LUA script set security status to .. by remote
Posted: Friday 07 December 2018 11:24
I have an strange problem.
In my domoticz-system (rpi3B+ with raspbian) I wanted to use the remote control (Aeontec Keyfob gen5) to switch between security panel alarm status: Disable, Arm Away, Arm Home. With some puzzling this is working well now with the following script:
This script is saved as device Lua.
Changing the status of Alarm by buttons works. But the log is showing the last status of the security panel instead of the new one.
What can I change in this script to fix this? Any tips?
if (devicechanged['remote-1'] == 'On') then
commandArray['Domoticz Security Panel'] = 'Arm Away'
print('### SecPanel: status changed to ' .. globalvariables['Security'])
if (devicechanged['remote-2'] == 'On') then
commandArray['Domoticz Security Panel'] = 'Arm Home'
if (devicechanged['remote-3'] == 'On') then
commandArray['Domoticz Security Panel'] = 'Disarm'
