Devolo Metering Plug MT02792
Posted: Thursday 15 November 2018 23:46
by Wolfgang
Version: V4.9700
Build Hash: a3a45906
Build Date: 2018-06-23 16:24:51
Platform: Raspi
Plugin/Hardware: RazBerry as GPIO Hat
Hi there ,
the metering plug 2792 is the "V2" version of the older plug called 2646. The XML file is nearly the same, the two device are working fine .
The only sad thing is the missing energy report on the new device .
The OZW-Panel shows the Energy report , but domoticz is not detecting it .
Any suggestions how to fix this ?
Wolfgang
Re: Devolo Metering Plug MT02792
Posted: Friday 16 November 2018 8:43
by gizmocuz
Did you enable accept new hardware under the settings ?
Posted: Friday 16 November 2018 20:48
by Wolfgang
Yes , I was activating "Allow New Devices for 5 Minutes " on domoticz and
plugged the metering plug off the socket and on again , but the Energy Value is still missing,,,
Posted: Saturday 17 November 2018 7:38
by gizmocuz
Maybe 5 minutes is to short and you get a value once an hour, try leaving it on
another thing could be that it does not report this value automatically and you need to enable polling for this device
but another thing could be that you need to put the controller in a certain group of the node to be able to receive these reports
Another thing could be that you need to 'configure' the node , like parameter 1 and 2
Posted: Saturday 17 November 2018 21:43
by Wolfgang
I configured the plug to send reports every 6 minutes ( minimm setting ) but there is no additional device detected .
I am wondering if there is a conflict because the energy value is once on the ozw panel seen as energy with the unit W (active power) and the same energy value with the unit VA ( apparent / reactive power )
https://imgur.com/a/zHjhgtk
The domoticz view as follows
https://imgur.com/a/4UV24zd
Posted: Sunday 18 November 2018 10:16
by gizmocuz
Are the values of "W" and "kWh" updated in the ozw panel ? Have they been updated once ?
kVAh was not implemented yet... i just made a small patch in the latest beta version, could you try this version? (enable accept new devices first)
Posted: Sunday 18 November 2018 20:31
by Wolfgang
the values are updated on the owz panel , the power values and the energy values are calculated in the right way , they are all plausible.
thank you gizmocuz for updating domoticz , i will try this with the latest beta ...
i will report back ...
Posted: Sunday 18 November 2018 20:55
by Wolfgang
hi gizmocuz,
updated the release version to the latest beta , domoticz restarted after completion , manually set domoticz to "new devices allowed for 5 minutes" and the energy values are shown in domoticz ... its working fine now
thank you !
Posted: Monday 19 November 2018 10:56
by gizmocuz
Great! thanks for the feedback!
