Zigbee2MQTT hardware "ready 2 go"
Posted: Monday 10 December 2018 23:26
by wifiminime
Is there a place/site where i can buy the Zigbee2MQTT hardware (CC2531 USB sniffer) that has already been programmed?
Seems a bit weird that everyone is buying a programmer + cable + CC2531 USB sniffer, while you only need the latter after programming it.
Or perhaps someone has a "Ready to Go"-spare to sell?
Thanks for reponse
Re: Zigbee2MQTT hardware "ready 2 go"
Posted: Tuesday 11 December 2018 5:24
by ben53252642
You really should be buying the programmer at the same time.
The project has updated the firmware many times already with improvements, Zigbee2MQTT is a rapidly developing and will soon move to Zigbee 3* which you would need the programmer to take advantage of if you flash it with the current Zigbee 1.2* firmware.
Personally I bought 3x CC2531 and the programming tool all at the same time, I'd suggest get the tool and a couple CC2531's so you have a spare if you need it.
They are pretty cheap, certainly a lot cheaper than buying a Z-Wave USB stick with the AU frequency, that's for sure.
Posted: Tuesday 11 December 2018 6:42
by Dlanor
wifiminime wrote:Hi,
I have the programmer so can help you when you order a sniffer!
