Where are Lua scripts stored
HFman
Domoticz version: V4.1174
Post by HFman »
If you write the Lua scripts in domoticz, where does domoticz store them ?
I don't see them in "scripts/Lua" folder.
I would like to copy my old scripts form my old domoticz... but can't find them back..
Raspberry PI 3 - Opentherm Gateway + ESP8826 - EvoHome - ESPEasy CO2 + Fancontrol - RF-Link - zigbee2mqqt -
Re: Where are Lua scripts stored
HFman wrote: Sunday 25 November 2018 13:05 If you write the Lua scripts in domoticz, where does domoticz store them ?
Internal Lua scripts are now in the domoticz.db database in table EventMaster. Don't know if that also the case for your (previous) version.
HFman
Post by HFman »
Thanks.. so sincd the database is corupt.. i means i lost them.. :( (yes.. i know i should back up.. )
HFman wrote: Monday 26 November 2018 23:22 Thanks.. so sincd the database is corupt.. i means i lost them.. :( (yes.. i know i should back up.. )
How corrupt is your DB ? Are you sure it is beyond repair ?
HFman
Post by HFman »
sqlite say "can't read file". Any programm's to "repair" it ?
HFman wrote: Monday 26 November 2018 23:46 sqlite say "can't read file". Any programm's to "repair" it ?
Maybe not programs but certainly methods. Check this and scroll down to the solution with the replaced header.
It might work and depending on how much effort is needed to rebuild your database (including Lua scripts) it might be worth to invest some time.
