Accessing dzvents JSON Data Table
Wolfgang
Post by Wolfgang »
Hello ,
I've got two problems with the dzvents data format .
I'm reading data from a website which returns the data in json format like this :
"8700": {
"name": "Aussentemperatur",
"value": "7.8",
"unit": "°C",
"desc": "",
"dataType": 0
I'm replacing the "8700" item with "Temp" in the script because I cannot access the field named completely numeric .
But how can I get the value of the field "value" into a variable to fill it into a virtual sensor ?
Currently there is always a nil value seen in the log.
Current script snippet as follows :
		if (item.isTimer) then
			domoticz.openURL({
				url = 'http://192.168.252.226/JQ=8700',
				method = 'GET',
				callback = 'trigger', -- see httpResponses above.
		if (item.isHTTPResponse) then
			if (item.statusCode == 200) then
				if (item.isJSON) then
					local HeizungAussentemperaturString = domoticz.utils.toJSON(item.data)
					HeizungAussentemperaturString = string.gsub(HeizungAussentemperaturString,"8700","Temp")
					domoticz.log('-------------------------------------------------------------------------')
					domoticz.log(HeizungAussentemperaturString,domoticz.LOG_INFO)
					local HeizungAussentemperaturJSON = domoticz.utils.fromJSON(HeizungAussentemperaturString)
					domoticz.log(HeizungAussentemperaturJSON,domoticz.LOG_INFO)
					domoticz.log('------------------------------------')
					local HeizungAussentemperatur = HeizungAussentemperaturJSON.Temp.value
					domoticz.log(HeizungAussentemperatur,domoticz.LOG_INFO)
					--domoticz.log('Aussentemperatur : ' .. HeizungAussentemperatur)
					-- update some device in Domoticz
					domoticz.devices('Heizung Aussentemperatur').updateTemperature(HeizungAussentemperatur)
so currently the HeizungAussentemperatur variable has always a nil value in the debug log .
Any help on getting the temperature value to the variable would be fine ...
Re: Accessing dzvents JSON Data Table
Wolfgang wrote: Sunday 09 December 2018 17:06 I've got two problems with the dzvents data format .
"8700": {
"value": "7.8",
"unit": "°C",
"desc": "",
"dataType": 0
Hope this example help.
return  {
    on       = {    timer           =   { "every minute"    }},
    execute = function(dz)
        function deepdump( tbl )
            local checklist = {}
            local function innerdump( tbl, indent )
                checklist[ tostring(tbl) ] = true
                for k,v in pairs(tbl) do
                        print (indent .. tostring(k) .. " ===> value: ".. tostring(v)  )
                    if (type(v) == "table" and not checklist[ tostring(v) ]) then
                        innerdump(v,indent .. tostring(k) .. ".")
            innerdump( tbl, "Key: " )
        local testdata  ='{"8700": {"name": "Aussentemperatur","value": "7.8","unit": "°C","desc": "","dataType": 0}}'
        local myTable       = dz.utils.fromJSON(testdata)
        deepdump(myTable) -- use this function call to see the structure of your table
        print (myTable["8700"].value) -- myTable.8700.value does not work; this sugar syntax  can only be used with strings
Wolfgang
Post by Wolfgang »
thanks for the clarifying code. This was the hint I was searching for , it works now !
