Add support for IPX800, a standalone relay webserver
Grouic
Post by Grouic »
I wonder what is the best solution to add support for IPX800 V3 Domoticz.
http://gce-electronics.com/en/home/57-ipx800-v300.html
The IPX800 is a standalone relay webserver with a LAN interface, which includes 8-32 relay output, 8-32 digital inputs and 4-16 analog inputs.
Way to communicate with IPX are:
- M2M protocol
- Push from IPX (on timer or event)
- Xml stream status
- JSON protocol
I think we should define a new type of material with:
- IP address
- Number of digital extensions
- Number of analog extensions
And then set each item separately
elringer
Re: Add support for IPX800, a standalone relay webserver
Post by elringer »
Hello
+1 for me, the IPX800 is a great card
Manu35500
Post by Manu35500 »
+1 ça serai un plus ^^
Chaussette
Post by Chaussette »
Bonjour,
Moi aussi je souhaite piloter un IPX800.
Protocoles M2M et IP.
Doc des protocoles (Semble simple) : http://www.gce-electronics.com/attachme ... achment=47
Avantage : IPX Autonome pour piloter des fonctions spécifiques (Volets, Portail, Eclairage extérieur...).
Possibilité de l'insérer dans un ensemble Domoticz sur raspberryPI.
Cordialement
mbliek
Post by mbliek »
This is an English forum. In English please.
Petiot35
Post by Petiot35 »
That would be a really nice new feature.
Are you going to add it for IPX800 v3 and v4 ?
Cheers
Number8
Domoticz version: 2022.1
Post by Number8 »
I don't think this would a priority for the dev team, more a nice to have. I've been using the IPX800 v3 for 2 or 3 years and I had no difficulties to integrate it within Domoticz. Very easy to drive the relays (just an http url in On/Off action), fairly easy to retrieve the analog outputs.
For instance, to drive relays 5 On and 6 Off
http://user:password@IPAdress/preset.htm?set5=1&set6=0
To retrieve analog values (3 channels), a bash script is needed
#!/bin/bash
IPX800=192.168.21.232
LOGFILE="/mnt/usbkey/tmp/ipx800.log"
DOMOTICZSERVER=192.168.21.240
DOMOTICZPORT=8080
#Create virtual sensors in Domoticz and enter their IDX's here. For the sensor types
IDX_TEMP_1=206
IDX_TEMP_2=198
IDX_TEMP_3=197
IDX_TEMP_4=
if ping -c 1 $IPX800 > /dev/null ; then  # if host is online then
	#Retrieve temperatures from IPX800
	curl --silent http://$IPX800/status.xml > $LOGFILE
	TEMP_1=$(cat $LOGFILE | grep "<analog0>" | cut -d ">" -f 2 | cut -d "<" -f 1)
	TEMP_1=$(echo 'scale=1;'"$TEMP_1*0.323-50.1" | bc | awk '{printf("%.1f\n", $1)}')
	#echo $TEMP_1
	TEMP_2=$(cat $LOGFILE | grep "<analog1>" | cut -d ">" -f 2 | cut -d "<" -f 1)
	TEMP_2=$(echo 'scale=1;'"$TEMP_2*0.323-50.1" | bc | awk '{printf("%.1f\n", $1)}')
	#echo $TEMP_2
	TEMP_3=$(cat $LOGFILE | grep "<analog2>" | cut -d ">" -f 2 | cut -d "<" -f 1)
	TEMP_3=$(echo 'scale=1;'"$TEMP_3*0.323-50.1" | bc | awk '{printf("%.1f\n", $1)}')
	#echo $TEMP_3
	for i in 1 2 3
		do
			#report Temperature
			eval IDX='$'IDX_TEMP_$i
			eval TEMP='$'TEMP_$i
			curl --silent $DOMOTICZSERVER:$DOMOTICZPORT'/json.htm?type=command&param=udevice&idx='$IDX'&svalue='$TEMP > /dev/null
		done
	echo "IPX800 not responding to ping, is it connected to LAN?"
fi
This one is a bit more engaging.
Need to modify the crontab, need to install bc in order to perform math operations, need to write in log file that is setup on a ram disk that turns to be a USB key in order to avoid SD card wear.
Crontab (refresh value every 3 minutes)
*/3 * * * * (/home/pi/domoticz/scripts/getTemp.sh)
Debian buster on NUC and three RPi with buster.
manuloup
Post by manuloup »
hello,
+1
It is true that it would be great to have native support and all devices added automatically. Some other products like Jeedom already do it.
Rapberry PI B+ (RaspBian), RFXtrx433E USB 433.92MHz Transceiver, AEON LABS Controler Z-Wave, Aeon Labs Z-Stick S2, Everspring ST814 Temperature Sensor, Everspring SF812 Smoke Detector, 2x Fibaro Wallplug, Aeon Zwave Miniremote , Xbee Teleinfo USB
Clemen
Post by Clemen »
Number8 wrote:I don't think this would a priority for the dev team, more a nice to have. I've been using the IPX800 v3 for 2 or 3 years and I had no difficulties to integrate it within Domoticz. Very easy to drive the relays (just an http url in On/Off action), fairly easy to retrieve the analog outputs.
#!/bin/bash
DOMOTICZPORT=8080
IDX_TEMP_1=206
IDX_TEMP_2=198
IDX_TEMP_3=197
IDX_TEMP_4=
	#echo $TEMP_1
	#echo $TEMP_2
	#echo $TEMP_3
	for i in 1 2 3
		do
			#report Temperature
		done
fi
What delay do you have on the outputs?
laco
Domoticz version: 2021.1
Post by laco »
Hello.
I also have an IPX800 relay.
I have a Domotitz server installed on Synology.
I'm trying to add here, could someone help me?
What hardware should I add?
Which switch should I choose?
Where do I put the basch script for analog inputs?
Well thank you.
laco
Post by laco »
Relay I managed to add
hardware:
Dummy (Does not use virtual switches only)
Add next:
Create Virtual Sensor
Choose:
Switch Type: On / Off
On Action:
http://192.168.1.125/preset.htm?led1=1
  Off Action:
http://192.168.1.125/preset.htm?led1=0
I now control the relay. :D
:( Next I can not move, I need to retrieve data from IPX800 v1, pro, v3
I have 8 analogue sensors, 1 counter and 6 digital sensors
Will someone help me? I am willing to pay for your help.
laco
Post by laco »
I created a virtual IDX16 and IDX17 thermometer
I have used the LM35Z temperature sensor an1 in IPX800
Temperature calculation an1 * 0.323
Status XML IPX800:
<response>
<led0>1</led0>
<led1>1</led1>
<led2>0</led2>
<led3>0</led3>
<led4>0</led4>
<led5>0</led5>
<led6>0</led6>
<led7>0</led7>
<btn0>up</btn0>
<btn1>up</btn1>
<btn2>up</btn2>
<btn3>up</btn3>
<an1>69</an1>
<an2>54</an2>
<time0>08:35:41</time0>
</response>
I used the script getTemp.sh
#!/bin/bash
IPX800=192.168.1.125
LOGFILE="/volume1/@appstore/domoticz/var/scripts/ipx800.log"
DOMOTICZSERVER=192.168.1.200
DOMOTICZPORT=8084
IDX_TEMP_1=16
IDX_TEMP_2=17
TEMP_1=$(cat $LOGFILE | grep "<an1>" | cut -d ">" -f 2 | cut -d "<" -f 1)
#echo $TEMP_1
TEMP_2=$(cat $LOGFILE | grep "<an2>" | cut -d ">" -f 2 | cut -d "<" -f 1)
#echo $TEMP_2
for i in 1 2
do
#report Temperature
curl -s '$DOMOTICZSERVER:$DOMOTICZPORT'/json.htm?type=command&param=udevice&idx='$IDX'&svalue='$TEMP > /dev/null
done
fi
I created Cron to run: bash /volume1/@appstore/domoticz/var/scripts/getTemp.sh
Current status: 2 (Suspended)
Standard Output / Error:
/volume1/@appstore/domoticz/var/scripts/getTemp.sh: line 23: syntax error near unexpected token `eval'
/volume1/@appstore/domoticz/var/scripts/getTemp.sh: line 23: `eval IDX='$'IDX_TEMP_$i
And I'm probably done here. The previous script was for raspberry pi.
Will anyone help me to create a synology script?
laco wrote: Sunday 04 November 2018 9:37 I created a virtual IDX16 and IDX17 thermometer
Can you try and change the block
for i in 1 2
do
#report Temperature
done
to the lines
curl -s '$DOMOTICZSERVER:$DOMOTICZPORT'/json.htm?type=command&param=udevice&idx='$IDX_TEMP_1'&svalue='$TEMP_1 > /dev/null
curl -s '$DOMOTICZSERVER:$DOMOTICZPORT'/json.htm?type=command&param=udevice&idx='$IDX_TEMP_2'&svalue='$TEMP_2 > /dev/null
laco
Post by laco »
Task: Snimac teploty IPX800 akva
Start time: Sun, 04 Nov 2018 14:11:25 GMT
Stop time: Sun, 04 Nov 2018 14:11:26 GMT
Current status: 2 (Interrupted)
Standard output/error:
/volume1/@appstore/domoticz/var/scripts/getTemp.sh: line 21: syntax error near unexpected token `$'do\r''
/volume1/@appstore/domoticz/var/scripts/getTemp.sh: line 21: `do
Sincerely,
Synology DiskStation
laco wrote: Sunday 04 November 2018 14:12
Sincerely,
Can you show how your script looks like now ?
laco
Post by laco »
#!/bin/bash
DOMOTICZPORT=8084
IDX_TEMP_1=16
IDX_TEMP_2=17
IDX_TEMP_3=
IDX_TEMP_4=
#echo $TEMP_1
#echo $TEMP_2
for i in 1 2
do
#report Temperature
done
fi
laco wrote: Sunday 04 November 2018 14:41
#!/bin/bash
DOMOTICZPORT=8084
IDX_TEMP_1=16
IDX_TEMP_2=17
IDX_TEMP_3=
IDX_TEMP_4=
#echo $TEMP_1
#echo $TEMP_2
for i in 1 2
do
#report Temperature
done
fi
What I meant with my last post is this:
#!/bin/bash
DOMOTICZPORT=8084
IDX_TEMP_1=16
IDX_TEMP_2=17
IDX_TEMP_3=
IDX_TEMP_4=
    #echo $TEMP_1
    #echo $TEMP_2
    #report Temperature
fi
laco
Post by laco »
Start time: Sun, 04 Nov 2018 14:50:35 GMT
Stop time: Sun, 04 Nov 2018 14:50:36 GMT
Current status: 0 (Normal)
ping: socket: Operation not permitted
Sincerely,
laco wrote: Sunday 04 November 2018 14:52 Task: Snimac teploty IPX800 akva
You should first try these commands (ping and curl) from the CLI as the user that will also execute the script.
Maybe they need to use sudo the be allowed to execute these commands. If so, you also have to adjust the commands in the script.
like
!/bin/bash
DOMOTICZPORT=8084
IDX_TEMP_1=16
IDX_TEMP_2=17
IDX_TEMP_3=
IDX_TEMP_4=
if sudo ping -c 1 $IPX800 > /dev/null ; then  # if host is online then
    #echo $TEMP_1
    #echo $TEMP_2
    #report Temperature
    sudo curl -s '$DOMOTICZSERVER:$DOMOTICZPORT'/json.htm?type=command&param=udevice&idx='$IDX_TEMP_1'&svalue='$TEMP_1 > /dev/null
    sudo curl -s '$DOMOTICZSERVER:$DOMOTICZPORT'/json.htm?type=command&param=udevice&idx='$IDX_TEMP_2'&svalue='$TEMP_2 > /dev/null
fi
laco
Post by laco »
/volume1/@appstore/domoticz/var/scripts/getTemp.sh: line 1: !/bin/bash: No such file or directory
cat: /volume1/@appstore/domoticz/var/scripts/ipx800.log
/volume1/@appstore/domoticz/var/scripts/getTemp.sh: line 15: bc: command not found
/volume1/@appstore/domoticz/var/scripts/getTemp.sh: line 18: bc: command not found
/volume1/@appstore/domoticz/var/scripts/getTemp.sh: line 23: $'else\r': command not found
