[SOLVED] updateSetPoint function in DzVents
Sapp1123
Post by Sapp1123 »
Hey everyone,
im very new to LUA and DzVents.
I have a bit of trouble to undersand why the following Script is not working:
		devices = {
			'Test Heizung'                            -- a dummy switch
		variables = {
		TH = 'Test Heizung'
	execute = function(domoticz, TH)
	    local Setpoint = domoticz.devices('Setpoint') -- a Setpoint
	    if(TH == 'On') then
	        Setpoint.updateSetPoint(16)                -- Setpoint should be 16°C when switch = on
		domoticz.log(Setpoint.setPoint)                 -- Log the new setPoint
I want to change the thermostat Setpoint to 16°C when toggleing the switch to on.
Log output is:
 2018-11-27 08:03:48.903 Status: User: admin initiated a switch command (48/Test Heizung/On)
2018-11-27 08:03:49.044 Status: dzVents: Info: Handling events for: "Test Heizung", value: "On"
2018-11-27 08:03:49.045 Status: dzVents: Info: ------ Start internal script: Heizungscript: Device: "Test Heizung (Switches)", Index: 48
2018-11-27 08:03:49.045 Status: dzVents: Info: 19
2018-11-27 08:03:49.045 Status: dzVents: Info: ------ Finished Heizungscript
would appreciate any help.
Last edited by Sapp1123 on Tuesday 27 November 2018 19:07, edited 1 time in total.
Re: updateSetPoint function in DzVents
Sapp1123 wrote: Tuesday 27 November 2018 9:42 I have a bit of trouble to understand why the following Script is not working:
I want to change the thermostat Setpoint to 16°C when toggling the switch to on.
See comments in script below.
            on =    {   devices     =   { 'Test Heizung'    },                 -- a dummy switch
                        variables   =   { 'Test Heizung'    },                 -- Not sure what you want with this trigger variable ?
                    },                                                         -- As it is not used in the script
    execute = function(domoticz, item )                                        -- item can be the device or the variable
        -- they are both collections (tables)
        if item.state == 'On' then
        -- the log statement below does show the the setpoint as it was before execution of the script. The new setpoint is
        -- only visible to dzVents in a next execution of a script. This is because everyrhing is passed to the script in the function call
        -- as first parameter ====>> function (domoticz,item)
Sapp1123
Post by Sapp1123 »
At first, thanks for the help, i got the script running. The mistake was "if(TH == 'On') instead of if(TH.state == 'On')
		devices = {
			'Test Heizung'
		variables = {
		TH = 'Test Heizung'					-- To use TH instead of "Test Heizung" beause the compiler seems
	 },								--to have trouble with the spacing in device names
	execute = function(domoticz, TH)			-- TH used here
	    if(TH.state == 'On') then
One more Question, how can i display the new Setpoint in the log?
Sapp1123 wrote: Tuesday 27 November 2018 13:23 One more Question, how can i display the new Setpoint in the log?
in your script the TH in execute = function(domoticz, TH) is not a Lua var with the string "Test Heizung" but in fact the device that triggered the script with all attributes and functions
See wiki on variables =
I never encountered a problem with spacing in device names, nor with Lua nor with dzVents.
You can see the result of the updateSetPoint in the log , in the Gui or when you trigger the script again. See below
        devices = {
        'Test Heizung', 'Setpoint'
        variables = {
    execute = function(domoticz, TH, info)            -- TH used here
        domoticz.log('Script ' .. info.scriptName .." is triggered by " .. TH.name  )
        if TH.name == 'SetPoint' then
            domoticz.log('setpoint of device ' .. TH.name .." is now" .. TH.setpoint  )
        elseif TH.state == 'On' then
            domoticz.log(TH.name .." is now On; setting Setpoint")
        elseif TH.state == 'Off' then
            domoticz.log(TH.name .." is now Off; no further action " )
Sapp1123
Post by Sapp1123 »
Thanks a lot.
