MQTT -Roller Shutter TASMOTA Dual R2
Posted: Tuesday 06 November 2018 9:58
by skorc11
i have dual R2 with tasmota FW- stefanbode patch.
Shutters are working and now i would like to send MQTT commands .
I created blinds percentage device .
Default Domoticz command :
10:02:12 MQT: stat/sonoff_dual_R2/RESULT = {"Command":"Unknown"}
10:02:45 Shutter unknown
10:02:45 MQT: stat/sonoff_dual/RESULT = {"Command":"Unknown"}
I have to send the percentage to shutterposition1 as a command- MQTT
Is this possible ?
U
Re: Roller Shutter TASMOTA Dual R2 MQTTupdate
Posted: Sunday 11 November 2018 8:12
by skorc11
tasmota FW with StefanB patch is now working- based on svalue- slider is ok.
"idx":156,"nvalue":0,"svalue":"56","Battery":58,"RSSI":5
But NVALUE is always 0.
it should be 0,2,1.
nValue 0 and sValue 0 ==>> Closed
nValue 2 and sValue 2-99 ==>> partially opened
nValue 1 and sValue 100 ==>> Opened
Nvalue reads relay it is not as dimmer.. (1 when releay is ON-blind moving 0 when stopped)
Is it possible to change this in any way ?
U
Re: MQTT -Roller Shutter TASMOTA Dual R2
Posted: Monday 12 November 2018 16:06
by salvacalatayud
I'm interested in this project. But I even don't know how to install this firmware.
Anyone can help?
Thanks in advance
Posted: Wednesday 14 November 2018 21:07
by skorc11
stefanbode is still working on FW.. I will post when it is done. Till now manual control with MQTT position is working perfect.
U
Posted: Wednesday 14 November 2018 21:16
by salvacalatayud
skorc11 wrote:Hello,
U
Great news then.
Yesterday I flashed my sonoff touch and worked, after that unpluged it and today plugged again but it doesn't connect to wifi...
Enviado desde mi Mi A2 mediante Tapatalk
Posted: Friday 23 November 2018 13:25
by salvacalatayud
My sonoff are t1 2ch, can't work for now.
I'll be waitning for it
Posted: Friday 15 February 2019 16:14
by salvacalatayud
skorc11 wrote: Sunday 11 November 2018 8:12
it should be 0,2,1.
U
What kind of blind are you using to send % to the sonoff? I've tried with blinds percentaje and doesn't work
Posted: Friday 08 March 2019 21:12
by salvacalatayud
I use node red to translate domoticz to tasmota mqtt, it sends a mqtt command, tasmota sends a status position, and node red updates the position back to Domotcz by http, then the shutter moves again to a diferent position, small movements. This happens a few times and then stops.
Any idea of how to deal with this?
Posted: Tuesday 25 May 2021 22:56
by AchilleTalon
Sorry to "revive" an old topic, but apparently I can't send PMs yet.
I use domoticz and Shelly"s 2.5 with tasmota to control blinds, but I wasn't able to find a proper setup for tasmota (the "configure Domoticz" section): I'm still stuck with virtual buttons and a blockly script.
Could you please share the way you setup your tasmota module?
Thanks in advance.
Posted: Wednesday 26 May 2021 1:30
by waltervl
This plugin supports standard Shelly devices
https://github.com/enesbcs/Shelly_MQTT
Tasmoticz perhaps also supports shutters (it is on the roadmap)
https://github.com/joba-1/Tasmoticz
Posted: Wednesday 26 May 2021 9:49
by AchilleTalon
Thanks. I'll look into it. Shelly_MQTT seems to work fine for "standard" devices, but I'd like to use an already flashed Shelly 2.5 (already installed, I'd like not to have to take it out, reflash it, then put it back): Tasmoticz will hopefully be the solution.
