Esp8266 + WS2812 Strip Led + Domoticz
Posted: Friday 23 November 2018 11:48
by vrega
i've read on forum about some projects to integrate the WS2812 RGB led strip with Domoticz but i've not found a WiKi or tutorial on how to integrate it with Domoticz.
Can someone reassume the steps to make it work?
Re: Esp8266 + WS2812 Strip Led + Domoticz
Posted: Friday 23 November 2018 14:49
by gizmocuz
Should be working fine using MySensors
Posted: Friday 23 November 2018 15:50
by vrega
How to integrate it with domoticz? What's the hardware to use to make it work?
Do i need the gateway? is there a way to use only esp8266 (with espeasy inside)?
Posted: Thursday 10 January 2019 19:05
by B7en9
Posted: Friday 02 August 2019 18:48
by ledfreak3d
yep but those are not neopixels
Posted: Thursday 31 October 2019 7:45
by MaffeMuis
ledfreak3d wrote: Friday 02 August 2019 18:48
Your still searching? I got a working version. True mqtt, domoticz and nice scenes. That you can build yourself and run with 6 zones.
Posted: Friday 01 November 2019 14:38
by gerbenvanasselt
Hey Guys, did you use esp easy version to control the 12v rgb strip? I want to use it combined with tasmota. Does anyone have experience with this setup and tasmota?
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
Posted: Friday 01 November 2019 17:47
by snellejellep
use wled with the plugin. easy and works flawlessly for me
Posted: Friday 01 November 2019 21:01
by gerbenvanasselt
snellejellep wrote:use wled with the plugin. easy and works flawlessly for me
Will try when Ali delivers. Do you know if you can have two white LEDs as well instead of rgbw?
Posted: Friday 01 November 2019 21:11
by snellejellep
I dont know, you should check the wled github for that
Verstuurd vanaf mijn SM-G975F met Tapatalk
Posted: Saturday 21 December 2019 18:50
by twoenter
Guys I've translated my dutch article about RGB ledstrips and domoticz to English for you.
See
https://www.twoenter.nl/blog/en/domotic ... -domoticz/
