Page 1 of 3
DZ Vents Light timer Help Please
Posted: Friday 30 November 2018 22:51
by alarm_guy1
I have the following DZ Vents, It is supposed to turn my kitchen light on if lux level is below 30 and motion is detected, (this works fine) However after 5mins if the detector has not activated then the light should go off, and if the detector detects motion then the light should stay on for a further 5 mins.
However the light just stays on..
Any help appreciated
keith
devices = {
"Kitchen MD Sensor",
"Kitchen Lights"
execute = function(dz, device)
local Sensor = dz.devices("Kitchen MD Sensor")
local Lux = dz.devices("Kitchen MD Lux").lux
local Lights = dz.devices ("Kitchen Lights")
if (Sensor.state == "On") and (Lights.state == "Off") and Lux < 30 then
Lights.switchOn()
elseif (Lights.state == "On") and Sensor.lastUpdate.minutesAgo > 1 then
Lights.switchOff().afterMin(5)
Re: DZ Vents Light timer Help Please
Posted: Saturday 01 December 2018 0:12
by waaren
alarm_guy1 wrote: Friday 30 November 2018 22:51
Try this one.
on = { devices = { "Kitchen MD Sensor" }},
execute = function(dz, item)
local Lights = dz.devices("Kitchen Lights")
if item.state == "On" and Lux < 30 then
Lights.cancelQueuedCommands()
Lights.switchOn().checkFirst()
Posted: Saturday 01 December 2018 0:26
by alarm_guy1
Thankyou,
I'll give it a try
cheers
Posted: Saturday 01 December 2018 2:28
by alarm_guy1
Just had a chance to test this and nothing happens and I get the following error
2018-12-01 01:24:33.535 Status: dzVents: Info: Handling events for: "Kitchen MD Sensor", value: "Off"
2018-12-01 01:24:33.535 Status: dzVents: Info: ------ Start internal script: Kitchen Lights DZ: Device: "Kitchen MD Sensor (Usb Controller)", Index: 192
2018-12-01 01:24:33.536 Status: dzVents: Error (2.4.6): There is no device with that name or id: Kitchen MD Lux
2018-12-01 01:24:33.536 Status: dzVents: Error (2.4.6): An error occured when calling event handler Kitchen Lights DZ
2018-12-01 01:24:33.536 Status: dzVents: Error (2.4.6): .../scripts/dzVents/generated_scripts/Kitchen Lights DZ.lua:5: attempt to index a nil value
2018-12-01 01:24:33.536 Status: dzVents: Info: ------ Finished Kitchen Lights DZ
Cheers
Posted: Saturday 01 December 2018 2:47
by alarm_guy1
I have checked all spellings and re-copied and pasted item names from devices
Posted: Saturday 01 December 2018 7:02
by waaren
alarm_guy1 wrote: Saturday 01 December 2018 2:28
Hi I added a couple of lines to see what happens during execution. Please change the two xxx in the script with the IDX numbers of the devices (without quotes). That might give a clue what is wrong.
logging = {
level = domoticz.LOG_DEBUG,
marker = "Kitchen motion"
local function logWrite(str,level)
dz.log(str,level or dz.LOG_DEBUG)
-- local Lux = dz.devices("Kitchen MD Lux").lux
local LuxDevice = dz.devices(xxx) -- <<<--- replace xxx by IDX of your Lux device
local Lux = LuxDevice.lux
-- local Lights = dz.devices("Kitchen Lights")
local Lights = dz.devices(xxx) -- <<<--- replace xxx by IDX of your Kitchen lights
logWrite("name of Lux device: " .. LuxDevice.name)
logWrite("name of Light : " .. Lights.name)
Posted: Saturday 01 December 2018 10:37
by alarm_guy1
Cheers
I will give it a test.
Although first impressions are it is functioning well.
entered kitchen, lights on
left kitchen lights off after 5 mins
entered kitchen lights on
left for 4 mins came back set timer on phone for 2 mins Lights stayed on.
Left room and lights went out.
The true test will be tonight when we are cooking as to whether we will be plunged into darkness..... as usual...
Many many thanks
Posted: Monday 03 December 2018 19:40
by alarm_guy1
Hi thanks for the continued support, unfortunately we are still plunged into darkness after 5 mins, is there anyway to have every activation of the detector restart the 5 min timer.
many many thanks
Posted: Monday 03 December 2018 20:00
by waaren
alarm_guy1 wrote: Monday 03 December 2018 19:40
many many thanks
Sure. If this not work as expected, I would be very interested in the loglines created by this script.
logging = {
logWrite(LuxDevice.name .. " ==>> Lux: " .. Lux )
logWrite(Lights.name .. " ==>> State: " .. Lights.state)
if Lux < 30 then
Lights.switchOn()
Posted: Monday 03 December 2018 20:10
by alarm_guy1
A snippet from the log:
2018-12-03 17:43:59.067 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-12-03 17:44:29.248 Status: dzVents: Info: Handling events for: "Kitchen MD Sensor", value: "Off"
2018-12-03 17:44:29.248 Status: dzVents: Info: Kitchen motion: ------ Start internal script: Kitchen Lights DZ: Device: "Kitchen MD Sensor (Usb Controller)", Index: 192
2018-12-03 17:44:29.252 Status: dzVents: Debug: Kitchen motion: Processing device-adapter for Kitchen MD Lux: Lux device adapter
2018-12-03 17:44:29.254 Status: dzVents: Debug: Kitchen motion: Processing device-adapter for Kitchen Lights: Switch device adapter
2018-12-03 17:44:29.254 Status: dzVents: Debug: Kitchen motion: name of Lux device: Kitchen MD Lux
2018-12-03 17:44:29.255 Status: dzVents: Debug: Kitchen motion: name of Light : Kitchen Lights
2018-12-03 17:44:29.255 Status: dzVents: Info: Kitchen motion: ------ Finished Kitchen Lights DZ
2018-12-03 17:44:44.082 Status: dzVents: Info: Handling events for: "Kitchen MD Sensor", value: "On"
2018-12-03 17:44:44.083 Status: dzVents: Info: Kitchen motion: ------ Start internal script: Kitchen Lights DZ: Device: "Kitchen MD Sensor (Usb Controller)", Index: 192
2018-12-03 17:44:44.085 Status: dzVents: Debug: Kitchen motion: Processing device-adapter for Kitchen MD Lux: Lux device adapter
2018-12-03 17:44:44.088 Status: dzVents: Debug: Kitchen motion: Processing device-adapter for Kitchen Lights: Switch device adapter
2018-12-03 17:44:44.088 Status: dzVents: Debug: Kitchen motion: name of Lux device: Kitchen MD Lux
2018-12-03 17:44:44.088 Status: dzVents: Debug: Kitchen motion: name of Light : Kitchen Lights
2018-12-03 17:44:44.089 Status: dzVents: Debug: Kitchen motion: Constructed timed-command: On
2018-12-03 17:44:44.089 Status: dzVents: Debug: Kitchen motion: Constructed timed-command: Off
2018-12-03 17:44:44.091 Status: dzVents: Debug: Kitchen motion: Constructed timed-command: Off AFTER 300 SECONDS
2018-12-03 17:44:44.091 Status: dzVents: Info: Kitchen motion: ------ Finished Kitchen Lights DZ
2018-12-03 17:44:44.301 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-12-03 17:45:28.451 Status: OpenZWave: Received timeout notification from HomeID: 3246928100, NodeID: 8 (0x08)
2018-12-03 17:51:04.161 Status: dzVents: Info: Handling events for: "Kitchen MD Sensor", value: "Off"
2018-12-03 17:51:04.161 Status: dzVents: Info: Kitchen motion: ------ Start internal script: Kitchen Lights DZ: Device: "Kitchen MD Sensor (Usb Controller)", Index: 192
2018-12-03 17:51:04.164 Status: dzVents: Debug: Kitchen motion: Processing device-adapter for Kitchen MD Lux: Lux device adapter
2018-12-03 17:51:04.167 Status: dzVents: Debug: Kitchen motion: Processing device-adapter for Kitchen Lights: Switch device adapter
2018-12-03 17:51:04.167 Status: dzVents: Debug: Kitchen motion: name of Lux device: Kitchen MD Lux
2018-12-03 17:51:04.167 Status: dzVents: Debug: Kitchen motion: name of Light : Kitchen Lights
2018-12-03 17:51:04.167 Status: dzVents: Info: Kitchen motion: ------ Finished Kitchen Lights DZ
2018-12-03 17:51:04.701 Status: dzVents: Info: Handling events for: "Kitchen MD Sensor", value: "On"
2018-12-03 17:51:04.701 Status: dzVents: Info: Kitchen motion: ------ Start internal script: Kitchen Lights DZ: Device: "Kitchen MD Sensor (Usb Controller)", Index: 192
2018-12-03 17:51:04.704 Status: dzVents: Debug: Kitchen motion: Processing device-adapter for Kitchen MD Lux: Lux device adapter
2018-12-03 17:51:04.708 Status: dzVents: Debug: Kitchen motion: Processing device-adapter for Kitchen Lights: Switch device adapter
2018-12-03 17:51:04.708 Status: dzVents: Debug: Kitchen motion: name of Lux device: Kitchen MD Lux
2018-12-03 17:51:04.708 Status: dzVents: Debug: Kitchen motion: name of Light : Kitchen Lights
2018-12-03 17:51:04.708 Status: dzVents: Debug: Kitchen motion: Constructed timed-command: On
2018-12-03 17:51:04.709 Status: dzVents: Debug: Kitchen motion: Constructed timed-command: Off
2018-12-03 17:51:04.710 Status: dzVents: Debug: Kitchen motion: Constructed timed-command: Off AFTER 300 SECONDS
2018-12-03 17:51:04.710 Status: dzVents: Info: Kitchen motion: ------ Finished Kitchen Lights DZ
2018-12-03 17:51:04.953 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-12-03 17:53:32.655 Status: OpenZWave: Received timeout notification from HomeID: 3246928100, NodeID: 8 (0x08)
2018-12-03 17:54:14.087 Status: dzVents: Info: Handling events for: "Kitchen MD Sensor", value: "Off"
2018-12-03 17:54:14.087 Status: dzVents: Info: Kitchen motion: ------ Start internal script: Kitchen Lights DZ: Device: "Kitchen MD Sensor (Usb Controller)", Index: 192
2018-12-03 17:54:14.092 Status: dzVents: Debug: Kitchen motion: Processing device-adapter for Kitchen MD Lux: Lux device adapter
2018-12-03 17:54:14.096 Status: dzVents: Debug: Kitchen motion: Processing device-adapter for Kitchen Lights: Switch device adapter
2018-12-03 17:54:14.097 Status: dzVents: Debug: Kitchen motion: name of Lux device: Kitchen MD Lux
2018-12-03 17:54:14.097 Status: dzVents: Debug: Kitchen motion: name of Light : Kitchen Lights
2018-12-03 17:54:14.097 Status: dzVents: Info: Kitchen motion: ------ Finished Kitchen Lights DZ
2018-12-03 17:56:11.651 Status: dzVents: Info: Handling events for: "Kitchen MD Sensor", value: "On"
2018-12-03 17:56:11.652 Status: dzVents: Info: Kitchen motion: ------ Start internal script: Kitchen Lights DZ: Device: "Kitchen MD Sensor (Usb Controller)", Index: 192
2018-12-03 17:56:11.654 Status: dzVents: Debug: Kitchen motion: Processing device-adapter for Kitchen MD Lux: Lux device adapter
2018-12-03 17:56:11.657 Status: dzVents: Debug: Kitchen motion: Processing device-adapter for Kitchen Lights: Switch device adapter
2018-12-03 17:56:11.657 Status: dzVents: Debug: Kitchen motion: name of Lux device: Kitchen MD Lux
2018-12-03 17:56:11.657 Status: dzVents: Debug: Kitchen motion: name of Light : Kitchen Lights
2018-12-03 17:56:11.658 Status: dzVents: Debug: Kitchen motion: Constructed timed-command: On
2018-12-03 17:56:11.658 Status: dzVents: Debug: Kitchen motion: Constructed timed-command: Off
2018-12-03 17:56:11.659 Status: dzVents: Debug: Kitchen motion: Constructed timed-command: Off AFTER 300 SECONDS
2018-12-03 17:56:11.659 Status: dzVents: Info: Kitchen motion: ------ Finished Kitchen Lights DZ
2018-12-03 17:56:11.871 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-12-03 17:57:00.332 Status: dzVents: Info: Handling events for: "Kitchen MD Sensor", value: "Off"
2018-12-03 17:57:00.333 Status: dzVents: Info: Kitchen motion: ------ Start internal script: Kitchen Lights DZ: Device: "Kitchen MD Sensor (Usb Controller)", Index: 192
2018-12-03 17:57:00.337 Status: dzVents: Debug: Kitchen motion: Processing device-adapter for Kitchen MD Lux: Lux device adapter
2018-12-03 17:57:00.342 Status: dzVents: Debug: Kitchen motion: Processing device-adapter for Kitchen Lights: Switch device adapter
2018-12-03 17:57:00.342 Status: dzVents: Debug: Kitchen motion: name of Lux device: Kitchen MD Lux
2018-12-03 17:57:00.342 Status: dzVents: Debug: Kitchen motion: name of Light : Kitchen Lights
2018-12-03 17:57:00.343 Status: dzVents: Info: Kitchen motion: ------ Finished Kitchen Lights DZ
2018-12-03 17:57:01.766 Status: dzVents: Info: Handling events for: "Kitchen MD Sensor", value: "On"
2018-12-03 17:57:01.766 Status: dzVents: Info: Kitchen motion: ------ Start internal script: Kitchen Lights DZ: Device: "Kitchen MD Sensor (Usb Controller)", Index: 192
2018-12-03 17:57:01.771 Status: dzVents: Debug: Kitchen motion: Processing device-adapter for Kitchen MD Lux: Lux device adapter
2018-12-03 17:57:01.775 Status: dzVents: Debug: Kitchen motion: Processing device-adapter for Kitchen Lights: Switch device adapter
2018-12-03 17:57:01.776 Status: dzVents: Debug: Kitchen motion: name of Lux device: Kitchen MD Lux
2018-12-03 17:57:01.776 Status: dzVents: Debug: Kitchen motion: name of Light : Kitchen Lights
2018-12-03 17:57:01.776 Status: dzVents: Debug: Kitchen motion: Constructed timed-command: On
2018-12-03 17:57:01.777 Status: dzVents: Debug: Kitchen motion: Constructed timed-command: Off
2018-12-03 17:57:01.777 Status: dzVents: Debug: Kitchen motion: Constructed timed-command: Off AFTER 300 SECONDS
2018-12-03 17:57:01.777 Status: dzVents: Info: Kitchen motion: ------ Finished Kitchen Lights DZ
2018-12-03 17:57:01.992 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-12-03 17:57:32.052 Status: dzVents: Info: Handling events for: "Kitchen MD Sensor", value: "Off"
2018-12-03 17:57:32.052 Status: dzVents: Info: Kitchen motion: ------ Start internal script: Kitchen Lights DZ: Device: "Kitchen MD Sensor (Usb Controller)", Index: 192
2018-12-03 17:57:32.055 Status: dzVents: Debug: Kitchen motion: Processing device-adapter for Kitchen MD Lux: Lux device adapter
2018-12-03 17:57:32.059 Status: dzVents: Debug: Kitchen motion: Processing device-adapter for Kitchen Lights: Switch device adapter
2018-12-03 17:57:32.060 Status: dzVents: Debug: Kitchen motion: name of Lux device: Kitchen MD Lux
2018-12-03 17:57:32.060 Status: dzVents: Debug: Kitchen motion: name of Light : Kitchen Lights
2018-12-03 17:57:32.060 Status: dzVents: Info: Kitchen motion: ------ Finished Kitchen Lights DZ
The wife was on me as soon as i walked in the door (Not in a good way)
that she was being plunged into darkness every 5 or 10 mins
cheers
Posted: Monday 03 December 2018 22:02
by akamming
i had similar problems creating a lighting script. I found out that if you user forMin() or afterMin() clausules: The scheduled commands remain scheduled if you give new commands to the switch as a result to a new event creating weird behaviour. So you should always cancel scheduled eventes using cancelQueuedCommands() before you give a new switch commands.
For this purpose i created 2 functions in my code for turning on and off lights
local Timeout=60 -- numer of mins after which the lights should go out if no motion is detected
function SwitchOn(name)
-- get device from name
local device=domoticz.devices(name)
-- turning off scheduled commands
device.cancelQueuedCommands()
if (device.active) then
domoticz.log("Device["..device.name.."] already active, disabling scheduled commands and set new timeout["..Timeout.."]",domoticz.LOG_DEBUG)
device.switchOff().afterMin(Timeout).silent()
domoticz.log("Device["..device.name.."] is off, turning on with scheduled turnoff timeout["..Timeout.."]",domoticz.LOG_DEBUG)
device.switchOn().forMin(Timeout).silent()
function SwitchOff(name)
-- disable queued commands
domoticz.log("Device["..device.name.."] is active, turning off",domoticz.LOG_DEBUG)
device.switchOff(device).silent()
domoticz.log( "Device["..device.name.."] is off, do nothing", domoticz.LOG_DEBUG)
if you incorporate this in your code it should work fine...
Posted: Monday 03 December 2018 22:07
by alarm_guy1
Thankyou. I will try tomorrow night as I'm currently out cheers, I'll let u know how I get on
Posted: Monday 03 December 2018 22:09
by waaren
alarm_guy1 wrote: Monday 03 December 2018 20:10
cheers
Excellent way of convincing your wife that you really need a test environment
Based on the log this should be better for your situation
logging = {
logWrite(item.name .. " ==>> State: " .. item.state)
if Lux < 30 and item.state == "On" then
elseif item.state == "Off" and Lights.state == "On" then
Lights.switchOff().afterSec(300)
Posted: Tuesday 04 December 2018 7:41
by alarm_guy1
Thankyou, I have swapped to the new script, seemed ok on breakfast duties, however the wife may cook for me tonight so, the moment I walk in the door we will know.... i'll keep you posted
Re: DZ Vents Light timer Help Please [Solved]
Posted: Wednesday 12 December 2018 22:36
by alarm_guy1
Sorry for the delay, but we have not been in the kitchen recently for an extended period of time, but I would like to say a whole hearted big THANKYOU for the assistance and code as it appears to be functioning as expected.
THANKYOU
Posted: Saturday 01 February 2020 14:50
by Tamil112
Hi waaren,
is there a possibility that when i change de dim level manually that when there is a movement again that the manually chosen dim level stays like this?
i tried it do it with the wiki but unfortunately i could not figure this out
hope you can help me
waaren wrote: Monday 03 December 2018 22:09
cheers
logging = {
Posted: Saturday 01 February 2020 14:56
by waaren
Tamil112 wrote: Saturday 01 February 2020 14:50
Sorry but I don't understand what you want. I don't get the relation with the example you attached either so please elaborate and explain in detail what you want and what you tried so far.
Posted: Saturday 01 February 2020 18:11
by alarm_guy1
I think what he is saying, is if you go into the room and the light comes on say 40%, and you subsequently dim that light to say 20%, when movement is detected the light will come back on at 40%, is there a way to make it come back on at the last dimmed level.. I THINK
Posted: Saturday 01 February 2020 20:44
by Tamil112
Yes that's what I mean
alarm_guy1 wrote: Saturday 01 February 2020 18:11
So when it turns on with motion and lux and when a user decide to dim or brighter manually that the level last used level stays on after there is movement with the pir
Posted: Sunday 02 February 2020 2:15
by waaren
Tamil112 wrote: Saturday 01 February 2020 20:44
OK. If I understand correctly what you need... Below should do it. (but untested)
local PIR = 'PIR' -- change to name of your PIR
local light = 'light' -- change to name of your light
local lux = 'lux' -- change to name of your lux device
return
on =
devices =
PIR,
light,
logging =
marker = 'memorize state',
data =
lastLevel = { initial = 0 },
local PIR = dz.devices(PIR)
local light = dz.devices(light)
local lux = dz.devices(lux).lux
if item == light then
if light.active then
dz.data.lastLevel = light.level
dz.data.lastLevel = 'Off'
return
if item.active then
if lux < 30 then
light.setLevel(99).silent()
elseif tostring(dz.data.lastLevel) == 'Off' then
light.cancelQueuedCommands()
light.switchOff().afterSec(300).checkFirst().silent()
light.setLevel(dz.data.lastLevel).afterSec(300).silent()
