Differentiate once or twice pressing a switch
Posted: Sunday 11 November 2018 10:47
by saik
I have one push button and try to run different external scripts depending on number of pushes within 2 seconds.
If I push once, only the script for single pressed should be executed. If I push twice, only the script for double pressed should be executed.
Unfortunately, I have no clue how realize that with DzVents.
Re: Differentiate once or twice pressing a switch
Posted: Sunday 11 November 2018 11:55
by waaren
saik wrote: Sunday 11 November 2018 10:47
Assuming this is not a push-button capable of making the distinction between single or double push itself (like the Xiaomi push-button)
My personal preference would be to combine the two scripts into one script with an if / else block. But if they really have to stay separated, you need an activation script and two user variables, dummy switches or two different callbacks from an domoticz.openURL call. Implementation below is with two uservariables and a helper script.
Activation script
--[[ -- doublePush
This script requires two domoticz uservariables (integer type) set to 0
local buttonName = "doublePush" -- Name of your trigger button
local singlePush = "scriptName1" -- Names of your uservariables (type integer and set to 0)
local doublePush = "scriptName2"
on = { devices = { buttonName }},
logging = { level = domoticz.LOG_DEBUG ,
marker = "doublePush"},
data = { lastState = { initial = "" }},
execute = function(dz, item )
singlePush = dz.variables(singlePush)
doublePush = dz.variables(doublePush)
delaySeconds = 2
if item.state == "On" and dz.data.lastState == "On" and item.lastUpdate.secondsAgo <= delaySeconds then
singlePush.cancelQueuedCommands()
doublePush.set(1)
dz.data.lastState = ""
elseif item.state == "On" then
dz.data.lastState = "On"
singlePush.set(1).afterSec(delaySeconds + 2) -- Maybe + 1 also works but to stay at the safe side
dz.data.lastState = item.state
script1
-- doublePush_script1
on = { variables = { singlePush }},
marker = "doublePush_script1"},
execute = function(dz)
dz.log("Script 1 is executing",dz.LOG_DEBUG)
script2
-- doublePush_script2
local doublePush = "scriptName2" -- Names of your uservariables (type integer and set to 0)
on = { variables = {doublePush }},
marker = "doublePush_script2"},
dz.log("Script 2 is executing",dz.LOG_DEBUG)
