Multiple wired door sensors
I've a closet with in total 10 doors, behind each door I want to but a wired (cheap) door sensor so that when the door opens I can enable the lights. What is the best wiring schema for such a solution? Put them all in serie and then connect it to the Raspberry on the GPIO connector? Any other suggestions?
- Domoticz version: Stable
Re: Multiple wired door sensors
Perhaps you can find your solution in: viewtopic.php?f=56&t=19870&p=192478#p192428
