Neo Coolcam wallplug sending multiple kWh measurements
bramski
Post by bramski »
I have some strange issues with one of my Neo Coolcam wall plugs.
All measurements of my different devices are sent to InfluxDB to be visualized in Grafana. Since a few weeks my visualizations are misbehaving.
The root cause seem to be my washing machine plug is reporting wrong measurements. I have checked the logs and see the following:
2018-12-07 10:08:31.653 (Zwave USB) General/kWh (kWh wasmachine)
2018-12-07 10:08:32.143 InfluxLink: value Usage,idx=730,name=kWh-wasmachine value=105100.000
2018-12-07 10:08:32.534 (Zwave USB) General/kWh (kWh wasmachine)
2018-12-07 10:08:33.638 (Zwave USB) General/kWh (kWh wasmachine)
2018-12-07 10:08:33.671 InfluxLink: value Usage,idx=730,name=kWh-wasmachine value=218290.000
2018-12-07 10:08:34.527 (Zwave USB) General/kWh (kWh wasmachine)
2018-12-07 10:08:34.701 InfluxLink: value Usage,idx=730,name=kWh-wasmachine value=30.000
You see the concerning wallplug is sending 3 different measurements withing 3 seconds and the values are all over the place.
Anyone experienced the same issue and know how to proceed?
gizmocuz
Re: Neo Coolcam wallplug sending multiple kWh measurements
Post by gizmocuz »
could you post a screenshot of the openzwave control panel ? does this sensor report kva also ?
bramski
Post by bramski »
Here is a screenshot of the OpenZwave configuration panel for the concerning device. Not sure how I can see if it reports kVa.
I am not experiencing any issues with my other Neo Coolcam plugs. I have 8 of them and some fibaro's.
Actually I did a factory reset of the plug a few minutes ago, will let you know if this solves the problem.
OpenZWave Control Panel.png (36.05 KiB) Viewed 884 times
lumjajo
Domoticz version: 4.10717
Post by lumjajo »
Hi maybe a stupid question, but how did you manage to get this open zwave configuration panel?
IS it runnin gon the raspi with domoticz (I assume so)
Many thanks
gizmocuz
Post by gizmocuz »
@lumjajo, from the openzwave hardware setup page, the drop down on the top right
