Download mesh network map data?
Posted: Sunday 11 November 2018 23:19
by jefft
Hi Folks,
Is there any way to download the raw data behind the domoticz z-wave network map?
I'm finding that the map isn't easy to read with my ~60 nodes - e.g. lines faded vs lines bright when I hover over a node isn't very clear and I have nodes whose arcs appear to end without reaching any other nodes, yet they work. I'd like to be able to look at the raw data pairs (node X can see node Y, etc) to be sure what I'm reading for diagnosis.
Re: Download mesh network map data?
Posted: Monday 12 November 2018 0:19
by waaren
jefft wrote: Sunday 11 November 2018 23:19 Is there any way to download the raw data behind the domoticz z-wave network map?
Try
http://Domoticz_IP:Domoticz_PORT/json.htm?type=command&param=zwavenetworkinfo&idx=<Zwave HARDWARE_ID>
Posted: Tuesday 05 February 2019 8:32
by jefft
Just noticed this, thought I had email notificaiton on the thread but seems not!
Waaren - That just gives an error, if I run it for idx=1... plus the syntax looks like it'll provide for one device at a time rather than dumping the map.
I have since found that the ozwcp has a tabular form of network map, which isn't easy to read (a sea of asterisks!) but it's clearer than the graphical one.
Posted: Tuesday 05 February 2019 8:43
by Egregius
The url provided by waaren is correct. Just replace the idx by the one your zwave hardware is using.
http://192.168.2.203:8080/json.htm?type=command&param=zwavenetworkinfo&idx=3
Output is this:
   "result" : {
      "mesh" : [
            "nodeID" : 1,
            "seesNodes" : "3,4,6,7,10,16,17,18,20,27,28,31,33,37,38,40,41,42,43,45,46,47,48,52,57,68,72,73,75,78,82,83,84,86,88,96,97,99,103,104,"
            "nodeID" : 2,
            "seesNodes" : "3,4,6,7,8,9,10,15,16,18,20,27,31,33,35,37,38,40,41,42,43,44,45,46,47,48,49,52,53,57,64,65,68,72,73,75,78,79,81,82,83,84,85,88,96,97,98,99,103,"
            "nodeID" : 3,
            "seesNodes" : "1,2,4,6,7,8,9,10,14,15,16,17,18,20,27,28,31,33,35,37,38,40,41,42,43,44,45,46,47,48,49,52,53,57,64,65,68,72,73,75,78,79,81,82,83,84,85,86,88,96,97,99,103,104,"
            "nodeID" : 4,
            "seesNodes" : "1,2,3,6,7,8,10,13,14,15,17,18,20,27,28,31,33,35,37,38,40,41,42,43,44,45,46,47,48,49,52,53,57,64,65,68,72,73,75,78,79,81,82,83,84,85,86,88,96,97,98,99,103,104,"
            "nodeID" : 6,
            "seesNodes" : "1,2,3,4,7,8,9,10,14,15,16,17,18,20,27,28,31,33,35,37,38,40,41,42,43,44,45,46,47,48,49,52,53,57,64,65,68,72,73,75,78,79,81,82,83,84,85,86,88,96,97,98,99,103,104,"
            "nodeID" : 7,
            "seesNodes" : "1,2,3,4,6,8,9,10,14,16,17,20,27,28,31,33,35,37,38,40,41,42,43,44,45,46,47,48,49,57,64,65,68,72,73,75,78,79,81,82,83,84,85,86,88,96,97,98,99,103,104,"
            "nodeID" : 8,
            "seesNodes" : "2,3,4,6,7,9,10,13,14,15,16,17,20,27,28,31,33,35,37,38,40,42,45,46,48,49,52,57,64,65,68,72,73,75,78,79,81,82,83,84,96,97,98,99,103,104,"
            "nodeID" : 9,
            "seesNodes" : "2,3,6,7,8,10,13,14,15,16,18,20,27,28,31,33,35,37,38,40,42,43,44,45,46,47,48,49,52,57,64,65,68,72,73,75,78,84,85,86,96,97,99,103,"
            "nodeID" : 10,
            "seesNodes" : "1,2,3,4,6,7,8,9,13,14,15,16,20,27,28,31,33,35,37,38,40,42,44,45,47,48,49,57,59,64,65,68,72,73,75,78,79,81,82,83,84,85,96,97,98,99,103,104,"
            "nodeID" : 13,
            "seesNodes" : "4,8,9,10,14,15,20,28,31,33,35,37,38,45,49,57,64,65,68,72,73,75,84,96,97,98,"
            "nodeID" : 14,
            "seesNodes" : "3,4,6,7,8,9,10,13,15,16,20,27,28,31,33,35,37,38,40,44,45,47,49,57,59,65,72,73,75,78,79,84,85,96,97,98,99,103,104,"
            "nodeID" : 15,
            "seesNodes" : "2,3,4,6,8,9,10,13,14,16,18,20,27,28,31,33,35,37,38,40,41,42,43,44,45,47,49,57,59,64,65,68,72,73,75,78,79,82,83,84,96,97,98,99,103,104,"
            "nodeID" : 16,
            "seesNodes" : "1,2,3,6,7,8,9,10,14,15,17,18,20,27,28,31,33,35,37,38,40,41,42,43,44,45,46,47,49,57,64,65,68,72,73,75,78,79,81,82,83,84,85,88,96,97,99,103,104,"
            "nodeID" : 17,
            "seesNodes" : "1,3,4,6,7,8,16,18,27,28,31,33,35,37,38,40,41,42,44,45,46,47,48,49,52,53,57,68,72,73,75,78,81,82,84,85,86,88,97,99,103,"
            "nodeID" : 18,
            "seesNodes" : "1,2,3,4,6,9,15,16,17,20,27,28,31,33,35,37,38,40,41,45,46,47,48,49,52,53,57,65,68,72,73,75,78,79,81,82,83,84,85,86,88,99,103,"
            "nodeID" : 20,
            "seesNodes" : "1,2,3,4,6,7,8,9,10,13,14,15,16,18,27,28,31,33,35,37,38,40,41,42,43,44,45,46,47,48,49,53,57,64,65,68,72,73,75,78,79,81,82,83,84,85,88,96,97,99,103,104,"
            "nodeID" : 27,
            "seesNodes" : ""
            "nodeID" : 31,
            "seesNodes" : "1,2,3,4,6,7,8,9,10,13,14,15,16,17,18,20,33,40,47,57,59,68,78,79,81,82,83,84,85,88,96,99,103,104,"
            "nodeID" : 32,
            "seesNodes" : ""
            "nodeID" : 33,
            "seesNodes" : "1,2,3,4,6,7,8,9,10,13,14,15,16,17,18,20,27,28,31,35,37,38,40,42,43,44,45,46,47,48,49,52,53,57,64,65,68,72,73,75,78,79,81,82,83,84,85,86,88,96,97,98,99,103,104,"
            "nodeID" : 35,
            "seesNodes" : "2,3,4,6,7,8,9,10,13,14,15,16,17,18,20,33,40,47,57,68,78,79,82,83,84,85,86,96,99,103,104,"
            "nodeID" : 37,
            "seesNodes" : "1,2,3,4,6,7,8,9,10,13,14,15,16,17,18,20,33,40,47,52,53,57,68,78,79,81,82,84,85,86,88,96,99,103,104,"
            "nodeID" : 38,
            "seesNodes" : "1,2,3,4,6,7,8,9,10,13,14,15,16,17,18,20,33,40,47,52,53,57,78,79,81,82,83,84,85,88,96,99,103,104,"
            "nodeID" : 40,
            "seesNodes" : "1,2,3,4,6,7,8,9,10,14,15,16,17,18,20,27,28,31,33,35,37,38,41,42,43,45,46,47,48,49,52,53,57,64,65,68,72,73,78,79,81,82,84,85,86,88,96,97,99,103,104,"
            "nodeID" : 41,
            "seesNodes" : ""
            "nodeID" : 42,
            "seesNodes" : "1,2,3,4,6,7,8,9,10,15,16,17,20,33,40,47,57,68,78,79,82,83,84,86,88,103,104,"
            "nodeID" : 43,
            "seesNodes" : "1,2,3,4,6,7,9,15,16,20,33,40,47,57,78,82,83,86,88,96,99,103,"
            "nodeID" : 44,
            "seesNodes" : "2,3,4,6,7,9,10,14,15,16,17,20,33,57,82,83,96,"
            "nodeID" : 45,
            "seesNodes" : "1,2,3,4,6,7,8,9,10,13,14,15,16,17,18,20,33,40,47,52,53,57,59,68,78,79,81,82,83,84,85,86,88,96,99,103,"
            "nodeID" : 46,
            "seesNodes" : ""
            "nodeID" : 47,
            "seesNodes" : "1,2,3,4,6,7,9,10,14,15,16,17,18,20,28,31,33,35,37,38,40,41,42,43,45,46,48,49,52,53,57,64,65,68,72,73,75,78,79,81,82,83,84,85,86,88,97,98,99,103,104,"
            "nodeID" : 48,
            "seesNodes" : "1,2,3,4,6,7,8,9,10,17,18,20,33,40,47,52,53,57,68,78,81,82,83,84,85,88,96,99,103,104,"
            "nodeID" : 49,
            "seesNodes" : "2,3,4,6,7,8,9,10,13,14,15,16,17,18,20,33,40,47,52,57,59,68,78,79,81,82,83,84,85,86,88,96,99,103,104,"
            "nodeID" : 51,
            "seesNodes" : ""
            "nodeID" : 52,
            "seesNodes" : "1,2,3,4,6,8,9,17,18,24,28,33,37,38,40,45,46,47,48,49,53,57,65,68,72,73,75,81,84,85,86,88,99,103,"
            "nodeID" : 53,
            "seesNodes" : "2,3,4,6,17,18,20,28,33,37,38,40,41,45,46,47,48,52,57,65,68,72,73,81,84,85,99,103,"
            "nodeID" : 57,
            "seesNodes" : "1,2,3,4,6,7,8,9,10,13,14,15,16,17,18,20,28,31,33,35,37,38,40,41,42,43,44,45,46,47,48,49,52,53,59,64,65,68,72,73,75,78,79,81,82,83,84,85,86,88,96,97,98,99,103,104,"
            "nodeID" : 59,
            "seesNodes" : "10,14,15,31,45,49,57,75,96,98,"
            "nodeID" : 64,
            "seesNodes" : "2,3,4,6,7,8,9,10,13,15,16,20,33,40,47,57,68,78,79,82,84,85,96,99,103,104,"
            "nodeID" : 65,
            "seesNodes" : "2,3,4,6,7,8,9,10,13,14,15,16,18,20,33,40,47,52,53,57,68,78,79,81,82,84,85,86,96,99,103,104,"
            "nodeID" : 68,
            "seesNodes" : "1,2,3,4,6,7,8,9,10,13,15,16,17,18,20,22,28,31,33,35,37,40,41,42,45,46,47,48,49,52,53,57,64,65,72,73,75,78,81,82,84,85,96,97,99,103,104,"
            "nodeID" : 72,
            "seesNodes" : "1,2,3,4,6,7,8,9,10,13,14,15,16,17,18,20,33,40,47,52,53,57,68,78,79,81,82,83,84,85,88,96,99,103,104,"
            "nodeID" : 73,
            "seesNodes" : "1,2,3,4,6,7,8,9,10,13,14,15,16,17,18,20,33,40,47,52,53,57,68,78,79,81,82,83,84,85,86,96,99,103,104,"
            "nodeID" : 75,
            "seesNodes" : "1,2,3,4,6,7,8,9,10,13,14,15,16,17,18,20,33,47,52,57,59,68,"
            "nodeID" : 28,
            "seesNodes" : "1,3,4,6,7,8,9,10,13,14,15,16,17,18,20,33,40,47,52,53,57,68,78,79,81,82,83,84,85,88,96,99,103,104,"
            "nodeID" : 79,
            "seesNodes" : "2,3,4,6,7,8,10,14,15,16,18,20,28,31,33,35,37,38,40,42,45,47,49,57,64,65,72,73,78,83,84,85,96,97,98,99,103,104,"
            "nodeID" : 78,
            "seesNodes" : "1,2,3,4,6,7,8,9,10,14,15,16,17,18,20,28,31,33,35,37,38,40,41,42,43,45,47,48,49,57,64,65,68,72,73,79,81,82,83,84,85,96,97,98,99,103,104,"
            "nodeID" : 81,
            "seesNodes" : "2,3,4,6,7,8,10,16,17,18,20,28,31,33,37,38,40,45,46,47,48,49,52,53,57,65,68,72,73,78,82,83,84,85,96,97,99,103,104,"
            "nodeID" : 82,
            "seesNodes" : "1,2,3,4,6,7,8,10,15,16,17,18,20,28,31,33,35,37,38,40,41,42,43,44,45,47,48,49,57,64,65,68,72,73,78,81,83,84,85,88,97,99,103,104,"
            "nodeID" : 83,
            "seesNodes" : "1,2,3,4,6,7,8,10,15,16,18,20,28,31,33,35,38,41,42,43,44,45,47,48,49,57,72,73,78,79,81,82,96,98,103,104,"
            "nodeID" : 84,
            "seesNodes" : "1,2,3,4,6,7,8,9,10,13,14,15,16,17,18,20,28,31,33,35,37,38,40,41,42,45,46,47,48,49,52,53,57,64,65,68,72,73,78,79,81,82,85,96,97,99,103,104,"
            "nodeID" : 85,
            "seesNodes" : "2,3,4,6,7,9,10,14,16,17,18,20,28,31,33,35,37,38,40,45,46,47,48,49,52,53,57,64,65,68,72,73,78,79,81,82,84,96,97,98,99,103,104,"
            "nodeID" : 86,
            "seesNodes" : "1,3,4,6,7,9,17,18,33,35,37,40,41,42,43,45,46,47,49,52,57,65,73,88,97,103,"
            "nodeID" : 88,
            "seesNodes" : "1,2,3,4,6,7,16,17,18,20,28,31,33,37,38,40,41,42,43,45,47,48,49,52,57,72,82,86,99,103,"
            "nodeID" : 94,
            "seesNodes" : ""
            "nodeID" : 95,
            "seesNodes" : ""
            "nodeID" : 96,
            "seesNodes" : "1,2,3,4,6,7,8,9,10,13,14,15,16,20,28,31,33,35,37,38,40,43,44,45,48,49,57,59,64,65,68,72,73,78,79,81,83,84,85,97,98,99,103,104,"
            "nodeID" : 97,
            "seesNodes" : ""
            "nodeID" : 98,
            "seesNodes" : "2,4,6,7,8,10,13,14,15,33,47,57,59,78,79,83,85,96,99,104,"
            "nodeID" : 99,
            "seesNodes" : "1,2,3,4,6,7,8,9,10,14,15,16,17,18,20,28,31,33,35,37,38,40,43,45,46,47,48,49,52,53,57,64,65,68,72,73,78,79,81,82,84,85,88,96,98,103,"
            "nodeID" : 103,
            "seesNodes" : "1,2,3,4,6,7,8,9,10,14,15,16,17,18,20,28,31,33,35,37,38,40,42,43,45,46,47,48,49,52,53,57,64,65,68,72,73,78,79,81,82,83,84,85,86,88,96,99,104,"
            "nodeID" : 104,
            "seesNodes" : "1,3,4,6,7,8,10,14,15,16,20,28,31,33,35,37,38,40,42,47,48,49,57,64,65,68,72,73,78,79,81,82,83,84,85,96,98,103,"
            "nodeID" : 105,
            "seesNodes" : ""
      "nodes" : "1,2,3,4,6,7,8,9,10,13,14,15,16,17,18,20,27,31,32,33,35,37,38,40,41,42,43,44,45,46,47,48,49,51,52,53,57,59,64,65,68,72,73,75,28,79,78,81,82,83,84,85,86,88,94,95,96,97,98,99,103,104,105,"
   "status" : "OK",
   "title" : "ZWaveNetworkInfo"
