Device.changed not working as expected
delcara
Domoticz version: 4.10171
Post by delcara »
I've a dummy switch which is called "Beweging_Woonkamer". It's updated by 2 PIR's and is automatically switched off after 20 minutes. Now I have a light script for the dining room and sitting room and want to only execute the script if the status from "Beweging_Woonkamer" is changed (In my logic On > On is no status change). Because of the PIR's multiple On commands are sent if there is movement. I thought this could be achieved with the device.changed but this is not working. If I write the status of the device.change to the domzoticz log then its true even if I have multiple On commands and no change to off. Is my thinking wrong or does device.changed not work this way. Is there another solution to solve this?
    active = true,
	    devices =   {   'Beweging_Woonkamer',
	                    'Beweging_Eetkamer'     }
	execute = function(dz, device)
		if (device.name == 'Beweging_Woonkamer') and device.changed then
		    if (device.state == 'Off') then
		    dz.groups('Lampen_Woonkamer').switchOff()
	        elseif (dz.time.matchesRule('at nighttime') and device.state == 'On') then
	            if dz.devices('Harmony-PowerOff').state == 'On' then
	                dz.scenes('Avond').switchOn()
	                dz.log('Avond is ingeschakeld')
                    dz.scenes('TV_verlichting').switchOn()
                    dz.log ('TV verlichting is ingeschakeld')
                    dz.log (device.changed)
        if (device.name == 'Beweging_Eetkamer') and device.changed then
		    dz.groups('Lampen_Eetkamer').switchOff()
	            dz.groups('Lampen_Eetkamer').switchOn()
Raspberry pi 3, Domoticz Beta, Nginx, dzVents 2.7.4, RFXtrx433e, P1 smart meter, Harmony, Hue, Zwave, Amazon echo, Sonos, Synology DS413, HomeBridge, HA Bridge, Ubiquiti.
Re: Device.changed not working as expected
delcara wrote: Monday 19 November 2018 21:16 I've a dummy switch which is called "Beweging_Woonkamer". It's updated by 2 PIR's and is automatically switched off after 20 minutes. Now I have a light script for the dining room and sitting room and want to only execute the script if the status from "Beweging_Woonkamer" is changed (In my logic On > On is no status change). Because of the PIR's multiple On commands are sent if there is movement. I thought this could be achieved with the device.changed but this is not working. If I write the status of the device.change to the domzoticz log then its true even if I have multiple On commands and no change to off. Is my thinking wrong or does device.changed not work this way. Is there another solution to solve this?
Nothing wrong with your thinking but the dzVents changed method does not work as you expect. If you need to remember the state of a PIR or switch device you have to use persistent data. Below is an example of how that could look like .
Please note that the script has to run once to initialize the persistent data before it will become useful.
    on = { devices =   {   1157, 1158 }},
    data = { beweging = { initial = {} }},
        PIR_Woonkamer = dz.devices(1157)
        PIR_Eetkamer  = dz.devices(1158)
        if next(dz.data.beweging) == nil then -- Empty table so initialize
            dz.data.beweging[PIR_Woonkamer.name] = PIR_Woonkamer.state
            dz.data.beweging[PIR_Eetkamer.name]  = PIR_Eetkamer.state
        if device.state ~= dz.data.beweging[device.name] then
            dz.log("device " .. device.name .. "(".. device.id .. ") was updated and did change state")
            dz.data.beweging[device.name] = device.state
            dz.log("device " .. device.name .. "(".. device.id .. ") was updated but did not change state")
delcara
Post by delcara »
Thnx again, fixed it with a variable. I wanted to implement this to sent unnecessary commands (a lot due to the PIR's) in my zwave network. For people interested below is de code.
    active = true,
	                    'Beweging_Eetkamer'     }},
	    PIR_Woonkamer = dz.devices('Beweging_Woonkamer')
        PIR_Eetkamer  = dz.devices('Beweging_Eetkamer')
		if (device.name == 'Beweging_Woonkamer') and device.state ~= dz.data.beweging[device.name] then
        if (device.name == 'Beweging_Eetkamer') and device.state ~= dz.data.beweging[device.name] then
