dzVents os.execute not executing command [Solved]
Posted: Thursday 22 November 2018 10:07
by MikeF
I'm running Domoticz (v4.9700) on a RPi, and I'm trying to control powered speakers on a separate RPi using an mpc playlist.
It works if I run the following at the command line:
sshpass -p <password> ssh pi@<second RPi url> mpc play 1
I've created a selector switch and the following dzVents script:
-- This script plays a streaming radio URL when the device is changed
-- It passes an mpc command to another RPi using sshpass and ssh
		devices = { 'Kitchen radio' }
	execute = function(dz)
	local level   = dz.devices("Kitchen radio").rawData[1]
	level = level / 10
	local base = "sshpass -p <password> ssh pi@<second RPi url> mpc play "
	if level >= 1 and level <= 7 then
		cmd = base .. level
		print (cmd)
		os.execute(cmd)
However, this appears to do nothing! (I can run the command displayed in the log at the command line OK.)
Re: dzVents os.execute not executing command
Posted: Thursday 22 November 2018 19:32
by waaren
MikeF wrote: Thursday 22 November 2018 10:07 Hi,
Can you try with this. It should display what is happening and the returnCode of you command.
    on = { devices = { 'Kitchen radio' }},
    logging =   {   level      =   domoticz.LOG_DEBUG,
                    marker     =   "sshPass"    },
    execute = function(dz, item, info )
        _G.logMarker             = info.scriptName                  -- sets the logmarker for dz.log
        local function logWrite(str,level)
            dz.log(str,level or dz.LOG_DEBUG)
        local function osExecute(cmd)
            local fileHandle     = assert(io.popen(cmd, 'r'))
            local commandOutput  = assert(fileHandle:read('*a'))
            local returnTable    = {fileHandle:close()}
            logWrite(commandOutput)
            logWrite(returnTable[3])
           return commandOutput,returnTable[3]            -- rc[3] contains returnCode
        level = level / 10
            cmd = base .. level
            osExecute(cmd)
Posted: Thursday 22 November 2018 20:03
by MikeF
Thanks, waaren.
This is what I get:
2018-11-22 18:54:29.098 Status: User: Admin initiated a switch command (276/Kitchen radio/Set Level)
2018-11-22 18:54:29.609 Status: dzVents: Info: sshPass: ------ Start external script: kitchen_radio2.lua: Device: "Kitchen radio (Dummy)", Index: 276
2018-11-22 18:54:29.890 Status: dzVents: Debug: kitchen_radio2:
2018-11-22 18:54:29.890 Status: dzVents: Debug: kitchen_radio2: 6
2018-11-22 18:54:29.890 Status: dzVents: Info: kitchen_radio2: ------ Finished kitchen_radio2.lua
Posted: Thursday 22 November 2018 20:56
by waaren
MikeF wrote: Thursday 22 November 2018 20:03 Thanks, waaren.
This is what I get:
Could it be the same as this or related to this Both pointing to something with Host public key is unknown
Re: dzVents os.execute not executing command [Solved]
Posted: Friday 23 November 2018 0:19
by MikeF
Thanks for these pointers.
The first doesn't work, even after adding the ssh fingerprint of the remote RPi through this command:
ssh-keyscan -H 192.168.0.9 >> ~/.ssh/known_hosts
However, the second one does! :D - by ignoring the check of the host public key, as follows:
sshpass -p <password> ssh [email protected] -o StrictHostKeyChecking=no -o UserKnownHostsFile=/dev/null mpc play 1
I still don't understand why the original sshpass command works at the command line, but not in dzVents (or a python or bash script, for that matter).
Thanks for your help! :D :D
