Update last seen time domoticz
pesa1234
Domoticz version: 2020.1
Post by pesa1234 »
Hi ,
I have a question:
Is there a possibility in domoticz to update last seen time of a thermostat setpoint to prevent it to blink in red in the GUI?
I would like to update just the time not the status, otherwise the script to control my Air Conditioner send command without do anything.
This is my script to control my AC:
      devices = {'AC Mode','AC Temp'},
      local mytemp = domoticz.devices('AC Temp')
      local ip = '192.168.181.177'
      if ((device.name == 'AC Mode' and device.changed) or
         (device.name == 'AC Temp' and device.changed)) then
        --domoticz.log('Device ' .. device.name .. ' ' ..device.state.. ' was changed', domoticz.LOG_INFO)
        if (device.name == 'AC Mode' and device.state == 'Off') then
            domoticz.openURL('http://' ..ip.. '/off')
            domoticz.log('http://' ..ip.. '/off', domoticz.LOG_INFO)
            domoticz.log('SPENTO', domoticz.LOG_INFO)
        if (device.name == 'AC Mode' and device.state == 'Auto') then
            domoticz.openURL('http://' ..ip.. '/auto?temp='..(mytemp.state)..'')
            domoticz.log('http://' ..ip.. '/auto?temp='..(mytemp.state)..'', domoticz.LOG_INFO)
            domoticz.log('ACCESO AUTO', domoticz.LOG_INFO)
        if (device.name == 'AC Mode' and device.state == 'Caldo') then
            domoticz.openURL('http://' ..ip.. '/caldo?temp='..(mytemp.state)..'')
            domoticz.log('http://' ..ip.. '/caldo?temp='..(mytemp.state)..'', domoticz.LOG_INFO)
            domoticz.log('ACCESO CALDO', domoticz.LOG_INFO)
        if (device.name == 'AC Mode' and device.state == 'Freddo') then
            domoticz.openURL('http://' ..ip.. '/freddo?temp='..(mytemp.state)..'')
            domoticz.log('http://' ..ip.. '/freddo?temp='..(mytemp.state)..'', domoticz.LOG_INFO)
            domoticz.log('ACCESO FREDDO', domoticz.LOG_INFO)
        if (device.name == 'AC Mode' and device.state == 'Dry') then
            domoticz.openURL('http://' ..ip.. '/deu')
            domoticz.log('http://' ..ip.. '/deu', domoticz.LOG_INFO)
            domoticz.log('ACCESO DEUMIDIFICATORE', domoticz.LOG_INFO)
        if (device.name == 'AC Temp' and device.changed) then
            local mysetup = domoticz.devices('AC Mode')
            if mysetup.state == 'Auto' then
            domoticz.log('ACCESO AUTO_TEMPVAR', domoticz.LOG_INFO)
            if mysetup.state == 'Caldo' then
            domoticz.log('ACCESO CALDO_TEMPVAR', domoticz.LOG_INFO)
            if mysetup.state == 'Freddo' then
            domoticz.log('ACCESO FREDDO_TEMPVAR', domoticz.LOG_INFO)
pesa1234
Re: Update last seen time domoticz
Post by pesa1234 »
Solved, changed script with auto update of setpoint
