os.date("%d-%m-%Y"))
holidays = {"25-12-2018", "26-12-2018","01-01-2019"}
x=0
--print(weekday)
if (time.hour==07) -- first if
then if -- second if
(weekday==1) or (weekday==7)
then print("07 uur en en weekend")
else print("07 uur en werkdag")
for key,value in ipairs(holidays) -- start loop
do
if (value==datum)
then
x=x+1
end -- end loop
if -- third if
(x>0) then print"it is a holiday" else
-- fourth if
--print"het is geen feestdag"
if (time.min ==01) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=1&iswhite=false" &')
elseif (time.min ==02) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=2&iswhite=false" &')
elseif (time.min ==03) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=3&iswhite=false" &')
elseif (time.min ==04) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=4&iswhite=false" &')
elseif (time.min ==05) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=5&iswhite=false" &')
elseif (time.min ==06) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=6&iswhite=false" &')
elseif (time.min ==07) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=7&iswhite=false" &')
elseif (time.min ==08) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=9&iswhite=false" &')
elseif (time.min ==09) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=10&iswhite=false" &')
elseif (time.min ==10) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=13&iswhite=false" &')
elseif (time.min ==11) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=16&iswhite=false" &')
elseif (time.min ==12) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=19&iswhite=false" &')
elseif (time.min ==13) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=22&iswhite=false" &')
elseif (time.min ==14) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=25&iswhite=false" &')
elseif (time.min ==15) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=27&iswhite=false" &')
elseif (time.min ==16) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=30&iswhite=false" &')
elseif (time.min ==17) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=35&iswhite=false" &')
elseif (time.min ==18) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=40&iswhite=false" &')
elseif (time.min ==19) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=45&iswhite=false" &')
elseif (time.min ==20) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=50&iswhite=false" &')
elseif (time.min ==21) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=55&iswhite=false" &')
elseif (time.min ==22) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=60&iswhite=false" &')
elseif (time.min ==23) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=65&iswhite=false" &')
elseif (time.min ==24) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=70&iswhite=false" &')
elseif (time.min ==25) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=75&iswhite=false" &')
elseif (time.min ==26) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=80&iswhite=false" &')
elseif (time.min ==27) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=85&iswhite=false" &')
elseif (time.min ==28) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=90&iswhite=false" &')
elseif (time.min ==29) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=95&iswhite=false" &')
elseif (time.min ==30) then os.execute('curl -s "http://192.168.1.85:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=2451&hue=454&brightness=100&iswhite=false" &')
elseif (time.min ==30) then commandArray['Lamp_name'] ='Off'
elseif (time.min ==35) then commandArray['Lamp_name'] ='Off'
elseif (time.min ==55) then commandArray['Lamp_name'] ='Off'
else print("do not wakeuplight")
end -- close third if
end -- close second if
else --print("het is geen 07 uur ")
