433mhz sonoff bridge with tasmota not working
Posted: Wednesday 28 November 2018 20:12
Hello.
I didn't post many at this moment but now i found it is time to ask you people something.
I bought a sonoff 433mhz bridge because i want to use it with klick aa klick uit modules here in the netherlands.
Now i use the sonoff touch wall mounts and this is working perfect with mqqt.
Now the problem is that i need this Klickaan module in the hallway with the light upstares.
It is an hotel switch ( don't know the english word) but if you put the light on downstears you can put it off upstears.
The problem is i cannot use the touch wallmount upstears because of the combined electric socket with lightswitch.
So my idea was to put this module behind this switch in the wall and let it comunnicate through the brudge with domoticz server.
If this works i will find more things to do with it for sure but first this.
What i did so far,
I was thinking i try first to but the light on with an 433 mhz remote what i bought at aliexpress.
I learned the switch to the bridge and if i press the buttons on it i see short red light flash on the bridge and in the console i see the rfkey1 and rfkey2 with the data what belongs to it.
This is working.
I can put the line in the switch to on action and off action.
If i put the light on or of i see on the bridge the red light flashing that it receives the data.
But i need the traffic other way around.
How do i do this?
gr Peter
What i did so far,
This is working.
How do i do this?
gr Peter
